查看: 3342|回复: 0
[LV工具模块] LabVIEW 2011 PID and Fuzzy Logic Toolkit Win32Eng LabVIEW PID和模糊逻辑工具包2011版下载
    昨天 07:44
  • 签到天数: 3537 天
    连续签到: 7 天
    发表于 2020-11-9 23:43:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2011
    文件大小: 63965792 字节 (61.00 MB)
    修改日期: 2011-07-09 01:21
    MD5: 7a1bb2e7cbf63185a24fab4b38e45978(重复下载一致)
    SHA1: 2044744c54efd3a38452031f3e333e08f30e5f21
    SHA256: b345c48e698358f331c7e00ca550496cf2d2ea2f1b14cba73f07434288ccce88
    CRC32: 179d74f2
    PID FLT2011.txt (584 Bytes, 下载次数: 1, 售价: 10 元)
    LabVIEW 2011 PID and Fuzzy Logic Toolkit Readme
    Version 11.0.0
    June 2011
    This file contains the following information about the LabVIEW 2011 PID and Fuzzy Logic Toolkit.
    Version 2011 Features and Changes
    Installation/Upgrading Instructions
    The computer you are using must meet the following minimum system requirements to run the PID and Fuzzy Logic Toolkit:
    • LabVIEW 2011 Full or Professional Development System (32-bit)
    You can run the LabVIEW PID and Fuzzy Logic Toolkit installer on the following operating systems:
    • Windows XP Service Pack 2 or later (32-bit)
    The LabVIEW PID and Fuzzy Logic Toolkit installer does not support Windows XP SP1 or earlier/2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    The LabVIEW 2011 PID and Fuzzy Logic Toolkit incorporates the following new features and changes.
    Autotuning Enhancements
    The LabVIEW 2011 PID and Fuzzy Logic Toolkit includes enhanced autotuning functionality provided by several new VIs. These enhancements enable you to configure autotuning programmatically without using the Autotuning Wizard, use autotuning in RT and FPGA applications, directly control temperature systems, and design autotuning solutions based on Cohen-Coon and Chien-Hrones-Reswick tuning methods.
    These updates include the following new VIs:
    • PID Advanced Autotuning
    • PID Online Autotuning
    • PID Autotuning Design
    • PID Autotuning (Temperature)
    Refer to the Autotuning PID Controllers book, located under Toolkits» PID and Fuzzy Logic Toolkit» PID Control in the LabVIEW Help, for more information.
    New VIs
    The LabVIEW 2011 PID and Fuzzy Logic Toolkit includes the following new VIs:
    • PID Structure Conversion—Converts a PID controller or controllers in Academic, Parallel, or Series form into the form (Academic) and PID gains units that the PID VIs expect.
    Updated VI
    The LabVIEW 2011 PID and Fuzzy Logic Toolkit includes the following updated VI:
    • PID Advanced—The PID Advanced VI includes the following new inputs that provide additional configuration options for PID controllers you implement with this VI:
      • gamma—Specifies an amount by which to weight the error applied to derivative action.
      • alpha—Specifies the derivative filter time constant
    Refer to the PID VIs book, located under Toolkits» PID and Fuzzy Logic Toolkit» PID and Fuzzy Logic Toolkit VIs in the LabVIEW Help for more information about these new and updated VIs.
    Notice of Upcoming Changes
    The Advanced VIs were deprecated in the LabVIEW 8.2 PID Control Toolkit. The LabVIEW PID and Fuzzy Logic Toolkit still supports applications that use these VIs. However, note that a future version of the PID and Fuzzy Logic Toolkit might no longer support these VIs. National Instruments strongly recommends that you use the LabVIEW Control Design and Simulation Module to replace the functionality of these VIs. Refer to the National Instruments Web site at ni.com for more information about the Control Design and Simulation Module.
    You can install all of your LabVIEW products—including the LabVIEW PID and Fuzzy Logic Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the PID and Fuzzy Logic Toolkit along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    The PID and Fuzzy Logic Toolkit Help contains conceptual, how-to, and reference information about the PID and Fuzzy Logic Toolkit. Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to the Toolkits» PID and Fuzzy Logic Toolkit top-level topic.
    Refer to the labview\examples\control directory for example VIs that demonstrate common tasks using the PID and Fuzzy Logic Toolkit. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules» PID Control in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 PID and Fuzzy Logic Toolkit.
    The following items are the IDs and titles of a subset of issues fixed between the LabVIEW 2010 PID and Fuzzy Logic Toolkit and the LabVIEW 2011 PID and Fuzzy Logic Toolkit. This is not an exhaustive list of issues fixed in the current version of the PID and Fuzzy Logic Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    287441Fuzzy System Designer needs keyboard shortcuts in run-time menu
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-5-13 03:55
