NI-Industrial Communications for DNP3 14.0 Win32/64Eng NI DNP3工业通信软件14.0
NI-Industrial Communications for DNP3 driver是一组用来创建DNP3分站或主站应用程序的LabVIEW函数集。
NI-Industrial Communications for DNP3(分布式网络协议)驱动程序支持以太网和串行通信、文件传输以及主站和分站之间的时间同步。这些LabVIEW函数可帮助您在Windows计算机上进行编程,并部署到PXI控制器或现场应用所需的CompactRIO单板控制器。借助该驱动,用户还可使用每个分站的多个通信通道以及每个通道的多个会话(逻辑设备)。
14.0
文件大小: 129351968 字节 (123.36 MB)
修改日期: 2014-12-03 23:35
MD5: 0f368cbc4ae4005df6d0858984aec5b9
SHA1: ca2b5cf50967fe1db312e87c572e9ef11336f3e1
SHA256: 4d6451a30aa47ed9adb18d0638cab802bd1bc2216d37681fc88b23d471b84e75
CRC32: 511d95a0
DNP3 14.0.txt
(624 Bytes, 下载次数: 0, 售价: 10 圆)
NI-Industrial Communications for DNP3 14.0 ReadmeAugust 2014 This file contains important information about the NI-Industrial Communications for DNP3 software, including system requirements, installation instructions, and new features and changes. Overview System Requirements Installation Instructions Product Security and Critical Updates New Features and Changes Driver Version Naming Changes Accessing the Help Finding Examples Automating the Installation of NI Products How to Use NI Software with Microsoft Windows 8.x NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 Legal Information OverviewThe NI-Industrial Communications for DNP3 software contains an extensive library of VIs and properties in LabVIEW for you to program applications for your DNP3 devices. System RequirementsNI Hardware SupportThe following list indicates the NI hardware products supported by the VIs in NI-Industrial Communications for DNP3. - NI CompactRIO controllers with real-time OS
- NI PXI/PXI Express controllers with real-time OS
- NI PXI Express controllers with Windows OS
NI Application Software SupportThe following table lists the NI application software supported by NI-Industrial Communications for DNP3. | NI Application Software | Versions Supported by NI-Industrial Communications for DNP3 | | NI LabVIEW | 2011 (32-bit), 2012 (32-bit), 2013 (32-bit), 2014 (32-bit) | | NI LabVIEW Real-Time Module | 2011, 2012, 2013, 2014 |
Note You can install NI-Industrial Communications for DNP3 with only one version of LabVIEW on a computer. If you want to install NI-Industrial Communications for DNP3 with another supported version of LabVIEW on the same computer, you must uninstall existing NI-Industrial Communications for DNP3 and then install it under the target version of LabVIEW. Note Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW. Installation InstructionsBefore installing the NI-Industrial Communications for DNP3 software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for DNP3 software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Double-click the setup.exe file in the root directory of the NI-Industrial Communications for DNP3 installer and follow the instructions on the screen to install NI-Industrial Communications for DNP3. After you complete installing NI-Industrial Communications for DNP3, you can program DNP3 applications and deploy them on targets. Note Refer to the Activation Instructions folder in the root directory of the NI-Industrial Communications for DNP3 installer for instructions about how to activate the NI-Industrial Communications for DNP3 software. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. New Features and ChangesNI-Industrial Communications for DNP3 14.0 contains the following new features and changes: - Support for deploying DNP3 applications on NI PXI Express controllers with Windows OS. Refer to the National Instruments website for more information about how to deploy DNP3 applications on NI PXI Express controllers with Windows OS.
- New example VIs and updated existing example VIs to better demonstrate common tasks using NI-Industrial Communications for DNP3.
- Fixed high-severity issues.
Driver Version Naming ChangesNI-Industrial Communications for DNP3 versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: NI-Industrial Communications for DNP3 14.0. For example, NI-Industrial Communications for DNP3 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-Industrial Communications for DNP3 2.1. The first version released under the new numbering scheme is NI-Industrial Communications for DNP3 14.0. Accessing the HelpRefer to the NI-Industrial Communications for DNP3 API for LabVIEW Help, accessible from Help»NI-Industrial Communications for DNP3 in LabVIEW, for information about NI-Industrial Communications for DNP3. Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»DNP3 folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. You also can find the examples for NI-Industrial Communications for DNP3 in the labview\examples\DNP3 directory. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
How to Use NI Software with Microsoft Windows 8.xWhen you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile in the Apps view. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. | Note NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch NI MAX either from the Apps view or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: | Current Application | Icon Location | Pin to Action | | Windows 8.x Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | | Windows 8.x Desktop | Start screen | Right-click application and select Pin to Start | | Windows 8.x Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8) or click the down arrow on the bottom left of the screen (Windows 8.1). For more information about NI support for Windows 8.x, visit ni.com/windows8. NI-Industrial Communications for DNP3 Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016National Instruments NI-Industrial Communications for DNP3 will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for DNP3 that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | NI LabVIEW | lifecycle | | NI LabWindows™/CVI™ | cvi_lifecycle | | NI Measurement Studio | mstudiolifecycle | | NI TestStand | tslcp | | NI DIAdem | ddlcp | | NI SignalExpress | selcp | | NI VeriStand | nivslifecycle |
Legal InformationCopyright © 2010–2014 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. 374796A-01 |
