查看: 3352|回复: 0
[NI驱动程序] NI-TimeSync 18.0 Win32/64Eng NI时间同步驱动程序18.0版下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-11-26 00:09:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-TimeSync
    NI-TimeSync可帮助安装、配置和监控嵌入式PXI目标上的同步。
    NI-TimeSync是一款驱动软件,可与PXI系统中的模块进行通信和同步。此软件可搭配PXI同步模块使用,用于对运行LabVIEW Real-Time模块的PXI控制器进行同步。该软件可以使用LabVIEW Real-Time模块的日期和时间对PXI控制器进行同步,同时包含基于与系统时间交互的API。此外,NI-TimeSync还提供LabVIEW范例,说明如何使用同步的绝对时间来协调多个实时目标或PXI机箱。NI-TimeSync支持通用和实时操作系统,包括Windows、Windows Server、NI Linux Real-Time、VxWorks和PharLap ETS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    18.0
    文件大小: 516313040 字节 (492.39 MB)
    修改日期: 2018-05-17 00:55
    MD5: a6932d6fcb77746142ea94884bb22334(重复一致)
    SHA1: 8852105bc640972c224d3e56da8e641d6cc5cc90
    SHA256: d205d3cbd5106d7d7f8ef53c16f9af8cf07c2a52b21d54c62d2d7f9ac89f1c5c
    CRC32: 532cdacd
    NITS18.0.txt (583 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-TimeSync 18.0 Readme
    May 2018
    NI-TimeSync is a coordinated set of synchronization protocols that can be used to synchronize time between multiple systems.
    NI-TimeSync 18.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R2 (x64) 1, 3, 4
    • Windows Server 2008 R2 (x64) 2, 3, 4
    • NI Real-Time VxWorks
    • NI Real-Time Phar Lap ETS
    • NI Linux Real-Time5, 6
    Note  In 2016 NI-TimeSync dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-TimeSync will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-TimeSync to an unsupported OS. Additionally, after installing NI-TimeSync, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    1NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 System Configuration does not support non-R2 versions of Windows Server.
    4 Support for Windows Server 2008 R2 and Windows Server 2012 R2 requires disabling Internet Explorer Enhanced Security Configuration (IE ESC). To learn how this affects your use of Windows Server 2008 R2 and Windows Server 2012 R2 and what actions you must take, visit ni.com/info and enter the Info Code MAXSupportIEESC.
    5 IEEE 1588-2008 protocol instances on ARM-based targets running NI Linux Real-Time are configured to be "slave only" by default. For more information about this issue, visit ni.com/info and enter the Info Code ARMTargetSlaveOnly.
    6The NI-TimeSync property node installed is not supported on NI Linux Real-Time targets. The NI-Sync API can be used with NI Linux Real-Time targets.
    NI-TimeSync 18.0 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI-TimeSync
    LabVIEW2015 SP11, 2016 SP1, 2017 SP1, 2018
    LabVIEW Real-Time Module2015 SP11, 2016 SP1, 2017 SP1, 2018
    1To use the NI-Sync 18.0 API on Linux RT targets with LabVIEW 2015 SP1, you must have the LabVIEW 2015 SP1 f3 or later patch installed.
    NI-TimeSync 18.0 is incompatible with NI-Sync 17.0 and earlier.
    You can access the software and documentation known issues list online. For a list of known issues with NI-TimeSync 18.0, visit ni.com/info and enter the Info Code NITimeSync180KnownIssues.
    For a list of bug fixes for NI-TimeSync, visit ni.com/info and enter the Info Code NITimeSyncFixList.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    • NI-TimeSync now installs the NI-Sync API. NI-Sync provides support for monitoring and configuring system time synchronization on Linux RT targets where NI-TimeSync time references are installed. NI-TimeSync 18.0 is incompatible with NI-Sync 17.0 and earlier.
    • NI-TimeSync 18.0 includes a new plugin for NI-Sync that allows you to synchronize a PXI controller's system time to hardware supported by NI-Sync. A beta version of this plugin was previously released on NI-Sync Labs.
    ©2009-2018 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help�Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    374886J-01
    GMT+8, 2025-11-19 12:45
