查看: 4140|回复: 0
[LV工具模块] LabVIEW 2020 SoftMotion Module Win32 NI运动控制模块20.5 适用LV2020
    2 小时前
  • 签到天数: 3591 天
    连续签到: 11 天
    发表于 2020-12-4 12:09:42 | 显示全部楼层 |阅读模式 来自:湖南省怀化市 移动
    LabVIEW 2020 SoftMotion模块(官方位数说明是32/64位版本,但是其自述文件里则只支持32位)
    LabVIEW SoftMotion模块可帮助您将运动控制与I/O和视觉应用程序进行集成。
    LabVIEW SoftMotion模块是LabVIEW编程环境的一个附加软件。您可在LabVIEW项目中配置、测试和调整LabVIEW SoftMotion轴。您可以将这些轴绑定到各种NI和第三方硬件配置。该模块具有用于自定义运动应用设计的高级功能,包括轨迹生成和多轴功能,如齿轮和坐标空间。
    百度网盘下载地址(百度限速,请耐心等待。或使用破解工具或开超级会员提速):
    请注册视觉论坛用户,登录后购买附件下载查看
    NI官方下载地址(可能失效或无法下载完成):
    SMM2020.txt (679 Bytes, 下载次数: 3, 售价: 10 元)
    LabVIEW 2020 SoftMotion Module 20.5
    文件大小: 470155264 字节 (448.38 MB)
    修改日期: 2020-12-04 11:54
    MD5: 0539368979d446610966ef24b4f57ebd(官方正确)
    SHA1: 3fd87a4454e8327d9bedb092513cd1bfe2ace5af
    SHA256: ed5e61daae9062a6aa7728d71e8d32e067ee479f82f536d4e123948c17b7915e
    CRC32: df9f1b3f
    LabVIEW 2020 SoftMotion™ Module Readme
    August 2020
    This document contains information to introduce you to the LabVIEW 2020 SoftMotion Module including installation information, a list of changes in this version of SoftMotion, and information about known issues for this version of SoftMotion.
    Contents
    The LabVIEW SoftMotion Module allows you to use the LabVIEW project to configure and test your motion axis settings, tune your servo motors, program deterministic motion profiles, create custom motion applications, and simulate your designs created in SOLIDWORKS.
    Note  Refer to the SoftMotion Selection Guide for a description of the different SoftMotion Module packages available.
    The LabVIEW 2020 SoftMotion Module supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 LabVIEW SoftMotion Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW 2020 SoftMotion Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2020 SoftMotion Module to an unsupported OS. Additionally, after installing LabVIEW 2020 SoftMotion Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The LabVIEW SoftMotion Module runs as a 32-bit application on all operating systems.
    To run the LabVIEW SoftMotion Module, National Instruments recommends that your system meet the following requirements in addition to the minimum requirements for the LabVIEW Development System for Windows:
    • 2 GB of memory if using SoftMotion for SOLIDWORKS
    • 500 MB of free disk space
    The LabVIEW 2020 SoftMotion Module is compatible with the following National Instruments software.
    • LabVIEW 2020 Base, Full, or Professional Development System (32-bit)
    • LabVIEW 2020 Real-Time Module
    • LabVIEW 2020 FPGA Module
    • NI-RIO 20.0 (included in NI CompactRIO 20.0 and Drivers)
    • NI-Industrial Communications for EtherCAT® 20.0
    Note  To use SoftMotion for SOLIDWORKS you must have SOLIDWORKS 2009 SP2.1 or later.
    NI installs LabVIEW 2020 SoftMotion Module using NI Package Manager. If you do not already have NI software installed, LabVIEW 2020 SoftMotion Module installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate LabVIEW 2020 SoftMotion Module. For more information on LabVIEW 2020 SoftMotion Module activation, refer to National Instruments Software Activation.
    Licensing
    The LabVIEW SoftMotion Module relies on licensing activation. After the evaluation period for SoftMotion Module expires, you must activate a valid license before you can run the full version of the software. To activate the SoftMotion Module, use the serial number you received as part of your installation package.
    If the LabVIEW SoftMotion Module is not activated and the evaluation period expires, the product will have restricted functionality. Refer to the SoftMotion Selection Guide for a description of the different SoftMotion Module packages available.
    Refer to the Activation Instructions for National Instruments Software for more information about licensing activation.
    LabVIEW 2020 SoftMotion Module Features and ChangesLabVIEW 2020 Support
    LabVIEW 2020 SoftMotion Module is fully supported on LabVIEW 2020.
    Real-Time Controller Support
    Refer to the National Instruments Website for a complete list of supported real-time controllers.
    SoftMotion Drive Interface (SDI) Plug-ins for Third-Party EtherCAT Drives
    SDI plug-ins for third-party EtherCAT motor drives are actively released and updated on the LabVIEW Tools Network. To learn more about SDI or download plug-ins, visit the National Instruments Website.
    LabVIEW 2020 SoftMotion Module Bug Fix List
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    General InformationLabVIEW Real-Time Users
    To use the updates and features included in the LabVIEW 2020 SoftMotion Module, you must install the LabVIEW 2020 SoftMotion Module software on the LabVIEW Real-Time target system using Measurement & Automation Explorer (MAX). NI recommends reformatting your LabVIEW Real-Time target and installing the latest recommended software set when upgrading LabVIEW and the LabVIEW SoftMotion Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about SoftMotion Module concepts, using SoftMotion, step-by-step instructions using the LabVIEW SoftMotion Module, and reference information about SoftMotion VIs and functions.
    LabVIEW examples for the SoftMotion Module can be found in the Example Finder (at Help > Find Examples) in two different directories: the Hardware Input and Output\Motion Control\SoftMotion folder and the Toolkits and Modules\SoftMotion folder. The examples are grouped into three primary categories:
    Hardware Specific - for use with specific hardware combinationsExpress VIs - API examples for all hardware combinationsProperties and Methods - API examples for all hardware combinationsReinitialization - for resetting the SoftMotion engine on real-time targets
    The Getting Started Guides contain detailed information for setting up and configuring specific SoftMotion hardware. Visit the Resources tab on the product page at ni.com to find a Getting Started Guide for your hardware. In LabVIEW 2014 SP1 SoftMotion Module and later, the examples for the NI 9502, 9503, and 9503 drive modules were converted to Sample Projects. These can be found in the Create Project menu in LabVIEW.
    LabVIEW 2020 SoftMotion Module Known Issues
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in this release.
    LabVIEW SoftMotion Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    LabVIEW SoftMotion Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi.
    Important Information
    © 2004–2020 National Instruments. All rights reserved.
    • EULAs are located in the \_Legal Information.txt for information on including legal information in installers built with NI products.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks. EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patent.
    376347D-01
    GMT+8, 2025-7-11 12:50
