查看: 2562|回复: 2
[MVTEC] MVTEC Halcon 20.05.0.1 Progress Runtime Version Win32/Win64 HALCON运行版20.05.0.1 32位/64位Windows版
    4 小时前
  • 签到天数: 3535 天
    发表于 2020-11-14 11:33:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    HALCON 20.05.0.1 Runtime Version (x86sse2-win32 / x64-win64):
    文件名: halcon-20.05.0.1-windows-runtime.exe
    文件大小: 219880256 字节 (209.69 MB)
    修改日期: 2020-11-05 12:25
    版本: 20.5.0.1
    MD5: ee1c7065f3585c35a2c5c7c0569b815a
    SHA1: 07151358fedc9bc1872ee1fb0bfab1ac5ffbe196
    SHA256: 410e1887a6558f7a47bcc9c1a5aef2cffa125d90060d225b3b41944815db3454
    CRC32: 5d4fbae1
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码: q4r6
    Release Notes for HALCON 20.05.0.1 Progress
    Hotfix for HALCON 20.05.0.0 Progress
    This document provides the release notes for MVTec HALCON 20.05.0.1 Progress, as released in July 2020, which is a Hotfix for HALCON 20.05.0.0 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.05.0.0 Progress.
    Contents
    Detailed Description of Changes in HALCON 20.05.0.1 Progress (Hotfix)
    Deep Learning
    Matching
    Licensing
    The changes in HALCON 20.05.0.1 Progress are described with respect to HALCON 20.05.0.0 Progress.
    Deep Learning
    If the system parameter "cudnn_deterministic" was specified as "true" and the model parameter "optimize_for_inference" was also "true", the training of this deep learning model did not use the corresponding deterministic cuDNN backward algorithm for convolution layers as required. Hence, the training of such a model was most likely not deterministic on a GPU. This problem has been fixed.
    Matching
    find_shape_model, find_shape_models, find_scaled_shape_model, find_scaled_shape_models, find_aniso_shape_model, find_aniso_shape_models, and find_shape_model_3d did not abort in a timeout error in rare cases where the operator was parallelized and a timeout was set. This problem has been fixed.
    Licensing
    When using a license bound to a dongle, HDevelop could periodically fail to communicate with the dongle and complain about a licensing error in response. This problem has been fixed.
    发表于 2021-9-26 09:37:31 | 显示全部楼层 来自:广东省深圳市罗湖区 电信
    发表于 2021-10-8 15:12:05 | 显示全部楼层 来自:广东省深圳市 电信
    GMT+8, 2025-5-10 14:13
