查看: 3106|回复: 0
[NI驱动程序] NI-TimeSync 14.5 Win32/64Eng NI时间同步驱动程序14.5版下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-11-25 23:52:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-TimeSync
    NI-TimeSync可帮助安装、配置和监控嵌入式PXI目标上的同步。
    NI-TimeSync是一款驱动软件,可与PXI系统中的模块进行通信和同步。此软件可搭配PXI同步模块使用,用于对运行LabVIEW Real-Time模块的PXI控制器进行同步。该软件可以使用LabVIEW Real-Time模块的日期和时间对PXI控制器进行同步,同时包含基于与系统时间交互的API。此外,NI-TimeSync还提供LabVIEW范例,说明如何使用同步的绝对时间来协调多个实时目标或PXI机箱。NI-TimeSync支持通用和实时操作系统,包括Windows、Windows Server、NI Linux Real-Time、VxWorks和PharLap ETS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    14.5
    文件大小: 396432200 字节 (378.07 MB)
    修改日期: 2015-02-28 02:20
    MD5: 03104c5d79b4a9c258d626e85cfd1dc4
    SHA1: dc5eee9c24303425eab4b896e361b4ff32dcc263
    SHA256: 119d454f504182a3e93e662f4cb0c050f3fbe5b488e8c0d9474dfae0042154bb
    CRC32: f7ad4b0c
    NITS14.5.txt (559 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-TimeSync 14.5 Readme
    February 2015
    Driver Version Naming Changes
    Known Issues and Bug Fixes
    System RequirementsSupported Platforms
    NI-TimeSync 14.5 supports the following platforms:
    • Windows XP Service Pack 3
    • Windows Vista x86, x64
    • Windows 7 x86, x64
    • Windows 8 x86, x64
    • Windows 8.1 x86, x64
    • Windows Server 2003 R2 (x86) 1,2
    • Windows Server 2008 R2 (x64) 1,3
    • Windows Server 2012 R2 (x64) 1,3
    • NI Real-Time VxWorks
    • NI Real-Time Phar Lap ETS
    • NI Linux Real-Time4
    1 System Configuration does not support non-R2 versions of Windows Server.
    2 Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the Info Code PAESupport.
    3Support for Windows Server 2008 R2 and Windows Server 2012 R2 requires disabling Internet Explorer Enhanced Security Configuration (IE ESC). To learn how this affects your use of Windows Server 2008 R2 and Windows Server 2012 R2 and what actions you must take, visit ni.com/info and enter the Info Code MAXSupportIEESC.
    4ARM-based targets running NI Linux Real-Time are slave only by default. For more information about this issue, visit ni.com/info and enter the Info Code ARMTargetSlaveOnly.
    The following table lists the application software versions, including service packs, supported by NI-TimeSync.
    Application SoftwareVersions Supported by NI-TimeSync
    LabVIEW2011, 2012, 2013, 2014
    LabVIEW Real-Time Module2011, 2012, 2013, 2014
    NI-TimeSync Version Naming Changes
    NI-TimeSync versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the NI-TimeSync was released and the most recent software version the software was designed to work with. Versions now start with a two-digit year indicator: <;ProductName>. For example, NI-TimeSync 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-TimeSync 1.3. The first version released under the new numbering scheme is NI-TimeSync 14.0.
    For a list of Known Issues of NI-TimeSync 14.5, visit ni.com/info and enter the Info Code NITimeSync145KnownIssues.
    For a list of Bug Fixes for NI-TimeSync, visit ni.com/info and enter the Info Code NITimeSyncFixList.
    Using NI Launcher
    Finding All Programs
    NI-TimeSync Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-TimeSync will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-TimeSync that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    NI DIAdemddlcp
    NI SignalExpressselcp
    ©2009-2015 National Instruments. All rights reserved.
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    374886A-01
    GMT+8, 2025-11-19 12:45
