查看: 3145|回复: 0
[LV工具模块] LabVIEW 2010 PID and Fuzzy Logic Toolkit Win32Eng LabVIEW PID和模糊逻辑工具包2010版下载
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-11-9 23:41:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2010
    文件大小: 51763808 字节 (49.37 MB)
    修改日期: 2010-07-17 01:06
    MD5: 3e998e2f31d0269c5a121f8a2c580b0d(重复下载一致)
    SHA1: bd05130c953965717e369e9349ab866d5c63ae5f
    SHA256: e0f8b222301e10cf770584ef871b3bf19a5d66eb73ccda1566f840936045b3aa
    CRC32: f409a308
    PID FLT2010.txt (584 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2010 PID and Fuzzy Logic Toolkit Readme
    Version 10.0.0
    June 2010
    This file contains the following information about the LabVIEW 2010 PID and Fuzzy Logic Toolkit.
    Version 2010 Features and Changes
    Installation/Upgrading Instructions
    The computer you are using must meet the following minimum system requirements to run the PID and Fuzzy Logic Toolkit:
    • LabVIEW 2010. Note that some examples might not work properly if you do not have the LabVIEW 2010 Full or Professional Development System installed.
    You can run the LabVIEW PID and Fuzzy Logic Toolkit installer on the following operating systems:
    • Windows XP (32-bit)
    The LabVIEW PID and Fuzzy Logic Toolkit installer does not support Windows 2000/NT/Me/98/95 or the Windows Server non-R2 editions.
    The LabVIEW 2010 PID and Fuzzy Logic Toolkit incorporates the following new features and changes.
    New VI
    The LabVIEW 2010 PID and Fuzzy Logic Toolkit includes the following new VI:
    • FL Integrate Rule—Checks a new rule for conflicts with existing rules in the fuzzy system and, optionally, integrates the new rule into the system.
    Notice of Upcoming Changes
    The Advanced VIs were deprecated in the LabVIEW 8.2 PID Control Toolkit. The LabVIEW 2010 PID and Fuzzy Logic Toolkit still supports applications that use these VIs. However, note that a future version of the PID and Fuzzy Logic Toolkit no longer might support these VIs. National Instruments strongly recommends that you use the LabVIEW Control Design and Simulation Module to replace the functionality of these VIs. Refer to the National Instruments Web site at ni.com for more information about the Control Design and Simulation Module.
    You can install all of your LabVIEW products—including the LabVIEW PID and Fuzzy Logic Toolkit—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the PID and Fuzzy Logic Toolkit along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    The LabVIEW PID and Fuzzy Logic Toolkit User Manual contains conceptual information about using the PID and Fuzzy Logic Toolkit. Complete the following steps to access this manual. Open this manual by selecting Start»All Programs»National Instruments»LabVIEW 2010»LabVIEW Manuals and opening PID_User_Manual.pdf or by navigating to the labview\manuals directory and opening PID_User_Manual.pdf.
    The LabVIEW PID and Fuzzy Logic Toolkit VIs Help contains reference information about the PID and Fuzzy Logic Toolkit. Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to the Toolkits» PID and Fuzzy Logic Toolkit VIs top-level topic.
    Refer to the labview\examples\control directory for example VIs that demonstrate common tasks using the PID and Fuzzy Logic Toolkit. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules» PID Control in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2010 PID and Fuzzy Logic Toolkit.
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-29 12:21
