查看: 2484|回复: 0
[NI驱动程序] NI-USRP 19.1 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序19.1下载
    5 小时前
  • 签到天数: 3556 天
    发表于 2020-11-16 23:30:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    19.1
    文件大小: 4498581504 字节 (4.19 GB)
    修改日期: 2019-06-27 04:49
    MD5: f8c7a6041b19acd10470a91439300e51(官方正确)
    SHA1: 2ee2c3efbd184f372a307e473a58d79af00e1c2b
    SHA256: d9942f18160ccf22f8a4951e5b4839888ebdde5a64e26c7f6fd2c2de102d921c
    CRC32: 4b56813b
    USRP19.1.txt (618 Bytes, 下载次数: 0, 售价: 10 元)
    NI-USRP 19.1 Readme
    June 2019
    This file contains important information about NI-USRP, including installation instructions, new features, a partial list of bugs fixed for NI-USRP 19.1, and known issues.
    Finding Examples, Lessons, and Sample Projects
    Installed Software
    This software installation provides support for customers using software defined radio (USRP) devices, software defined radio reconfigurable (USRP RIO) devices, and software defined radio stand-alone (USRP Stand-Alone) devices, as specified in the Supported Hardware section. To program your USRP, USRP RIO, or USRP Stand-Alone device, use the NI-USRP API or USRP RIO Instrument Design Library (IDL) included in the NI-USRP instrument driver.
    The getting started guide for your device provides information about how to install, configure, test, and begin using a USRP, USRP RIO, or USRP Stand-Alone device.
    NI-USRP 19.1 includes support for a bug fix.
    NI-USRP 19.0 includes the following new features:
    • Support for LabVIEW 2019
    • Support for LabVIEW NXG 3.1
    • High Speed Serial (HSS) support in LabVIEW NXG
    NI-USRP 18.5 adds support for LabVIEW NXG 3.0 and LabVIEW Communications System Design Suite 3.0.
    NI-USRP 18.3 adds support for the USRP-2974 device with LabVIEW Communications System Design Suite 2.1.
    NI-USRP 18.1 adds support for LabVIEW NXG 2.1 and LabVIEW Communications System Design Suite 2.1.
    NI-USRP 18.0 adds support for LabVIEW 2018 (32- and 64-bit).
    NI-USRP 17.2 adds support for the USRP-2974 device with LabVIEW Communications System Design Suite 2.0.
    NI-USRP 17.1 adds support for several bug fixes.
    NI-USRP 17.0 adds support for LabVIEW 2017 (32- and 64-bit).
    NI-USRP 16.1 includes the following new features:
    • Support for USRP-2945 and USRP-2955 devices with LabVIEW 2016
    • Support for USRP-2900 and USRP-2901 devices with LabVIEW 2016
    NI-USRP 16.0 adds support for LabVIEW 2016 (32- and 64-bit).
    The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions.
    • USRP-2900
    • USRP-2901
    • USRP-2920
    • USRP-2921
    • USRP-2922
    • USRP-2930
    • USRP-2932
    • USRP-2940 40 MHz
    • USRP-2940 120 MHz
    • USRP-2942 40 MHz
    • USRP-2942 120 MHz
    • USRP-2943 40 MHz
    • USRP-2943 120 MHz
    • USRP-2944
    • USRP-2945
    • USRP-2950 40 MHz
    • USRP-2950 120 MHz
    • USRP-2952 40 MHz
    • USRP-2952 120 MHz
    • USRP-2953 40 MHz
    • USRP-2953 120 MHz
    • USRP-2954
    • USRP-2955
    • USRP-2974
    • Ettus Research USRP2*
    • Ettus Research N200*
    • Ettus Research N210*
    • Ettus Research X300*
    • Ettus Research X310*
    *The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450
    daughterboards. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    NI-USRP 19.1 has the following requirements:
      Note  LabVIEW NXG and LabVIEW Communications System Design Suite support only 64-bit (x64) processors.
    • Connector requirements shown in the following table
    Device
    USB 2.0 or Higher
    Gigabit Ethernet
    PCI/MXI Express x4
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/2932
    USRP-2940/2942/2943/2944/2945
    USRP-2950/2952/2953/2954/2955
    USRP-2974
    Ethernet Support on USRP RIO Devices
    USRP RIO devices support both 1G Ethernet (1 GbE) and 10G Ethernet (10 GbE) using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G.
    The USRP-2974 is only supported through Ethernet using 1 GbE through RJ45 and 10 GbE through SFP+ connections.
    Note  The FPGA cannot be modified when the USRP RIO device is connected through Ethernet.
    NI-USRP 19.1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  LabVIEW NXG and LabVIEW Communications System Design Suite support only 64-bit operating systems.
    Note  NI-USRP 19.1 does not support Windows Server non-R2 editions.
    Note  In 2016, NI-USRP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-USRP 19.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-USRP 19.1 to an unsupported OS. Additionally, after installing NI-USRP 19.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-USRP 19.1 supports the following application software versions, including service packs. If you are using LabVIEW, you should install it before installing NI-USRP. To add support for application software installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
    Device
    LabVIEW 2016, 2017, 2018, or 2019
    LabVIEW Communications System Design Suite 3.1
    LabVIEW NXG 3.1
    USRP-2900/2901
    USRP-2920/2921/2922
    USRP-2930/2932
    USRP-2940/2942/2943/2944à
    USRP-2950/2952/2953/2954à
    USRP-2945/2955
    USRP-2974
    † Support for the USRP RIO API and modifying the LV FPGA bitfile is only supported in LabVIEW NXG FPGA Module.
    NI-USRP and USRP RIO palette VIs and nodes are available in the following palette locations.
    API
    LabVIEW NXG or LabVIEW Communications System Design Suite
    NI-USRPFunctions»Instrument I/O»Instrument Drivers»NI-USRPHardware Interfaces»Wireless Design and Test»NI-USRP
    USRP RIOFunctions»Instrument I/O»Instrument Drivers»USRP RIOHardware Interfaces»Wireless Design and Test»USRP RIO
    NI-USRP examples, lessons, and sample projects are available in the following locations.
    Content Type
    Description
    ExamplesNI-USRP includes several example applications that serve as interactive tools, programming models, and building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality.
    Note  You can access additional examples from the Code Sharing Community at ni.com/usrp.
    • From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
    • From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
    • From the Learning tab, select Examples»Hardware Input and Output»NI-USRP.
    • From the Learning tab, select Examples»Hardware Input and Output»NI-USRP RIO.
    LessonsNI-USRP includes lessons that guide you through the process of identifying and demodulating an FM signal with your device.N/AFrom the Learning tab, select Lessons»Getting Started»Demodulating FM Signals with the NI... and choose a task to accomplish.
    Sample ProjectsUSRP RIO includes several sample projects that serve as starting points to build a USRP RIO streaming application.From the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project.From the Projects tab, select USRP RIO and choose the applicable sample project for your device and setup.
    Documentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation and online at ni.com/manuals. The documentation set is composed of the following documents.
    Document
    Format
    Location
    Description
    NI-USRP 19.1 ReadmeHTML (this document)Start»All Programs»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manualsContains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-USRP HelpHTML/Windows HelpStart»All Programs»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manualsThe primary document for most NI-USRP products used in LabVIEW. The help is an installed and online version of a traditional user manual that includes the following information:
    • An introduction to NI USRP
    • A complete programming reference for all NI-USRP programming functions and VIs in LabVIEW
    NI-USRP ManualOnline HelpOnline at ni.com/manualsThe primary document for most NI-USRP products. The help is an installed and online version of a traditional user manual that includes the following information:
    • A complete programming reference for all NI-USRP nodes in LabVIEW NXG and LabVIEW Communications System Design Suite
    Basic Elements (NI-USRP and NI-579x) ManualOnline HelpOnline at ni.com/manualsContains a complete programming reference for all Basic Elements nodes on the USRP RIO and NI-579x palettes in LabVIEW NXG and LabVIEW Communications System Design Suite.
    Getting started guide for your devicePrinted and PDFOnline at ni.com/manualsContains software and hardware installation, configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePDFOnline at ni.com/manualsLists technical specifications for your device.
    Manual for your deviceOnline HelpOnline at ni.com/manualsContains information about supported hardware, including pinouts, block diagrams, and specifications.
    To access the latest LabVIEW Communications System Design Suite Manual, visit ni.com/info and enter the Info Code commsmanual. This manual includes an introduction to LabVIEW Communications System Design Suite and information about how to get started with application development.
    LabVIEW NXG and LabVIEW Communications System Design Suite Help
    View context help by pressing and hovering over an object.
    Search for items using the search bar in the upper right corner of the window. You can also view context help for the search results.
    Installed Software
    • is an alias for the following file folder location: (64-bit) Windows\system32
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Utilities\NI-USRP\utilities\
    NI-USRP Examples\LabVIEW\examples\instr\niUSRP\
    NI-USRP Header files\Shared\ExternalCompilerSupport\C\include
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib32\msvc
    NI-USRP Firmware and FPGA images\NI-USRP\images\
    Additional File Locations for Windows (64-bit)
    Item
    Installed Location
    NI-USRP\NI-USRP\
    NI-USRP Import Library files\Shared\ExternalCompilerSupport\C\lib64\msvc
    Installation InstructionsInstalling NI-USRP for LabVIEW, LabVIEW NXG, or LabVIEW Communications System Design Suite
    NI automates LabVIEW NXG and LabVIEW Communications System Design Suite installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The following are the behavior changes in NI-USRP 18.5 from NI-USRP 18.0:
    • The SDR Basic Elements IDL is obsolete in instrument driver version 18.5.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code usrp191knownissues for an up-to-date list of known issues in NI-USRP 19.1.
    The following item is a change in NI-USRP 19.1 from NI-USRP 19.0.
    ID
    Fixed Issue
    170434Fixed an issue that caused some users of the NI-USRP Simple Streaming with USRP-2945/2955 Sample Project to receive an error stating that their hardware is too new for this version of the Configuration Instrument Design Library.
    There are no changes in NI-USRP 19.0 from NI-USRP 18.5.
    There are no changes in NI-USRP 18.5 from NI-USRP 18.3.
    There are no changes in NI-USRP 18.3 from NI-USRP 18.1.
    There are no changes in NI-USRP 18.1 from NI-USRP 18.0.
    There are no changes in NI-USRP 18.0 from NI-USRP 17.2.
    There are no changes in NI-USRP 17.2 from NI-USRP 17.1.
    The following items are changes in NI-USRP 17.1 from NI-USRP 17.0.
    ID
    Fixed Issue
    679121Fixed an issue that caused digital data values in the NI-USRP Simple Streaming with USRP-2945/2955 Sample Project to be scaled to half of the correct value.
    681935Fixed an issue that caused aliases to appear in the data path after the frequency shift occurred on the FPGA.
    The following items are changes in NI-USRP 17.0 from NI-USRP 16.1.
    ID
    Fixed Issue
    641880Fixed an issue that caused the RF frequency to be inaccurate due to LO sharing when using the USRP-2945/2955 and the USRP RIO sample project.
    624459Fixed an issue that caused the building of a bitfile to fail using DRAM in LabVIEW Communications 2.0 after installing NI-USRP.
    617872Fixed an issue that caused the streaming performance of USRP RIO devices to degrade when connected over PCIe and using NI-USRP API.
    The following items are changes in NI-USRP 16.1 from NI-USRP 16.0.
    ID
    Fixed Issue
    597196Fixed an issue that caused errors to appear when launching the NI-USRP Configuration Utility from LabVIEW Communications 2.0.
    494050Fixed an issue that caused the USRP-2950/2952/2953/2954 devices not to set the GPS time by default.
    © 2011–2019 National Instruments. All rights reserved.
    374760V-01
    GMT+8, 2025-6-3 13:35
