查看: 4180|回复: 0
[NI驱动程序] NI-USRP 1.1 Driver Win32Eng NI通用软件无线电外设仪器驱动程序1.1下载
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2020-11-16 22:43:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI USRP
    NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
    NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
    1.1
    文件大小: 37209936 字节 (35.49 MB)
    修改日期: 2012-05-11 00:15
    MD5: 5e1dba214c9f1b43a08b8e716095b5ed(官方正确)
    SHA1: 7ac0fabafd7fdd3f3586338bc3deb4727faaf178
    SHA256: 4d0b827d019969671d6e8a3fd86d4b8b2c1e44b852ba66a9ea3791195c7905c5
    CRC32: 949c2f07
    USRP1.1.txt (542 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-USRP Readme
    Version 1.1
    Thank you for using NI-USRP instrument driver software. This file contains important information about NI-USRP and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Updates and Notifications
    • Uninstalling/Modifying NI-USRP
    • Known Issues
    • Bug Fixes
    • Notice Regarding Microsoft Silverlight Installation and Redistribution
    • Important Information
    NI-USRP 1.1 includes the following features:
    • Support for the NI USRP-2922 device
    • Support for configuring 8-bit sample width for transferring data over the bus, which can increase streaming rates and allow higher I/Q rates
    • Support for fetching and writing binary data waveforms
    • Support for programmatically discovering devices in the system and their model information using the niUSRP Find Devices VI
    • Support for controlling multiple devices in a single session (for use in MIMO applications)
    • Support for locking the local oscillator (LO) to a user-specified frequency and controlling the carrier frequency independently using the digital signal processor (DSP)
    • Support for reconfiguring gain, carrier frequency, and active antenna while an acquisition or generation is in progress
    • API Changes:
      • VIs
        • niUSRP Fetch Rx Data (I16) VI
        • niUSRP Fetch Rx Data (2D CDB) VI
        • niUSRP Fetch Rx Data (2D I16) VI
        • niUSRP Write Tx Data (I16) VI
        • niUSRP Write Tx Data (2D CDB) VI
        • niUSRP Write Tx Data (2D I16) VI
        • niUSRP Find Devices VI
      • Properties
        • Number of Channels in Session property
        • Host Data Type property
        • Sample Width property
        • Expected Peak property
        • LO Frequency property
        • Warning Policy property
    • Compatible with Ettus Research USRP2, USRP N200, and USRP N210 devices using the following daughterboards:
      • SBX
      • LFTX
      • LFRX
      • BasicTX
      • BasicRX
    NI-USRP 1.0 includes the following features:
    • Support for NI USRP-292x devices
    • Support for LabVIEW 2011 (32-bit)/2010 (32-bit)/2009 (32-bit)
    • Support for Windows 7/Vista/XP
    • Interactive configuration utility to change device IP addresses and update firmware and FPGA images
    • Support for continuous and finite generation (Tx) and acquisition (Rx) operations
    • Full set of examples, including examples that use the NI LabVIEW Modulation Toolkit
    • Integration with NI LabVIEW Modulation Toolkit
    • Compatible with Ettus Research USRP2 and USRP N210 devices using the following daughterboards:
      • WBX
      • XCVR2450
    The following hardware products are supported under Windows 7 (32-bit and 64-bit1 versions)/Vista (32-bit and 64-bit1 versions)/XP operating systems.
    • NI USRP-2920
    • NI USRP-2921
    • NI USRP-2922
    • Ettus Research USRP22
    • Ettus Research N2002
    • Ettus Research N2102
    1 These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64).
    2 The NI-USRP instrument driver supports WBX, SBX, XCVR2450, LFTX, LFRX, BasicTX, and BasicRX daughterboards on this device. Other daughterboards may also be compatible, but they have not been tested.
    Device-specific information about these modules is included in the NI-USRP Help.
    Note  You must update the firmware and FPGA images on your USRP module prior to using NI-USRP 1.1. Refer to the NI USRP-292x Getting Started Guide for more information about updating the firmware and FPGA images.
    NI-USRP 1.1 and later supports the following operating systems:
    • Windows XP Service Pack 2 (32-bit)
    It is recommended that you have the most recent service pack for your operating system installed.
    Minimum System Requirements
    • RAM—
      • Windows XP: 1 GB
      • Windows 7/Windows Vista: 1 GB
    • Gigabit Ethernet interface
    • Windows 7/Vista/XP with all available critical updates and service packs
    Recommended System
    • Processor—Core II Duo or equivalent
    • RAM—
      • Windows XP: 2 GB
      • Windows 7/Vista: 2 GB
    • Dedicated gigabit Ethernet interface for each device
    Application Development Environment (ADE)
    • LabVIEW 2009 SP1 (32-bit), 2010 SP1 (32-bit), 2011 SP1 (32-bit)
      • Windows 7 (32-bit)/Vista (32-bit)/Windows XP: Program Files\National Instruments\
      • Windows 7 (64-bit)3/Vista (64-bit)3: Program Files (x86)\National Instruments\
      • Windows 7 (32-bit)/Vista (32-bit)/Windows XP: Windows\System32
      • Windows 7 (64-bit)3/Vista (64-bit)3: Windows\syswow64
    3 These software versions run within the 32-bit emulation layer, Windows on Windows (WOW64).
    ItemInstalled Location
    NI-USRP\NI-USRP\
    NI-USRP Utilities\NI-USRP\utilities\
    NI-USRP Examples\LabVIEW\examples\instr\niUSRP\
    NI-USRP Header files\NI-USRP\includes\
    NI-USRP Import Library files\NI-USRP\lib\msc\
    NI-USRP DLL\niusrp.dll
    NI-USRP Firmware and FPGA images\NI-USRP\images\
    Note  The NI Example Finder does not include NI-USRP examples.
    The product documentation is available at Start» Programs»National Instruments»NI-USRP»Documentation. The documentation set is composed of the following documents:
    • NI-USRP Readme
    • NI USRP-292x Getting Started Guide—Printed and PDF format. Contains hardware and software installation and configuration information.
    • NI-USRP Help—HTML help format. Contains digital communication system fundamentals, hardware device overview, programming information, and LabVIEW reference.
    • NI-USRP Specifications—PDF format. Lists specifications for NI-USRP devices.
    • Read Me First: Safety and Electromagnetic Compatibility—Printed format. Contains safety instructions and electromagnetic compatibility (EMC) information for the hardware it accompanies.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    National Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates.
    National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications.
    Perform the following procedure to uninstall NI-USRP.
    • Click Change/Remove.
    • Select NI-USRP 1.1 from the dialog box that appears.
    You can access the software and documentation known issues list online. Refer to the NI-USRP 1.1 Known Issues at ni.com for an up-to-date list of known issues.
    The following items are changes in NI-USRP 1.1 from NI-USRP 1.0.
    325276Corrected the documented maximum input power (Pin) for the NI USRP-2920 to 0 dBm.
    325144Fixed an issue that caused the NI-USRP Configuration Utility to hang if the final field of the IP address was three or more digits.
    313727Fixed an issue where the niUSRP EX QAM Rx example VI would not display a signal constellation when run using the default values.
    311842Fixed an issue where NI-USRP returned an error if you opened an Rx session when a Tx session was already open for a separate device.
    313754Fixed an issue where NI-USRP returned an incorrect value for the coerced gain parameter on a Tx session using the NI USRP-2920.
    329137Fixed an issue where NI-USRP raised the class of the process to "Real-Time" and the priority of the thread to "Highest" when an Rx operation started.
    Using Microsoft Silverlight
    © 2011–2012 National Instruments. All rights reserved.
    • Review \_Legal Information\_Legal Information.txt for information on including legal information in installers built with NI products.
    GMT+8, 2025-11-19 12:43
