查看: 2809|回复: 2
[MVTEC] MVTEC Halcon 20.05.0.1 Progress Deep Learning Data Win32/Win64 HALCON深度学习数据20.05.0.1 32位/64位Windows版
    5 小时前
  • 签到天数: 3535 天
    发表于 2020-11-14 11:37:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HALCON 20.05.0.1 Deep Learning Data - Data Required for Deep Learning Example Programs (x86sse2-win32 / x64-win64), Add-on to Full/Runtime Version:
    文件名: halcon-20.05.0.1-windows-deep-learning-data.exe
    文件大小: 1321371920 字节 (1.23 GB)
    修改日期: 2020-11-05 14:00
    版本: 20.5.0.1
    MD5: f85210298866ed81ce890feb630aff0e
    SHA1: bee793a9744473ae361f07fd63c13aceba55868d
    SHA256: 1aaf3dbc5c3f3d3c4078bcd0f2db3c7e50ff47786c6fdc9c12dba914cb310fc9
    CRC32: 66e5a668
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码: f4bh
    Release Notes for HALCON 20.05.0.1 Progress
    Hotfix for HALCON 20.05.0.0 Progress
    This document provides the release notes for MVTec HALCON 20.05.0.1 Progress, as released in July 2020, which is a Hotfix for HALCON 20.05.0.0 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.05.0.0 Progress.
    Contents
    Detailed Description of Changes in HALCON 20.05.0.1 Progress (Hotfix)
    Deep Learning
    Matching
    Licensing
    The changes in HALCON 20.05.0.1 Progress are described with respect to HALCON 20.05.0.0 Progress.
    Deep Learning
    If the system parameter "cudnn_deterministic" was specified as "true" and the model parameter "optimize_for_inference" was also "true", the training of this deep learning model did not use the corresponding deterministic cuDNN backward algorithm for convolution layers as required. Hence, the training of such a model was most likely not deterministic on a GPU. This problem has been fixed.
    Matching
    find_shape_model, find_shape_models, find_scaled_shape_model, find_scaled_shape_models, find_aniso_shape_model, find_aniso_shape_models, and find_shape_model_3d did not abort in a timeout error in rare cases where the operator was parallelized and a timeout was set. This problem has been fixed.
    Licensing
    When using a license bound to a dongle, HDevelop could periodically fail to communicate with the dongle and complain about a licensing error in response. This problem has been fixed.
    发表于 2021-4-20 22:24:23 | 显示全部楼层 来自:广东省广州市 联通
  • 签到天数: 11 天
    发表于 2021-5-2 21:39:41 | 显示全部楼层 来自:美国 加利福尼亚州弗里蒙特市Hurricane Electric公司
    GMT+8, 2025-5-10 15:08
