查看: 1890|回复: 2
[MVTEC] MVTEC Halcon 20.11.0.0 Progress Deep Learning (aarch64-linux, armv7a-linux) HALCON20.11.0.0进阶版深度学习 aarch64-linux/armv7a-linux系统
  • 签到天数: 3586 天
    连续签到: 6 天
    发表于 2020-11-25 11:08:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HALCON 20.11.0.0 Deep Learning (aarch64-linux, armv7a-linux), Add-on to Full/Runtime Version:
    文件名: halcon-20.11.0.0-linux-deep-learning.tar.gz
    文件大小: 3700159258 字节 (3.45 GB)
    修改日期: 2020-11-23 13:40
    MD5: f73dea53ff67154dd7eb73c1c9e3f187
    SHA1: 407a48d06f5b2b1ce1fe300268cf0dd21469150e
    SHA256: 0ae1809ed3bf1427ce27772ed6cfcbfa0957eb39da1200670f58dd3138bd010c
    CRC32: f5d63107
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码: ridx
    大恒提供下载:
    Contents
      • DotCode Reader
      • Deep OCR
      • HALCON/Python
      • HDevelop Facelift
      • Pruning for Deep Learning
    • Compatibility
      • Licenses
      • HALCON Library
      • HALCON Applications
      • Digital I/O Interfaces
      • Extension Packages
    • Supported Operating Systems
      • HDevelop
        • New Functionality
        • Bug Fixes
        • HDevelop Example Programs
      • HDevEngine
        • Functionality
        • Bug Fixes
      • HALCON Library
        • Speedup
        • New Functionality
        • Bug Fixes
      • Procedures
      • HALCON/C++
      • HALCON/.NET
      • HALCON/PYTHON
      • HBench
      • Documentation
      • Installation
      • Licensing
    DotCode Reader
    Deep OCR
    HALCON/Python
    HDevelop Facelift
      More information.
    Linux
    macOS
    HDevelopNew FunctionalityGUI
    Procedures
    Miscellaneous
    Bug FixesAssistants
    Code Export
    GUI
    Help
    IDE
    Procedures
      • read_dl_dataset_anomaly
    Miscellaneous
    New Functionality
    HDevEngineFunctionality
    HALCON LibrarySpeedup
    New Functionality3D
    Bar Code
    Calibration
    Data Code
      • 12 x [64, 88]
      • 16 x 64
      • 20 x [36, 44, 64]
      • 22 x 48
      • 24 x [48, 64]
      • 26 x [40, 48, 64]
    Deep Learning
      • create_dl_pruning
      • add_dl_pruning_batch
      • gen_dl_pruned_model
      • set_dl_pruning_param
      • get_dl_pruning_param
      as well as a new procedure:
      • prune_dl_model
      • ArgMax
      • Clip
      • ReduceMax
      • Resize
      • Sigmoid
      • query_available_dl_devices
      • get_dl_device_param
    Graphics
    Matching
    Miscellaneous
    OCR
      • apply_deep_ocr
      • create_deep_ocr
      • get_deep_ocr_param
      • read_deep_ocr
      • set_deep_ocr_param
      • write_deep_ocr
    Region
    Segmentation
    Bug Fixes3D
    Bar Code
    Classification
    Data Code
    Deep Learning
    Feature
    File
    Filter
    Graphics
    Inspection
    Images
    Matching
    Measure
    Miscellaneous
    OCR
    Region
    Segmentation
    System
    XLD
    ProceduresBug Fixes
    HALCON/C++Functionality
    HALCON/.NETFunctionality
    HALCON/PYTHONFunctionality
    HBenchBug Fixes
    DocumentationUser Guides
    Solution Guides
    Reference Manual
    Installation
    Licensing
  • 签到天数: 1 天
    发表于 2020-12-16 09:14:55 | 显示全部楼层 来自:浙江省杭州市 电信
    halcon-Progress-20.11.0.0-linux-deep-learning.tar.gz
  • 签到天数: 2 天
    发表于 2021-1-9 13:13:32 | 显示全部楼层 来自:广东省东莞市 电信
    做机器视觉实验,就到机器视觉论坛http://visionbbs.com,石鑫华视觉网http://shixinhua.com免费提供实验及解决方案
    GMT+8, 2025-7-6 22:06
