查看: 3359|回复: 0
[NI驱动程序] NI-SLSC 20.0.1 Driver Win32/64Eng NI开关负载信号调理设备驱动20.0.1版下载
    昨天 10:01
  • 签到天数: 3599 天
    连续签到: 7 天
    发表于 2020-11-9 00:00:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    20.0.1
    文件大小: 1174382592 字节 (1.09 GB)
    修改日期: 2020-10-14 20:46
    MD5: 0e3130a88c90fae63be73d4554c65fef(官方正确)
    SHA1: 148b13099ff9271613d2e5835724cc2ed6db65a0
    SHA256: 5990cf3cd62644938ca4432182429db72e0a7de637fcf4dcd0c85c53e64afd28
    CRC32: 82a0a4b1
    SLSC20.1.txt (275 Bytes, 下载次数: 0, 售价: 10 元)
    NI-SLSC 20.0 Readme
    February 2020
    This file contains important information about the NI-SLSC driver software, including new features and known issues.
    NI-SLSC Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-SLSC 20.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  Refer to NI-SLSC Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 NI-SLSC dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SLSC 20.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SLSC 20.0 to an unsupported OS. Additionally, after installing NI-SLSC 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022 may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    NI-SLSC 20.0 supports the following application software versions, including service packs.
    Versions Supported by NI-SLSC
    LabVIEW2017, 2018, 2019, 2020
    LabVIEW Real-Time Module12017, 2018, 2019, 2020
    1 NI-SLSC supports Phar Lap ETS and NI Linux Real-Time targets, but does not support VxWorks targets.
    NI installs NI-SLSC using NI Package Manager. If you do not already have NI software installed, NI-SLSC installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    NI-SLSC 20.0 added the following new features:
    • C language support for the NI-SLSC API and the NI-SLSC Switch API
    • Support for LabVIEW 2020
    • SLSC-12001 chassis
    • SLSC modules that comply with SLSC MDK 1.4 or earlier
    You can access the NI-SLSC known issues list online at NI-SLSC Known Issues.
    Refer to the NI-SLSC Help, accessible by navigating to the C:\Users\Public\Documents\National Instruments\NI-SLSC\Documentation directory and opening NI-SLSC Help.chm, for information about the NI-SLSC driver software. You can also refer to the NI-SLSC VI Reference Help, accessible by selecting Help»NI-SLSC VI Reference Help in LabVIEW, for information about SLSC VIs.
    NI-SLSC will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2016–2020 National Instruments. All rights reserved.
    376773J-01
    GMT+8, 2025-7-21 08:36
