查看: 3118|回复: 0
[RTE运行引擎] NI-SLSC 17.0 Runtime Driver Win32/64Eng NI开关负载信号调理设备驱动17.0版运行引擎下载
    昨天 10:01
  • 签到天数: 3599 天
    连续签到: 7 天
    发表于 2020-11-8 23:37:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    17.0RT
    文件大小: 96855624 字节 (92.37 MB)
    修改日期: 2019-06-25 03:09
    MD5: 0bd38c510e45b8e43619079206829006(官方正确)
    SHA1: 32dcd11329b53ad46122ba202d8834249e3499de
    SHA256: bd3880a55950f19e5d9a77c4a0104cfd3d66cc88c8bf69d958651ce071b8650d
    CRC32: 0fe829b5
    SLSC17.0RT.txt (267 Bytes, 下载次数: 0, 售价: 5 元)
    NI-SLSC 17.0 Readme
    May 2017
    This file contains important information about NI-SLSC, including any system requirements and any known issues for the application and the driver software.
    Supported Devices
    Enhancements and Bug Fixes
    NI-SLSC supports the following operating systems:
    • Windows 10/8.1/7 SP11
    • Windows Embedded Standard 7 SP11
    • Windows Server 2012 R2
    • Windows Server 2008 R2 SP11
    1 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    The following table lists the NI application software versions, including service packs, supported by NI-SLSC.
    Application SoftwareVersions Supported by NI-SLSC
    LabVIEW2015, 2016, 2017
    LabVIEW Real-Time Module12015, 2016, 2017
    1 NI-SLSC supports Phar Lap ETS and Linux RT targets. It does not support VxWorks targets.
    Supported Devices
    • SLSC-12001 chassis
    • SLSC modules that comply with SLSC MDK 1.0
    You can access an up-to-date list of known issues in NI-SLSC by visiting ni.com/info and entering ex2t83.
    • Added LabVIEW 2016 and 2017 support.
    • Added Linux RT support.
    • Moved SLSC examples to LabVIEW example finder.
    • Updated chassis status LED to turn green when the chassis is ready to accept network connections, although module discovery may not be complete. Modules may require several more seconds to fully enumerate.
    • Information about NVMEM areas is now updated correctly after the module is reset.
    • Updated physical channel names to allow slashes.
    • Improved reporting chassis firmware and module capabilities for compatibility and versioning.
    • Updated the firmware for the SLSC-12001 chassis to fix the incorrect device class appearing in the System Configuration API. This fix enables filtering of SLSC chassis using the device class “SLSC."
    • Improved synchronization when multiple sessions in the same reservation group attempt to access a module. Attempts to write registers, commit properties, or execute commands while a command is in progress will report an error. Other operations are synchronized to allow execution without error while preserving data integrity on the chassis.
    • Made changes to allow the properties DefaultDevices, DefaultNVMEMAreas, and DefaultPhysicalChannels to now be writeable through the NI-SLSC Session property node. NI-SLSC 1.0 allowed them to be read, but attempts to write to them failed.
    • Updated web interface for the SLSC-12001 to now indicate that a reboot is required for changed network settings to take effect.
    © 2016–2017 National Instruments. All rights reserved.
    376773B-01
    GMT+8, 2025-7-21 08:37
