查看: 3011|回复: 0
[LV工具模块] LabVIEW Simulation Interface Toolkit 2012 Win32Eng LabVIEW2012仿真接口工具包SIT2012下载
    昨天 07:09
  • 签到天数: 3534 天
    连续签到: 4 天
    发表于 2020-11-11 23:56:22 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2012
    文件大小: 201374344 字节 (192.05 MB)
    修改日期: 2012-08-07 05:33
    MD5: 8470dd45b0a840cb81ac16dc439a0e04(重复一致,可秒传)
    SHA1: 359201d0dbb5dfe37039ac3dc5363cdd433f54bf
    SHA256: 3474849eb078ec04c25fdaac214cbce109f4da3e15793731c5383f4622aa2fe6
    CRC32: 720fc7e2
    SIT2012.txt (791 Bytes, 下载次数: 2, 售价: 10 元)
    LabVIEW 2012 Simulation Interface Toolkit Readme
    Version 2012.0.0
    June 2012
    This file contains the following information about the LabVIEW Simulation Interface Toolkit.
    Upgrading from SIT 2.0.x/3.0.x/4.0/5.0.x/2009/2010/2011
    What's New in 2012
    Support for Real-Time Targets
    Accessing the Help and Examples
    Development Tips
    The NI LabVIEW Simulation Interface Toolkit gives control system design and test engineers a link between the NI LabVIEW graphical development environment and The MathWorks, Inc. Simulink® application software. With the LabVIEW Simulation Interface Toolkit, you can easily build custom LabVIEW user interfaces to view and control your simulation model at run time. This toolkit also provides a plug-in for use with The MathWorks, Inc. Real-Time Workshop® (Simulink Coder®), so you can use LabVIEW to connect your model developed in the Simulink environment to the real world through a variety of real-time I/O platforms (requires the LabVIEW Real-Time Module). With these capabilities, you can easily take your models from software verification to real-world prototyping and hardware-in-the-loop simulation.
    You can run the LabVIEW Simulation Interface Toolkit installer on the following operating systems:
    • Windows XP SP2 (32-bit)
    Note  The LabVIEW Simulation Interface Toolkit runs as a 32-bit application on all operating systems.
    The LabVIEW Simulation Interface Toolkit does not support Windows 2000/NT/Me/98/95, Windows XP x64, or the Windows Server non-R2 editions.
    Refer to the LabVIEW readme for additional system requirements and supported operating systems for LabVIEW 2012.
    In addition to the system requirements for the LabVIEW Development System, the LabVIEW 2012 Simulation Interface Toolkit has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    To create a host VI for a previously-developed model, you need only LabVIEW installed. To develop your model, you also must be a properly licensed user of and have the following software installed on the host computer:
    • The MathWorks, Inc. MATLAB® software and The MathWorks, Inc. Simulink® application software release 13.x, 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, 2009a, 2009b, 2010a, 2010b, or 2011a
    Note  The LabVIEW Simulation Interface Toolkit does not support 64-bit versions of the MATLAB application software.
    To control an offline simulation using the LabVIEW 2012 Simulation Interface Toolkit, you must install LabVIEW 2012 Simulation Interface Toolkit in addition to the MATLAB application software and the Simulink application software.
    To compile your model into a model DLL, you must install the following software:
    • The MathWorks, Inc. Real-Time Workshop® software release 13.x, 14.x, 2006a, 2006b, 2007a, 2007b, 2008a, 2008b, 2009a, 2009b, 2010a, 2010b, or 2011a
    • Microsoft Visual C++ 6.0, .NET 2003, 2005 (Professional or Express), or 2008 (Professional or Express)
    To control a simulation with a model in DLL form (Real-Time Target or Driver VI on Localhost), you must be a properly licensed user of and have the following software installed on both the host computer and the real-time target.
    • National Instruments LabVIEW 2012 Real-Time Module for ETS Targets.
    • (Optional) National Instruments LabVIEW 2012 FPGA Module, to create customized FPGA bitfiles used in real-time simulations involving NI FPGA devices.
    • You also must install the following driver software versions, depending on the type of hardware you want to use.
      National Instruments HardwareDriver Software Version Required
      National Instruments FPGA DevicesNI-RIO™ 4.0 or later
      National Instruments CAN InterfacesNI-CAN™ 2.7.3 or later
      National Instruments DAQ DevicesNI-DAQmx™ 9.3.5 or later
    You can install all of your LabVIEW products—including the LabVIEW 2012 Simulation Interface Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW 2012 Platform DVDs, refer to the National Instruments Web site at ni.com.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    • Load a host VI saved in SIT 3.0.x/4.0 and launch the SIT Connection Manager dialog box. Click the OK button to apply new settings. The conversion process preserves control/indicator mappings and all block diagram code. You will lose changes to SIT 3.0.x driver VI, but SIT 5.0.1 maintains hardware mappings. If the path to your model is invalid, SIT 5.0.1 prompts you to specify a valid path.
    • SIT 3.0.x driver VIs are not supported in SIT 5.0.1. If you are not using the SIT Connection Manager you will need to manually upgrade the driver VI. Refer to one of the examples for the correct driver VI structure.
    • SIT 5.0.1 does not convert driver VIs that SIT 2.0.x generated. Use the SIT Connection Manager dialog box to build a new driver VI for use in real-time simulations.
    • SIT 5.0.1 does not convert host VIs that SIT 2.0 generated.
    • The Simulation Interface Toolkit 4.0 deprecated the following VIs: SIT Execute Task and SIT Synchronize Base Rate.
    • The Simulation Interface Toolkit 5.0.1 relies heavily upon the SIT Connection Manager dialog box. National Instruments recommends you use this dialog box to create host VIs and driver VIs.
    • When running a simulation in Simulation Environment, the SignalProbe blocks from SIT 3.0.x/4.0 do not recognize tuneable variables specified through Data Objects. To be able to tune variables specified as tuneable through Data Objects, you must delete and re-add the SignalProbe block.
    • Update any custom FPGA bitfiles and VIs you developed in SIT 3.0.x/4.0 to the new FPGA VI template and recompile them.
    • SIT Write Log Settings to Configuration File.vi and SIT Write Playback Settings to Configuration File.vi in the User API have a new required input for Model Path.
    • The Simulation Interface Toolkit 5.0/5.0.1/2009/2010/2011 VIs can be used in LabVIEW 2012 Simulation Interface Toolkit without any modification.
    • The LabVIEW 2012 Simulation Interface Toolkit supports the 2011a software release of The Mathworks, Inc. MATLAB®, Simulink®, Real-Time Workshop®, and Stateflow® software.
    What's New in 2012
    The LabVIEW 2012 Simulation Interface Toolkit includes the following new features:
    • Updated Support for The MathWorks, Inc. Software
    The LabVIEW Simulation Interface Toolkit supports running a simulation on the following types of National Instruments RT Series Hardware:
    • PXI
      • Any PXI-RT controller
    • FieldPoint
      • Any Compact FieldPoint controller
    • CompactRIO
      • Any CompactRIO controller is supported. A default bitfile is provided for the cRIO-9103 with NI 9215, NI 9263, NI 9411 and NI 9474 I/O modules. If you are using a different controller or a different set of I/O modules, you can use LabVIEW FPGA module to compile a custom bitfile.
      • You can use the Single Point Timed I/O Timing Engine in the FPGA Wizard to help create the FPGA VI for use with SIT. FPGA VIs created by the FPGA Wizard can only be used when there is only one HW timed device in the system. If you are using more than one HW timed device (e.g. two R-series boards in a PXI chassis) you need to use the template provided with SIT.
      • If you are using a VxWorks-based controller refer to the X:\SimulationInterfaceToolkit\2011\VxWorks\readme_sit_vxworks.txt file for information about enabling VxWorks support, where X is the drive where you installed the Simulation Interface Toolkit.
      • National Instruments recommends that you do not install the Scan Engine if you are using the CompactRIO controller with Simulation Interface Toolkit.
    The LabVIEW 2012 Simulation Interface Toolkit ships with FPGA VIs for the following FPGA devices:
    • NI PCI-7811R
    • NI PXI-7811R
    • NI PCI-7813R
    • NI PXI-7813R
    • NI PCI-7831R
    • NI PXI-7831R
    • NI PCI-7833R
    • NI PXI-7833R
    • NI PXI-7841R
    • NI PXI-7842R
    • NI PXI-7851R
    • NI PXI-7852R
    • NI cRIO-9103
    The LabVIEW Help contains conceptual, how-to, and reference information about the Simulation Interface Toolkit. Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to the Toolkits»Simulation Interface top-level topic.
    The LabVIEW Simulation Interface Toolkit examples are located in the labview\examples\Simulation Interface\ directory.
    Development Tips
    • Driver VIs running on NI FPGA devices use the hardware settings for channel measurements.
    • In order to use the example .mdl files, that are included with SIT, when the execution host is set to driver VI on local or real-time, you first must compile the model into a DLL using Simulink®.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW Simulation Interface Toolkit.
    Important Information
    © 2002–2012 National Instruments. All rights reserved.
    CompactRIO, FieldPoint, LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    MATLAB®, Real-Time Workshop®, Stateflow®, and Simulink® are registered trademarks of The MathWorks, Inc.
    Other product and company names are trademarks or trade names of their respective companies.
    Only Licensed Use is Permitted
    You are only permitted to use this product in accordance with the accompanying license agreement. All rights not expressly granted to you in the license agreement accompanying the product are reserved to NI. Further, and without limiting the forgoing, no license or any right of any kind (whether by express license, implied license, the doctrine of exhaustion or otherwise) is granted under any NI patents or other intellectual property right of NI with respect to any other product(s) of NI or of anyone else (including without limitation, the MATLAB, Simulink and/or the Real-Time Workshop software of The MathWorks, Inc.), including without limitation, the right to use any of these other products.
    GMT+8, 2025-5-10 07:42
