查看: 2854|回复: 0
[NI驱动程序] NI-TimeSync 1.3 Win32/64Eng NI时间同步驱动程序1.3版下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-11-25 23:47:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-TimeSync
    NI-TimeSync可帮助安装、配置和监控嵌入式PXI目标上的同步。
    NI-TimeSync是一款驱动软件,可与PXI系统中的模块进行通信和同步。此软件可搭配PXI同步模块使用,用于对运行LabVIEW Real-Time模块的PXI控制器进行同步。该软件可以使用LabVIEW Real-Time模块的日期和时间对PXI控制器进行同步,同时包含基于与系统时间交互的API。此外,NI-TimeSync还提供LabVIEW范例,说明如何使用同步的绝对时间来协调多个实时目标或PXI机箱。NI-TimeSync支持通用和实时操作系统,包括Windows、Windows Server、NI Linux Real-Time、VxWorks和PharLap ETS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    1.3
    (MD5)
    ddac9376ad90e8851c057203a252d3aa(官方)
    我方文件校验和:
    文件大小: 408433480 字节 (389.51 MB)
    修改日期: 2013-08-30 04:40
    MD5: b3a1e463b7fdf8408c009140cf92b86c(重复一致,可秒传)
    SHA1: 5a38cbd6db4733791993d90c02f7d12f6bcc612c
    SHA256: 682cb2945f601dc26abd66831db80a042771cda0fadb841dcb9c1a595a19e6a5
    CRC32: 31d258ef
    NITS1.3.0.txt (643 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-TimeSync 1.3 Readme
    June 2013
    ContentsSystem Requirements
    Known Issues and Bug Fixes
    Updates and Notifications
    Windows XP Support Information
    Important Information
    • Windows XP Service Pack 3
    • Windows Vista x86, x64
    • Windows 7 x86, x64
    • Windows 8 x86, x64
    • LabVIEW 2013/2012/2011/2010
    • LabVIEW Real-Time Module 2013/2012/2011/2010
    For a list of Known Issues of NI-TimeSync 1.3, visit ni.com/info and enter the Info Code NITimeSync13KnownIssues.
    For a list of Bug Fixes for NI-TimeSync, visit ni.com/info and enter the Info Code NITimeSyncFixList.
    NI-TimeSync Updates and Notifications
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI-TimeSync Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-TimeSync will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-TimeSync that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    ©2013 National Instruments. All rights reserved.
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    GMT+8, 2025-11-19 12:46
