TA的每日心情 | 怒 8 小时前 |
签到天数: 3586 天 连续签到: 6 天 [LV.Master]2000FPS
发表于 2020-11-14 11:31:02
MVTEC Halcon 20.05.0.1 Progress Full Version Win32/Win64 HALCON开发版20.05.0.1 32位/64位Windows版
HALCON 20.05.0.1 Full Version (x86sse2-win32 / x64-win64):
文件名: halcon-20.05.0.1-windows.exe
文件大小: 2108523480 字节 (1.96 GB)
修改日期: 2020-11-05 17:17
版本: 20.5.0.1
MD5: cb9b5e6068aece9c73a1d029529f17ab
SHA1: 21bee57de77871ad9a2ddcbb5a4a934ee4394118
SHA256: bcb4340f35776d4a16500176a2883a32a950bc48529fb34b76b00cfa934df224
CRC32: e43f41d5
MVTEC官方下载(需要注册、国外IP地址可能被墙)
www.mvtec.com
链接:提取码: nxuj
Release Notes for HALCON 20.05.0.1 Progress
Hotfix for HALCON 20.05.0.0 Progress
This document provides the release notes for MVTec HALCON 20.05.0.1 Progress, as released in July 2020, which is a Hotfix for HALCON 20.05.0.0 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.05.0.0 Progress.
Contents
Detailed Description of Changes in HALCON 20.05.0.1 Progress (Hotfix)
Deep Learning
Matching
Licensing
The changes in HALCON 20.05.0.1 Progress are described with respect to HALCON 20.05.0.0 Progress.
Deep Learning
If the system parameter "cudnn_deterministic" was specified as "true" and the model parameter "optimize_for_inference" was also "true", the training of this deep learning model did not use the corresponding deterministic cuDNN backward algorithm for convolution layers as required. Hence, the training of such a model was most likely not deterministic on a GPU. This problem has been fixed.
Matching
find_shape_model, find_shape_models, find_scaled_shape_model, find_scaled_shape_models, find_aniso_shape_model, find_aniso_shape_models, and find_shape_model_3d did not abort in a timeout error in rare cases where the operator was parallelized and a timeout was set. This problem has been fixed.
Licensing
When using a license bound to a dongle, HDevelop could periodically fail to communicate with the dongle and complain about a licensing error in response. This problem has been fixed.
