查看: 5449|回复: 0
[LV工具模块] NI LabVIEW Internet Toolkit 2012 Win32Eng LabVIEW2012网络工具包下载
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2020-11-6 23:45:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Internet工具包可用于将internet功能整合至VI,实现基于Telnet协议的数据收发、从FTP服务器上传或下载文件、向Web发布VI、以及通过Web浏览器对VI进行远程控制。
    文件大小: 60664416 字节 (57.85 MB)
    修改日期: 2011-06-29 05:50
    MD5: 9af271c0f016a450d3c1d531a07b2380
    SHA1: 43d43c0de47b42651b919c854bcb13500150c251
    SHA256: da37f20c4867978e593adc8fe6510e9b67b06e7b1a68858b029789100d06f33a
    CRC32: 39549aa8
    百度和NI官方下载地址:
    Internet2012.txt (267 Bytes, 下载次数: 13, 售价: 10 圆)
    LabVIEW 2012 Internet Toolkit Readme
    Version 12.0.0
    June 2012
    This file contains the following information about the LabVIEW 2012 Internet Toolkit.
    Changes in 2012
    Installation
       Version 2012 for Windows
       Version 2012 for Mac OX X and Linux
            Mac OS X
            Linux
    Changes in 2012
    The FTP VIs now ship with LabVIEW Base Edition instead of with the Internet Toolkit. To download the 2012 Internet Toolkit for free, refer to the National Instruments Web site.
    InstallationVersion 2012 for Windows
    The 2012 Internet Toolkit supports the Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit) editions. The 2012 Internet Toolkit does not support the Windows Server non-R2 editions.
    Version 2012 for Mac OS X and Linux
    Internet Toolkit 2012 is compatible with LabVIEW 2012. Internet Toolkit 6.0.2 is compatible with LabVIEW 8.6 through LabVIEW 2011. If you want to use Internet Toolkit with LabVIEW 8.5 or older, you must install Internet Toolkit 6.0.1.
    Before installing the LabVIEW Internet Toolkit 2012, uninstall any previous versions of the Internet Toolkit from the computer.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    (Mac OS X) If a previous version of the LabVIEW Internet Toolkit exists on the machine, complete the following steps to uninstall the previous version before you install Internet Toolkit 2012.
    • Navigate to the LabVIEW directory and drag the Internet_Toolkit_Uninstall.sh uninstallation script to the prompt in a Terminal Window. Press Return and follow the instructions provided by the script.
    • After uninstalling the Internet Toolkit, you must manually delete the uninstallation script.
    Complete the following steps to install the LabVIEW Internet Toolkit 2012 for Mac OS X.
    • Browse to the LabVIEW Internet Toolkit 2012 download folder and open NI_LabVIEW_2012_ITK.pkg.
    • Select Continue to run a program to determine if the Internet Toolkit can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Select Destination dialog box.
    • In the Select Destination dialog box, click the Choose button and select LabVIEW 2012.
    Note  You must click the Choose button for a proper installation. If you do not select a location where LabVIEW is installed or you select a non-compatible version of LabVIEW, the installation will not complete.
    • After you select the destination directory, click the Continue button to complete the installation.
    • (Optional) Mass compile the Internet Toolkit VIs. When you open a VI last saved in a previous version of LabVIEW, LabVIEW automatically converts and compiles the VI. You must save the VI in the current version of LabVIEW or the conversion process, which uses extra memory resources, occurs every time you access the VI. Because the Internet Toolkit supports multiple versions of LabVIEW, you might need to mass compile after you install.
      • Launch LabVIEW and select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
      • Navigate to the labview\vi.lib\addons\internet directory and click the Mass Compile button to mass compile the Internet Toolkit VIs.
    (Linux) Complete the following steps to install the Internet Toolkit 2012 for Linux.
    • Enter the following command to extract the installation script:
      tar -xf InternetToolkitLinux.tar
    • Enter the following command to run the installation script:
      sh ./INSTALL
    • Copy the lvexint.bin4 file to the Example Finder directory:
      /usr/local/natinst/share/example finder/1.0/products/labview/x.y/exbins/english
      where x.y is the version of LabVIEW to which you are installing the Internet Toolkit, such as 2012.
      • Navigate to the LabVIEW-2012\vi.lib\addons\internet directory and click the Mass Compile button to mass compile the Internet Toolkit VIs.
    The Internet Toolkit VIs Help contains reference information about the Internet Toolkit.
    (Windows) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»Search the LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to the Toolkits»Internet Toolkit VIs top-level topic.
    (Mac OS X, Linux) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»Internet Toolkit to launch the Internet Toolkit VIs Help.
    Refer to the labview\examples\internet directory for example VIs that demonstrate common tasks using the Internet Toolkit. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules»Internet in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2012 National Instruments Corporation. All rights reserved.
    (Windows) You can find end-user license agreements (EULAs) and third-party legal notices in the following locations:
    (Mac OS X, Linux) The following third-party legal notices apply to the Mac OS X and Linux platforms.
    • DOCUMENTATION NOTICE FOR THE MIT LICENSE
      This product includes code from jQuery 1.7.2, licensed by a third party or parties pursuant to the MIT License, and that is subject to the following notice(s):
      Copyright 2011, John Resig
      Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions:
      The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
      This product includes code from Sizzle, licensed by a third party or parties pursuant to the MIT License, and that is subject to the following notice(s):
      Copyright 2011, The Dojo Foundation
    GMT+8, 2026-1-29 09:48
