查看: 2315|回复: 0
[LV工具模块] LabVIEW 2017 ELVIS RIO Control Toolkit Win32Eng LabVIEW ELVIS RIO控制模块2017版下载
    昨天 07:43
  • 签到天数: 3524 天
    连续签到: 12 天
    发表于 2020-11-10 23:06:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2017
    (MD5)
    7e1b1cc3de25e0bd3ab74b91ea9df473(官方校验和)
    文件大小: 2088725036 字节 (1.95 GB)
    修改日期: 2017-05-22 21:51
    MD5: 8e348dbb2e3be69fee5cedabb77fbd2e(多次重复下载一致)
    SHA1: df1ab96eadb9cc18a1e33fe80324a9be79c0163b
    SHA256: 8936e01029c19e9e94e06410065807d1b821f36389024305b5b892e15d2ff12d
    CRC32: 5fe1242a
    ELRIO2017.txt (647 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2017 ELVIS RIO Control Toolkit Readme
    March 2017
    This file contains important information about the LabVIEW ELVIS RIO Control Toolkit, including system requirements, installation instructions, and known issues for the LabVIEW 2017 ELVIS RIO Control Toolkit.
    Installing the High Throughput Add-On for ELVIS RIO Control Module
    Accessing the LabVIEW for NI ELVIS RIO CM Environment
    The LabVIEW ELVIS RIO Control Toolkit provides you with tools for creating and deploying applications on the NI ELVIS RIO Control Module (CM).
    The ELIVS RIO Control Toolkit has the following requirements:
    • (Optional for C Programming) LabVIEW 2017 Student, Full, or Professional Development System
    • (Optional for C Programming) LabVIEW 2017 Real-Time Module
    • At least 2 GB of disk space in addition to the LabVIEW-recommended minimum
    • 1 GB RAM
    Refer to the LabVIEW Readme for additional system requirements for LabVIEW 2017.
    Note
    • The ELVIS RIO Control Toolkit is compatible with only 32-bit LabVIEW. Install 32-bit LabVIEW even if you use a 64-bit operating system.
    • You might need more memory than the LabVIEW-recommended minimum depending on the size of the application you design in LabVIEW on the host computer.
    The ELVIS RIO Control Toolkit supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 the LabVIEW ELVIS RIO Control Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 ELVIS RIO Control Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2017 ELVIS RIO Control Toolkit to an unsupported OS. Additionally, after installing the LabVIEW 2017 ELVIS RIO Control Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Complete the following steps to install the ELVIS RIO Control Toolkit using the LabVIEW ELVIS RIO Control Software Bundle media:
    • Log in to the development computer as an administrator or as a user with administrative privileges.
    • Insert the LabVIEW ELVIS RIO Control Software Bundle DVD 1.
    • Select Install NI LabVIEW 2017 ELVIS RIO Control Toolkit.
    • (Optional for C Programming) Click the drop-down arrow next to LabVIEW Support and select Install this feature to a local drive.
    • Click Next and follow the instructions on the screen to install the ELVIS RIO Control Toolkit.
    To install the ELVIS RIO Control Toolkit using the installer from ni.com/downloads, double-click the setup.exe file in the root directory of the ELVIS RIO Control Toolkit installer and follow the instructions on the screen to install this product.
    The High Throughput Add-On for ELVIS RIO Control Module provides the High Throughput FPGA Personality VIs which support high-speed analog or digital data access. The High Throughput FPGA Personality VIs appear on the NI ELVIS RIO CM palette only after you install the High Throughput Add-On for ELVIS RIO Control Module.
    Visit ni.com/info and enter the Info Code exqmja to download the High Throughput Add-On for ELVIS RIO Control Module installer. Double-click the setup.exe file in the root directory of the installer and follow the instructions on the screen to install this product.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the ELVIS RIO Control Toolkit.
    The ELVIS RIO Control Toolkit provides the LabVIEW for NI ELVIS RIO CM environment to allow you to easily access NI ELVIS RIO CM-specific features and focus on developing NI ELVIS RIO CM applications.
    You can use the Choose Environment Settings dialog box to change your LabVIEW environment. To display this dialog box, select Tools»Choose Environment from LabVIEW.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the ELVIS RIO Control Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the ELVIS RIO Control Toolkit are located in the labview\examples\EL-RIO-CM directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2016–2017 National Instruments. All rights reserved.
    376364B-01
    举报
    GMT+8, 2025-4-26 08:42
