查看: 2892|回复: 0
[LV工具模块] LabVIEW 2013 PID and Fuzzy Logic Toolkit Win32Eng LabVIEW PID和模糊逻辑工具包2013版下载
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-11-9 23:46:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2013
    文件大小: 88523552 字节 (84.42 MB)
    修改日期: 2013-07-03 00:47
    MD5: 106a67af03420b9e95782c43365a233d(重复下载一致)
    SHA1: 51034c7b976282b3e2a395d462b5afb065f070a3
    SHA256: d249772b09434134c88ac1fdc4efcc7cec8f9b1c4bf732394ca261ba4c943c0c
    CRC32: 9847d0c2
    PID FLT2013.txt (584 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2013 PID and Fuzzy Logic Toolkit Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW PID and Fuzzy Logic Toolkit, including installation instructions, a partial list of bugs fixed for LabVIEW 2013 PID and Fuzzy Logic Toolkit, and known issues.
    In addition to the system requirements for the LabVIEW Development System, the PID and Fuzzy Logic Toolkit has the following requirements:
    • LabVIEW 2013 Full or Professional Development System (32-bit)
    • At least 75 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    You can install all of your LabVIEW products—including the PID and Fuzzy Logic Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    PID and Fuzzy Logic Toolkit Updates and Notifications
    In the PID and Fuzzy Logic Toolkit 2011 and earlier, the PID Structure Conversion VI converts controllers in Parallel form to Academic form using the following transformation for the integral value: Td = K * Kd. In the PID and Fuzzy Logic Toolkit 2012 and later, the PID Structure Conversion VI converts the integral value using the following transformation: Td = Kd / K.
    To continue using the behavior from the previous versions, use the VI located at \examples\control\PID\subVIs\Convert PID Parameters.vi.
    Refer to the Toolkits» PID and Fuzzy Logic Toolkit» PID Control» PID Algorithms» PID Topologies topic on the Contents tab of the LabVIEW Help for more information about different forms of PID controllers.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the PID and Fuzzy Logic Toolkit.
    The following items are the IDs and titles of a subset of issues fixed in the PID and Fuzzy Logic Toolkit. This is not an exhaustive list of issues fixed in the current version of the PID and Fuzzy Logic Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    367762The PID Advanced Autotuning.vi does not have a terminal that indicates autotuning completion
    390912The PID Advanced Autotuning.vi cannot be used in parallel
    384634The PID Structure (DBL).vi is configured incorrectly in the “Modified Ziegler-Nichols” instance
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the PID and Fuzzy Logic Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the PID and Fuzzy Logic Toolkit are located in the labview\examples\control directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI LabVIEW PID and Fuzzy Logic Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW PID and Fuzzy Logic Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of PID and Fuzzy Logic Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2009–2013 National Instruments. All rights reserved.
    GMT+8, 2025-10-29 12:14
