NI-USRP 17.2 Driver Win32/64Eng NI通用软件无线电外设仪器驱动程序17.2下载
NI USRP
NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
17.2
文件大小: 3228101888 字节 (3.01 GB)
修改日期: 2018-05-18 01:51
版本: 18.1.0.0
MD5: a8d34302042356cd26cf04715a8b160e(官方正确)
SHA1: ec23771d4db52ae53cc52fd37f04dd7257e001f4
SHA256: 75a9a2bb7283d356a1ba2bf488ae572e93a9791fa7bdeabc64c5e930015f81c2
CRC32: 8c6b1d4b
USRP17.2.txt
(583 Bytes, 下载次数: 0, 售价: 10 圆)
NI-USRP 17.2 ReadmeApril 2018
This file contains important information about NI-USRP, including installation instructions, new features, a partial list of bugs fixed for NI-USRP 17.2, and known issues.
Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installed Software, Documentation, and Examples Documentation Accessing VIs and Functions Finding Examples and Sample Projects Ethernet Support on USRP RIO Devices Product Security and Critical Updates Known Issues Bug Fixes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewThis software installation provides support for customers using software defined radio (USRP) devices and software defined radio reconfigurable (USRP RIO) devices, as specified in the Supported Hardware section. To program your USRP or USRP RIO device, use the NI-USRP API or USRP RIO Instrument Design Library (IDL) included in the NI-USRP instrument driver.
The getting started guide for your device provides information about how to install, configure, test, and begin using a USRP or USRP RIO device.
New FeaturesNI-USRP 17.2 adds support for the USRP-2974 device with LabVIEW Communications System Design Suite 2.0.
NI-USRP 17.1 adds support for several bug fixes.
NI-USRP 17.0 adds support for LabVIEW 2017 (32- and 64-bit).
NI-USRP 16.1 includes the following new features:
- Support for USRP-2945 and USRP-2955 devices with LabVIEW 2016
- Support for USRP-2900 and USRP-2901 devices with LabVIEW 2016
NI-USRP 16.0 adds support for LabVIEW 2016 (32- and 64-bit).
NI-USRP 15.5 includes the following new features:
- Support for USRP-2944 and USRP-2954 devices
NI-USRP 15.1 adds support for LabVIEW Communications 2.0.
NI-USRP 15.0 adds support for LabVIEW 2015 (32- and 64-bit).
Supported HardwareThe following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions.
- USRP-2900
- USRP-2901
- USRP-2920
- USRP-2921
- USRP-2922
- USRP-2930
- USRP-2932
- USRP-2940 40 MHz
- USRP-2940 120 MHz
- USRP-2942 40 MHz
- USRP-2942 120 MHz
- USRP-2943 40 MHz
- USRP-2943 120 MHz
- USRP-2944
- USRP-2945
- USRP-2950 40 MHz
- USRP-2950 120 MHz
- USRP-2952 40 MHz
- USRP-2952 120 MHz
- USRP-2953 40 MHz
- USRP-2953 120 MHz
- USRP-2954
- USRP-2955
- USRP-2974
- Ettus Research USRP2*
- Ettus Research N200*
- Ettus Research N210*
- Ettus Research X300*
- Ettus Research X310*
*The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450
daughterboards. Other daughterboards may also be compatible, but they have not been tested.
Device-specific information about these modules is included in the NI-USRP Help.
System RequirementsNI-USRP 17.2 has the following requirements:
- Processor—1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
- RAM—1 GB RAM (32-bit) or 2 GB RAM (64-bit)
- Windows 10/8.1/7, with all available critical updates and service packs
- Connector
- USB 2.0 or higher (USRP-2900/2901)
- Gigabit Ethernet (USRP-2920/2921/2922/2930/2932/2940/2942/2943/2944/2945/2950/2952/2953/2954/2955/2974)
- PCI/MXI Express x4 (USRP-2940/2942/2943/2944/2945/2950/2952/2953/2954/2955)
Supported Operating SystemsNI-USRP 17.2 supports the following operating systems:
- Windows 10/8.11/7 SP12
- Windows Embedded Standard 7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
Note NI-USRP 17.2 does not support Windows Server non-R2 editions.
Note In 2016, NI-USRP dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-USRP 17.2 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-USRP 17.2 to an unsupported OS. Additionally, after installing NI-USRP 17.2, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport.
Application Software SupportNI-USRP 17.2 supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabVIEW Communications System Design Software, or LabVIEW Communications System Design Suite, before installing NI-USRP. To add support for application software installed after installing NI-USRP, modify your NI-USRP installation or launch the NI-USRP installer again.
Device | LabVIEW 2014 SP1, 2015 SP1, 2016, or 2017 | LabVIEW Communications System Design Software 2.0 | LabVIEW Communications System Design Suite 2.0 | | USRP-2900/2901 | Yes | Yes | Yes | | USRP-2920/2921/2922 | Yes | Yes | Yes | | USRP-2930/2932 | Yes | Yes | Yes | | USRP-2940/2942/2943/2944 | Yes | No | Yes | | USRP-2950/2952/2953/2954 | Yes | No | Yes | | USRP-2945/2955 | Yes† | No | No | | USRP-2974 | No | No | Yes |
† The USRP-2945/2955 devices are supported only in LabVIEW 2016 and LabVIEW 2017.
Note NI-USRP is not supported in LabVIEW NXG 1.0 or later.
Installed Software, Documentation, and ExamplesInstalled Software- is an alias for the following National Instruments file folder location: Users\Public\Public Documents\National Instruments
- is an alias for the following file folder location: (64-bit) Windows\system32
- (32-bit OS) Program Files\National Instruments
- (64-bit OS) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
File LocationsItem | Installed Location | | NI-USRP | \NI-USRP\ | | NI-USRP Utilities | \NI-USRP\utilities\ | | NI-USRP Examples | \LabVIEW\examples\instr\niUSRP\ | | NI-USRP Header files | \Shared\ExternalCompilerSupport\C\include | | NI-USRP Import Library files | \Shared\ExternalCompilerSupport\C\lib32\msvc | | NI-USRP DLL | \niusrp.dll | | NI-USRP 2 DLL | \niusrp2.dll | | NI UHD DLL | \niuhd.dll | | NI UHD 2 DLL | \niuhd2.dll | | NI-USRP RIO DLL | \niusrprio.dll | | NI-USRP RIO RPC | \niusrpriorpc.exe | | NI-USRP USB Monitor | \niusrpmonitor.exe | | NI-USRP Firmware and FPGA images | \NI-USRP\images\ |
Additional File Locations for Windows (64-bit)Item | Installed Location | | NI-USRP | \NI-USRP\ | | NI-USRP Header files | \Shared\ExternalCompilerSupport\C\include | | NI-USRP Import Library files | \Shared\ExternalCompilerSupport\C\lib64\msvc | | NI-USRP DLL | \niusrp.dll | | NI-USRP 2 DLL | \niusrp2.dll | | NI UHD DLL | \niuhd.dll | | NI UHD 2 DLL | \niuhd2.dll | | NI-USRP RIO DLL | \niusrprio.dll | | NI-USRP Examples | \LabVIEW\examples\instr.lib\niUSRP\ |
DocumentationDocumentation for NI-USRP is located at Start»All Programs»National Instruments»NI-USRP»Documentation. The documentation set is composed of the following documents.
Document | Format | Description | | NI-USRP Help | HTML/Windows Help | The primary document for most NI-USRP products. The help is an HTML version of a traditional user manual that includes the following information:- An introduction to NI USRP
- Hardware device information
- A complete reference for all NI-USRP programming functions and VIs
| | Getting Started Guide for your device | Printed and PDF | Contains software and hardware installation, configuration, signal connection, and troubleshooting information for your device. | | Specifications for your device | PDF | Lists technical specifications for your device. | | NI-USRP 17.2 Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. |
To access the LabVIEW Communications System Design Suite 2.0 Manual, visit ni.com/info and enter the Info Code commsmanual. This manual includes the following information:
- An introduction to LabVIEW Comms
- Hardware device overviews
- Information about how to get started with application development
- A complete programming reference for all NI-USRP nodes
Note To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
Accessing VIs and FunctionsNI–USRP palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-USRP palette.
USRP RIO palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»USRP RIO palette.
Finding Examples and Sample ProjectsNI-USRP includes several example applications for LabVIEW. These examples serve as interactive tools, programming models, and as building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality. You can access the NI-USRP examples from the following locations:
- From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
- From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
Note The NI Example Finder does not include NI-USRP examples.
USRP RIO includes several sample projects for LabVIEW. These sample projects serve as starting points to build a USRP RIO streaming application. To access the LabVIEW sample project from the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project.
You can access additional examples from the Code Sharing Community at ni.com/usrp.
Ethernet Support on USRP RIO DevicesUSRP RIO devices support both 1G Ethernet and 10G Ethernet using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G.
The USRP-2974 is only supported through Ethernet using 1 GbE through RJ45 and 10 GbE through SFP+ connections.
Note The FPGA cannot be modified when the USRP RIO device is connected through Ethernet. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI.
Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-USRP 17.2.
Bug FixesThere are no changes in NI-USRP 17.2 from NI-USRP 17.1.
The following items are changes in NI-USRP 17.1 from NI-USRP 17.0.
ID | Fixed Issue | | 679121 | Fixed an issue that caused digital data values in the NI-USRP Simple Streaming with USRP-2945/2955 Sample Project to be scaled to half of the correct value. | | 681935 | Fixed an issue that caused aliases to appear in the data path after the frequency shift occurred on the FPGA. |
The following items are changes in NI-USRP 17.0 from NI-USRP 16.1.
ID | Fixed Issue | | 641880 | Fixed an issue that caused the RF frequency to be inaccurate due to LO sharing when using the USRP-2945/2955 and the USRP RIO sample project. | | 624459 | Fixed an issue that caused the building of a bitfile to fail using DRAM in LabVIEW Communications 2.0 after installing NI-USRP. | | 617872 | Fixed an issue that caused the streaming performance of USRP RIO devices to degrade when connected over PCIe and using NI-USRP API. |
The following items are changes in NI-USRP 16.1 from NI-USRP 16.0.
ID | Fixed Issue | | 597196 | Fixed an issue that caused errors to appear when launching the NI-USRP Configuration Utility from LabVIEW Communications 2.0. | | 494050 | Fixed an issue that caused the USRP-2950/2952/2953/2954 devices not to set the GPS time by default. |
There are no changes in NI-USRP 16.0 from NI-USRP 15.5.
The following items are changes in NI-USRP 15.5 from NI-USRP 15.1.
ID | Fixed Issue | | 544731 | Fixed an issue that caused Rx/Tx samples to be misaligned by 5 ns when synchronizing using the external PPS on a USRP RIO device. | | 519793 | Fixed an issue that caused two channel acquisitions (Rx) on a single USRP-2901 device to fail to align. | | 486961 | Fixed an issue that caused the niUSRP Find Devices VI to occasionally return incorrect information when a session is open to a USRP device. | | 466351 | Fixed an issue that caused "A stream command was issued in the past" or "Packet had timestamp that was late (or too early)" errors to occur with MIMO synchronization. |
There are no changes in NI-USRP 15.1 from NI-USRP 15.0.
The following items are changes in NI-USRP 15.0 from NI-USRP 14.5.1.
ID | Fixed Issue | | 544473 | Fixed an issue that caused the niUSRP Configure Frequency Shift VI to incorrectly negate the Tx shift when the scope was "all". | Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes.
- For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10.
Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
Legal InformationCopyright
© 2011–2018 National Instruments. All rights reserved.
- Notices are located in the \_Legal Information and directories.
374760M-01 |
