查看: 3946|回复: 0
[LV工具模块] NI ECU Measurement and Calibration Toolkit 2.1.2 Win32Eng NI电子控制单元测量和校准工具包ECUMC2.1.2下载
    昨天 16:26
  • 签到天数: 3674 天
    发表于 2020-11-22 22:37:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    ECU测量和校准工具包
    ECU测量和校准(ECUMC)工具包用于为电子控制单元(ECU)设计和验证提供测量和校准。
    ECU测量和校准工具包是LabVIEW、LabWindows/CVI和Microsoft C/C ++编程环境的软件附件。该软件支持通用测量和校准协议(Universal Measurement and Calibration Protocol,XCP)及CAN校准协议(CAN Calibration Protocol,CCP),提供了许多高级且易用的函数。这些协议可让用户可根据ASAM (.A2L)数据库文件的定义,读写内部ECU变量及特性。通过(.A2L)数据库文件,工具包自动应用所有换算信息并以工程单位返回数据,便于简单地分析、演示及记录。此外,该工具包还提供了常见应用的示例,例如使用一维到三维用户界面来测量ECU变量或控制ECU特性。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    2.1.2(在NI官网还有2.1版本,但是我方未能找到相关资源,无法提供下载)
    文件大小: 215555104 字节 (205.57 MB)
    修改日期: 2010-04-25 05:59
    MD5: f347e6c52d0525f460fd9e04e67b9eb2(可秒传一致)
    SHA1: a23344c6b6aa7b4cd356c0d50348efcf3f73e9c0
    SHA256: 5d7ba4527bc2e7d7100fb43f5dce4153c853c8645b1075bfcb7f030dbf9694bf
    CRC32: b6a2d935
    ECUMC2.1.2.txt (603 Bytes, 下载次数: 0, 售价: 10 圆)
    ECU Measurement and Calibration Toolkit (ECU M&C) 2.1.2 Readme
    October 2008
    Thank you for using National Instruments products.
    For more information about this product, refer to ni.com/support.
    This file contains information about the ECU Measurement and Calibration Toolkit (ECU M&C) Software for Windows Vista/XP/2000 and LabVIEW™ Real-Time (RT). Information in this file is in the following sections:
    Installation
    Installing the ECU Measurement and Calibration Toolkit with a LabWindows/CVI Upgrade
    Supported Software and Hardware
    ECU Simulator
    Using LabVIEW Real-Time (RT)
    New Features Compared to ECU M&C Toolkit 1.0
    New Features Compared to ECU M&C Toolkit 2.0
    New Features Compared to ECU M&C Toolkit 2.1
    Additional Programming Topics and Known Issues
    The ECU Measurement and Calibration Toolkit User Manual is the primary reference document. This manual includes an introduction to the CAN Calibration Protocol (CCP) and Measurement and Calibration Protocol (XCP). It also explains how to get started with application development and includes a complete reference for all ECU M&C Toolkit functions.
    The ECU Measurement and Calibration Toolkit User Manual is in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at www.adobe.com.
    You can open the ECU Measurement and Calibration Toolkit User Manual from Start» Programs»National Instruments»ECU Measurement and Calibration Toolkit Manual.
    Links to the NI-CAN Hardware and Software Manual are in the online help for each NI-CAN function within the National Instruments LabVIEW and LabWindows™/CVI™ development environments.
    Online help for the NI-CAN features within Measurement & Automation Explorer (MAX) is in the MAX Help Topics menu. The MAX help topics for NI-CAN also include a link to the NI-CAN Hardware and Software Manual.
    Back to Top
    Installation
    Before installing the ECU M&C Toolkit software, log on as Administrator or as a user with Administrator privileges. The ECU M&C Toolkit software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the ECU M&C Toolkit software:
    • Insert the ECU M&C Toolkit software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your ECU M&C Toolkit Software CD.
    • The installation wizard guides you through the necessary steps to install the ECU M&C Toolkit software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Back to Top
    When you execute a LabWindows/CVI upgrade, and you have an ECU Measurement and Calibration Toolkit installed on your computer, the ECU Measurement and Calibration Toolkit will support the earlier LabWindows/CVI version.
    If you want to use the ECU Measurement and Calibration Toolkit in the new LabWindows/CVI version, complete the following steps:
    • Uninstall the ECU Measurement and Calibration Toolkit using the Windows Control Panel ("Add or Remove Programs" / "National Instruments Software" / "NI ECU Measurement and Calibration Toolkit").
    • Reinstall the ECU Measurement and Calibration Toolkit. The installation routine now recognizes the new LabWindows/CVI version and installs the support for the new LabWindows/CVI.
    Please note that the ECU Measurement and Calibration Toolkit is no longer supported in the earlier LabWindows/CVI version after you complete these steps.
    Back to Top
    This version of the ECU M&C Toolkit software supports only the following operating systems:
    • Windows XP (32-bit)
    • Windows 2000 Service Pack 3
    For more information about using National Instruments hardware and software products with Windows Vista, refer to ni.com/vista.
    National Instruments recommends using Service Pack 2 when using the USB-847x interfaces in hyperthread or multicore/CPU environments on Microsoft Windows XP.
    Back to Top
    This version of the ECU M&C Toolkit software supports all NI-CAN Hardware that NI-CAN 2.5.3 or higher supports on Windows and LabVIEW RT.
    The ECU M&C Toolkit software supports only National Instruments CAN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Note: PCMCIA-CAN and PCMCIA-CAN/2 interfaces are not supported on the 64-bit version of Windows Vista.
    Back to Top
    This version of the NI-CAN software supports the following development environments:
    • LabVIEW 7.1, 8.0, 8.5, and 8.6
    • LabVIEW Real-Time (RT) 7.1, 8.2, 8.5, and 8.6
    • LabWindows/CVI 7.1 and higher
    • Microsoft Visual C/C++ 6.0
    Back to Top
    ECU Simulator
    The ECU M&C Toolkit software simulates an ECU. All ECU M&C Toolkit examples are preconfigured to communicate with the ECU simulation using the ASAM 2MC CCPECU.A2L file if using CCP or the XCPECU.A2L file if using the XCP Slave Simulator.
    LabVIEW users using CCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \\Examples\ECU MC\CCPECU.LLB.
    LabVIEW users using XCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \\Examples\ECU MC\XCPECU.LLB.
    MS VC users using CCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \ECU Measurement and Calibration Toolkit\MS Visual C\CCPECU.
    MS VC users using XCP can find the ECU simulator, seed-key DLL, and corresponding A2L file at \ECU Measurement and Calibration Toolkit\MS Visual C\XCPECU.
    Back to Top
    To use the ECU M&C Toolkit on a LabVIEW RT system, you must download your ASAM 2MC database (*.A2L) file to the RT target. The LabVIEW Real-Time Engine running on the PXI LabVIEW Real-Time controller supports a File Transfer Protocol (FTP) server. You can access the LabVIEW RT target FTP server using any standard FTP utility for transferring files to and from the hard drive or CompactFlash. For further information about how to download your A2L file to the RT target, refer to LabVIEW Real-Time (RT) Configuration in the ECU Measurement and Calibration Toolkit User Manual.
    Back to Top
    The ECU M&C Toolkit 2.1 release adds the following features:
    • Support for Universal Measurement and Calibration Protocol (XCP) on CAN and Ethernet (TCP and UDP).
    • New property for Measurements and Characteristics: Comment.
    • New property for DAQ Lists: Samples Pending.
    Back to Top
    • Support for LabVIEW 8.2.0.
    • New MC DAQ List Initialize VI for LabVIEW and mcDAQListInitialize function for C define a DAQ list on a specific DAQ list number.
    • Support for the 32 and 64-bit versions of Windows Vista.
    • You now can write the X axis of a characteristic using the mcPropChar_X_Axis property.
    • You now can write the Y axis of a characteristic using the mcPropChar_Y_Axis property.
    • You can change the byte order of a characteristic from Intel to Motorola and vice versa using the mcPropChar_ByteOrder property.
    • You can change the byte order of a measurement from Intel to Motorola and vice versa using the mcPropMeas_ByteOrder property.
    • Support for NI USB-8473 (1-port, High-Speed CAN, USB interface) and NI USB-8473s (1-port, High-Speed CAN, USB interface with synchronization).
    Back to Top
    The ECU M&C Toolkit 2.1.1 release adds the following features:
    • Support for LabVIEW 8.5 and 8.6.
    • Support for LabWindows/CVI 8.5.
    • New set of functions to generate measurements without an A2L database (mcECUCreate, mcConversionCreate, mcEventCreate, and mcMeasurementCreate).
    • New read mode for DAQ List to acquire DAQ List data as timestamped value pairs.
    • You can activate address mapping if defined in an A2L database using the mcPropECU_MappingMode property.
    • You can specify distinct mapping directions if defined in an A2L database using the mcPropECU_MappingSource and mcPropECU_MappingTarget properties.
    • You can deactivate the use of the CCP command EXCHANGE_ID, which is used by default when a connection to an ECU is initiated.
    • You can deactivate the use of all optional CCP commands such as GET_SEED, UNLOCK, DNLOAD_6, and more using the related properties mcPropOptCmd_xxx.
    Back to Top
    ECU M&C Toolkit 2.1 supports CCP Version 2.1.
    ECU M&C Toolkit 2.1 does not support symbolic conversion tables for characteristics and measurement channels.
    NI-Spy monitors function calls to the ECU M&C Toolkit API. This tool helps in debugging programming problems in the application. To launch this tool, open the Software branch of the MAX Configuration tree, right-click NI Spy, and select Launch NI Spy. If more than one National Instruments driver is installed on your computer, you can specify which APIs to spy on at any time. By default, all installed APIs are enabled. To select the APIs to spy on, select Spy»Options, select the View Selections tab, and select the APIs under Installed API Choices.
    The following LabVIEW example VIs do not run under LabVIEW Real-Time and LabVIEW Base Development System:
    • Edit a characteristic.vi
    • Measurement and Calibration Application.vi
    To make these examples run, remove the subVI call from 3DDisplayWrapper.vi in MCCharacteristicsEditors.llb.
    If you are using an NI USB-8473 or NI USB-8473s, the ECU M&C Toolkit is based internally on the NI-CAN Frame API. For this reason, the following properties are not available for the GetProperty function:
    • CRO Task (mcPropCRODAQ_DTO_Task)
    • DTO Task (mcPropDAQ_DTO_Task)
    • SamplesPending (mcPropDAQ_SamplesPending)
    Back to Top
    The following items are the IDs and titles of a subset of issues fixed between ECU M&C Toolkit 2.1.0 and ECU M&C Toolkit 2.1.2.
    If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the ECU M&C Toolkit.
    Bug IDFixed Issue
    105783Fixed the issue that the XCP Spy does not analyze the byte order.
    105788Fixed the issue that a XCP DAQ Lists does not work correctly if GET_DAQ_PROCESSOR_INFO is not implemented in the ECU.
    Back to Top
    © 2005–2008 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-8 00:15
