查看: 4509|回复: 5
[MVTEC] MVTEC MERLIC 4.4.2标准智能图像处理软件下载 非破解版 多国语言完整版
    昨天 11:29
  • 签到天数: 3774 天
    连续签到: 25 天
    发表于 2020-11-5 16:36:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    MVTEC公司出品Halcon同门小师弟MERLIC 4.4.2下载,本版本为非破解版,可以45天试用期。
    本帖版本为4.4.2正式版。包含多国语言包。发布日期2020.10。
    MERLIC为一款标准的智能软件,不需要太多编程知识,只需要拖动需要的功能模块,组成一定的工作流程,配置一下参数,完成配方配置,即可应用于机器视觉领域。同时MERLIC优化并行处理功能,可匹配多相机的工位应用。再加上其基于Halcon的底层,图像检测功能是非常优秀的。不过相对较贵的价格,2万+的人民币,一般个人可能承受不起。如有需要,可联系我方论坛购买大恒Pallas智星智能相机的批量许可证版本的MERLIC,该版本是大恒批发的MERLIC,绑定了大恒的PALLAS智星智能相机,即只能使用PALLAS智能相机(现阶段有两款带MERLIC软件的型号可选择,一个是全局的130万相机的PALLAS 6513M-M0(MERLIC全功能版),另一款为行曝光630万像素的PALLAS 6563M-M0(MERLIC全功能版),其它的相机如大恒水星MER、火星MARS、Basler、AVT等品牌的相机,都不支持。两款智能相机带MERLIC软件,2万以内可以拿下,详情可联系我方。如需要支持其它非PALLAS的工业相机的MERLIC,可购买独立版本的,价格2万以上。
    文件名: merlic-4.4.2-windows.exe
    文件大小: 666887136 字节 (635.99 MB)
    修改日期: 2020-11-05 12:37
    版本: 4.4.2.0
    MD5: cdfc5f1261a90c700423968df0341dfe
    SHA1: 30ee44f2afad6afca8c7a57e806f5f43356953c7
    SHA256: 85dbf96ece64b73a31d42cbeed1661b323fced059d01a404e0eca4ff19232539
    CRC32: eed1fc31
    MERLIC 4.4.2版本下载:
    链接:
    提取码: qr2c
    Release Notes for MERLIC 4.4.2
    Here you can read the release notes for MVTec MERLIC 4.4.2, as released in October 2020.
    Contents
    Licensing
    MERLIC 4.4.2 is available for Windows 7 and Windows 10 (64-bit operating system).
    During the installation, the environment variable MERLIC4EXAMPLES is set to C:\Users\Public\Documents\MVTec\MERLIC 4 by default. It contains the path to the directory in which additional files such as example applications or images are installed.
    Please refer to the "Readme" in the MERLIC manual for more information about the system requirements.
    Linux
    MERLIC 4.4.2 is available for selected Linux ARM 64-bit platforms. This edition requires a specific license that needs to be activated on the ARM device. Please contact MVTec to get more information about how to obtain this license. After the license activation, the ARM device also functions as a license dongle for the PC version of MERLIC 4.4.2, however, with some limitations.
    Please refer to the "Help → About" dialog in the MERLIC Backend for the respective limitations.
    Licensing
    Fixed Problems
    Several vulnerabilities in CodeMeter Runtime, the license management of MERLIC, have been disclosed on the website of WIBU Systems on September 8, 2020. Successful exploitation of these vulnerabilities could potentially lead to remote code execution or prevent normal operation of MERLIC. This problem has been fixed. This MERLIC version uses the updated CodeMeter Runtime version 7.10a which secures the remote access.
  • 签到天数: 2 天
    连续签到: 2 天
    发表于 2020-11-14 22:00:54 | 显示全部楼层 来自:美国 加利福尼亚州洛杉矶IT7网络
  • 签到天数: 9 天
    发表于 2021-6-30 08:42:47 | 显示全部楼层 来自:辽宁省沈阳市 联通
    df dsfasdsf dsfsdfddddddddddddddddddddddddddddddddddddddddddddddddd
    发表于 2022-10-19 18:34:15 | 显示全部楼层 来自:北京市昌平区 移动
  • 签到天数: 4 天
    发表于 2022-11-10 09:09:49 | 显示全部楼层 来自:江苏省无锡市 电信IDC机房
    GMT+8, 2026-1-17 06:40
