查看: 2734|回复: 0
[LV工具模块] LabVIEW Touch Panel Module 2011 Win32Eng LabVIEW触摸屏模块2011版下载
    昨天 07:58
  • 签到天数: 3547 天
    连续签到: 17 天
    发表于 2020-10-30 23:40:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW触摸屏模块
    LabVIEW触摸屏模块用于开发触摸屏计算机所需的应用程序。
    LabVIEW触摸屏模块是一款软件附加工具,可用于创建和部署人机界面(HMI)应用程序,以便与CompactRIO系统等嵌入式实时平台进行通信。此工具包含多种用户界面开发工具,并具有通信、数据分析和数据存储功能。借助该附加工具,即可通过共享变量、TCP/IP或其他协议与控制器进行通信。您还可以借助内置LabVIEW演示工具,向操作人员显示重要信息。LabVIEW触摸屏模块经过优化,可将HMI部署于运行Windows Embedded Standard系统的NI或第三方工业触摸屏计算机。
    2011
    文件大小: 116779616 字节 (111.37 MB)
    修改日期: 2011-06-29 06:18
    MD5: 946a0ef27550249fa0428f97d6167615(重复下载一致)
    SHA1: 890914d5d51b247f06ccdaf48c19cb24f8ee28d8
    SHA256: 7f7dec96eec71c46f2cacd9067a98ab59aa7915f9a2722e8f955e74433053b6f
    CRC32: 9b709396
    TPM2011.txt (259 Bytes, 下载次数: 0, 售价: 2 元)
    LabVIEW 2011 Touch Panel Module Readme
    Version 11.0
    June 2011
    This file contains important last-minute information about the LabVIEW 2011 Touch Panel Module, including installation issues.
    Installing the Touch Panel Module
    Resources
    Important Information
    The Touch Panel Module has the following system requirements:
    • LabVIEW 2011 Base, Full, or Professional Development System (32-bit)
    • 250 MB available disk space
    • (Windows CE) A Touch Panel device, such as the NI TPC-2006, running Windows CE 4.2 or 5.0
    • (Windows Embedded Standard) A Touch Panel device, such as the NI TPC-2512, running Windows Embedded Standard
    The Touch Panel Module supports the following operating systems:
    • Windows XP SP2 or later (32-bit)
    The Touch Panel Module does not support Windows NT/Me/98/95/2000 or the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the Touch Panel Module—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the Touch Panel Module along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Additional Installation Information
    This section contains information that you might find helpful as you install the Touch Panel Module.
    • The Touch Panel Module runs in evaluation mode if you do not activate it. In evaluation mode, you can create VIs, but any Touch Panel applications you build run only for five minutes. You have the option of activating the Touch Panel Module during the installation process. You also can use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate National Instruments products. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the NI License Manager, for more information about activating NI products.
    • The Touch Panel Module includes Microsoft tools, such as Microsoft ActiveSync on Windows XP. Some of these Microsoft tools might interfere with any existing installations of Visual Studio, Windows Embedded, or Windows CE toolkits.
    • (Windows XP) The Touch Panel Module installs ActiveSync 4.2 if you do not already have ActiveSync 4.2 or later installed. The Touch Panel Module works with ActiveSync 4.2 or later.
    • (Windows 7/Vista) You must install Windows Mobile Device Center to use the Touch Panel Module. Refer to the Microsoft Web site at www.microsoft.com to download Windows Mobile Device Center.
    • You might need to install the additional tools, such as NI-DAQmxBase, NI TPC Service support, Shared Variable support, or NI-VISA, to use the Touch Panel Module. Refer to the Installing Additional Tools section of the Getting Started with the LabVIEW Touch Panel Module manual for more information about additional tools.
    Uninstalling the Touch Panel Module (Windows CE)
    If you uninstall the Touch Panel Module, you also must uninstall the following:
    • (Windows XP) Microsoft ActiveSync
    • (Windows 7/Vista) Windows Mobile Device Center
    • Microsoft Device Emulator version 1.0 – ENU
    • Microsoft Visual C++ 2005 Redistributable
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 Touch Panel Module.
    The following table contains the IDs and titles of fixed issues in LabVIEW 2011 Touch Panel Module. This table is not an exhaustive list of issues fixed in the current version of the Touch Panel Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    222189Documentation doesn't state that Histograms are not supported on Touch Panels.
    Resources
    LabVIEW includes extensive online and PDF documentation for new and experienced LabVIEW users. Refer to the Related Documentation section in the Getting Started with the Touch Panel Module manual for more information about LabVIEW documentation. Visit the National Instruments Web site at ni.com for software drivers and updates, a searchable KnowledgeBase, product manuals, step-by-step troubleshooting wizards, thousands of example programs, tutorials, application notes, instrument drivers, and so on.
    © 2011 National Instruments Corporation. All rights reserved.
    举报
    GMT+8, 2025-5-23 00:21
