查看: 2778|回复: 0
[NI驱动程序] NI-USRP 20.0 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序20.0下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-11-16 23:38:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    20.0.0
    文件大小: 4721844224 字节 (4.40 GB)
    修改日期: 2020-05-19 04:33
    MD5: 84f22d7cf0b9c7595eff5b61a182a71f(重复下载一致)
    SHA1: 153e04833c80d429c913bcd4697dab3ca2bafdb1
    SHA256: 916f398b875a5ae08f6e5ed831fb7c0b8b283e40277981d392f088089f30683f
    CRC32: cacdfd42
    USRP20.0.txt (628 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-USRP 20.0 Readme
    May 2020
    This file contains important information about NI-USRP, including system requirements, installation instructions, and new features.
    Finding Examples, Lessons, and Sample Projects
    LabVIEW NXG Support and Considerations
    NI-USRP Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    This software installation provides support for customers using software defined radio (USRP) devices, software defined radio reconfigurable (USRP RIO) devices, and software defined radio stand-alone (USRP Stand-Alone) devices, as specified in the Supported Hardware section. To program your USRP, USRP RIO, or USRP Stand-Alone device, use the NI-USRP API or USRP RIO Instrument Design Library (IDL) included in the NI-USRP instrument driver.
    The getting started guide for your device provides information about how to install, configure, test, and begin using a USRP, USRP RIO, or USRP Stand-Alone device.
    NI-USRP 20.0 has the following requirements:
    • Connector requirements shown in the following table
    Device
    USB 2.0 or Higher
    Gigabit Ethernet
    PCI/MXI Express x4
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/2932
    USRP-2940/2942/2943/2944/2945
    USRP-2950/2952/2953/2954/2955
    USRP-2974
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    Ethernet Support on USRP RIO Devices
    USRP RIO devices support both 1G Ethernet (1 GbE) and 10G Ethernet (10 GbE) using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G. Users programming with LabVIEW, LabVIEW NXG, or LabVIEW Communications System Design Suite can use Ethernet.
    The USRP-2974 is only supported through Ethernet using 1 GbE through RJ45 and 10 GbE through SFP+ connections.
    Note  The FPGA cannot be modified when the USRP RIO device is connected through Ethernet.
    Note  Refer to NI-USRP Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    NI-USRP 20.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install this security update.
    Note  NI-USRP 20.0 does not support Windows Server non-R2 editions.
    Note  In 2016, NI-USRP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-USRP 20.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-USRP 20.0 to an unsupported OS. Additionally, after installing NI-USRP 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-USRP 20.0 supports the following application software versions, including service packs. If you are using LabVIEW, you should install it before installing NI-USRP. To add support for application software installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    Device
    LabVIEW 2017, 2018, 2019, or 2020
    LabVIEW Communications System Design Suite 5.0
    LabVIEW NXG 5.0
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/2932
    USRP-2940/2942/2943/2944à
    USRP-2950/2952/2953/2954à
    USRP-2945/2955
    USRP-2974
    † Support for the USRP RIO API and modifying the LV FPGA bitfile is only supported in LabVIEW NXG FPGA Module.
    Installation InstructionsInstalling NI-USRP for LabVIEW, LabVIEW NXG, or LabVIEW Communications System Design Suite
    NI automates LabVIEW NXG and LabVIEW Communications System Design Suite installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    NI-USRP 20.0 includes the following new features:
    • Support for LabVIEW 2020
    • Support for LabVIEW NXG 5.0 and LabVIEW Communications System Design Suite 5.0
    NI-USRP 19.5 includes the following new features:
    • Aurora Streaming and 10 Gb Ethernet Sample Projects for LabVIEW 2019
    • Support for LabVIEW NXG 4.0 and LabVIEW Communications System Design Suite 4.0
    NI-USRP 19.1 includes support for a bug fix.
    NI-USRP 19.0 includes the following new features:
    • Support for LabVIEW 2019
    • Support for LabVIEW NXG 3.1
    • High Speed Serial (HSS) support in LabVIEW NXG
    NI-USRP 18.5 adds support for LabVIEW NXG 3.0 and LabVIEW Communications System Design Suite 3.0.
    NI-USRP 18.3 adds support for the USRP-2974 device with LabVIEW Communications System Design Suite 2.1.
    NI-USRP 18.1 adds support for LabVIEW NXG 2.1 and LabVIEW Communications System Design Suite 2.1.
    NI-USRP 18.0 adds support for LabVIEW 2018 (32- and 64-bit).
    NI-USRP 17.2 adds support for the USRP-2974 device with LabVIEW Communications System Design Suite 2.0.
    NI-USRP 17.1 adds support for several bug fixes.
    NI-USRP 17.0 adds support for LabVIEW 2017 (32- and 64-bit).
    The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions.
    • USRP-2900
    • USRP-2901
    • USRP-2920
    • USRP-2921
    • USRP-2922
    • USRP-2930
    • USRP-2932
    • USRP-2940 40 MHz
    • USRP-2940 120 MHz
    • USRP-2942 40 MHz
    • USRP-2942 120 MHz
    • USRP-2943 40 MHz
    • USRP-2943 120 MHz
    • USRP-2944
    • USRP-2945
    • USRP-2950 40 MHz
    • USRP-2950 120 MHz
    • USRP-2952 40 MHz
    • USRP-2952 120 MHz
    • USRP-2953 40 MHz
    • USRP-2953 120 MHz
    • USRP-2954
    • USRP-2955
    • USRP-2974
    • Ettus Research USRP2*
    • Ettus Research N200*
    • Ettus Research N210*
    • Ettus Research X300*
    • Ettus Research X310*
    *The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450
    daughterboards. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    The following are the behavior changes in NI-USRP 18.5 from NI-USRP 18.0:
    • The SDR Basic Elements IDL is obsolete in instrument driver version 18.5.
    You can access the NI-USRP known issues online at NI-USRP 20.0 Known Issues.
    You can access the NI-USRP bug fixes online at NI-USRP 20.0 Bug Fixes. This list describes a subset of issues fixed in the NI-USRP 20.0. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Documentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation and online at ni.com/manuals. The documentation set is composed of the following documents.
    Document
    Format
    Location
    Description
    NI-USRP 20.0 ReadmeHTML (this document)Start»All Programs»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manualsContains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-USRP HelpHTML/Windows HelpStart»All Programs»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manualsThe primary document for most USRP products used in LabVIEW. The help is an installed and online version of a traditional user manual that includes the following information:
    • An introduction to USRP
    • A complete programming reference for all NI-USRP programming functions and VIs in LabVIEW
    NI-USRP ManualOnline HelpOnline at ni.com/manualsThe primary document for most USRP products. The help is an installed and online version of a traditional user manual that includes the following information:
    • A complete programming reference for all NI-USRP nodes in LabVIEW NXG and LabVIEW Communications System Design Suite
    Basic Elements (NI-USRP and NI-579x) ManualOnline HelpOnline at ni.com/manualsContains a complete programming reference for all Basic Elements nodes on the USRP RIO and NI-579x palettes in LabVIEW NXG and LabVIEW Communications System Design Suite.
    Getting started guide for your devicePrinted and PDFOnline at ni.com/manualsContains software and hardware installation, configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePDFOnline at ni.com/manualsLists technical specifications for your device.
    Manual for your deviceOnline HelpOnline at ni.com/manualsContains information about supported hardware, including pinouts, block diagrams, and specifications.
    To access the latest LabVIEW Communications System Design Suite Manual, visit ni.com/info and enter the Info Code commsmanual. This manual includes an introduction to LabVIEW Communications System Design Suite and information about how to get started with application development.
    LabVIEW NXG and LabVIEW Communications System Design Suite Help
    View context help by pressing and hovering over an object.
    Search for items using the search bar in the upper right corner of the window. You can also view context help for the search results.
    NI-USRP examples, lessons, and sample projects are available in the following locations.
    Content Type
    Description
    LabVIEW NXG or LabVIEW Communications System Design Suite
    ExamplesNI-USRP includes several example applications that serve as interactive tools, programming models, and building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality.
    Note  You can access additional examples from the Code Sharing Community at ni.com/usrp.
    • From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    • From the Learning tab, select Examples»Hardware Input and Output»NI-USRP.
    • From the Learning tab, select Examples»Hardware Input and Output»NI-USRP RIO.
    LessonsNI-USRP includes lessons that guide you through the process of identifying and demodulating an FM signal with your device.N/AFrom the Learning tab, select Lessons»Getting Started»Demodulating FM Signals with the NI... and choose a task to accomplish.
    Sample ProjectsUSRP RIO includes several sample projects that serve as starting points to build a USRP RIO streaming application.From the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project.From the Projects tab, select USRP RIO and choose the applicable sample project for your device and setup.
    The following sections detail considerations for using LabVIEW NXG 5.0 with NI-USRP 20.0.
    LabVIEW NXG Hardware Support
    All hardware listed in the Supported Hardware section is supported in LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    Refer to the Finding Examples, Lessons, and Sample Projects section to locate LabVIEW NXG Examples.
    NI-USRP will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2011–2020 National Instruments Corporation. All rights reserved.
    374760X-01
    GMT+8, 2025-11-19 12:47
