NI CompactRIO Module Support 17.1.0 Patch Win32Eng/Jpn/Chs NI-CompactRIO模块支持17.1.0补丁
NI CompactRIO模块支持
NI CompactRIO Module Support支持CompactRIO控制器、CompactRIO机箱和CompactRIO单板控制器。
NI CompactRIO Module Support是一个驱动软件,用于支持CompactRIO系统的识别、编程和部署。除LabVIEW之外,您还必须安装NI CompactRIO Module Support以及LabVIEW Real-Time模块和/或LabVIEW FPGA模块,才能开始对硬件进行编程。
17.1.0安装补丁之前请先安装NI CompactRIO 17.0。
文件大小: 95330312 字节 (90.91 MB)
修改日期: 2017-09-30 01:30
MD5: 75c15d623c53e682f107c4aeb04ac73d(官方正确)
SHA1: 6b623de49af69bf64e575c1de8220a1eec99db2a
SHA256: 74ccdc34bfe34928ad2bcf60a3b423c1715dd013f1639caaddec25ef03464e07
CRC32: 678cdc71
NICRIOMS17.1.0.txt
(335 Bytes, 下载次数: 0, 售价: 1 圆)
NI CompactRIO Module Support 17.1 ReadmeAugust 2017 This document contains important information about installing NI CompactRIO Module Support 17.1, descriptions of known issues for installing and using NI CompactRIO Module Support 17.1, and information about the hardware and software that NI CompactRIO Module Support 17.1 supports. - Installing NI CompactRIO Module Support 17.1
- What's New in NI CompactRIO Module Support 17.1
- Preserving Device Aliases when Upgrading Software
- Bug Fixes
- Known Issues
- Accessing the Help
- Supported Platforms
- Supported Hardware and Software
- Product Security and Critical Updates
- Automating the Installation of NI Products
- Using NI Software with Microsoft Windows 10
- Using NI Software with Microsoft Windows 8.1
- Legal Information
Installing NI CompactRIO Module Support 17.1Complete the following steps to install NI CompactRIO Module Support 17.1 for use with LabVIEW. - Install LabVIEW 2017.
- Install the LabVIEW Real-Time Module.
- Install the LabVIEW FPGA Module.
- Install NI CompactRIO Device Drivers May 2017.
- Install NI CompactRIO Module Support 17.1.
Other Installation Notes- This installation requires that MSI Engine version 3.1 is installed on your computer. If you do not have MSI Engine version 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.
- If you are installing NI driver software on Microsoft Windows Vista, you must first uninstall all National Instruments software versions older than the February 2007 release before you proceed with this installation. Refer to the How Do I Remove Unsupported NI Software from Windows Vista to Install Officially Supported Versions? support document on ni.com for additional information and tools to assist you in upgrading NI driver software on Windows Vista.
- If you want to install from a network location, copy the entire contents of the installation disk to a single folder and run from that location.
↑ Back to Top What's New in NI CompactRIO Module Support 17.1This release adds support for the following new hardware and functionality in LabVIEW 2017: - NI 9202 C Series module
- NI 9262 C Series module
- sbRIO-9698
↑ Back to Top Preserving Device Aliases when Upgrading SoftwareEnsure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade. ↑ Back to Top Bug FixesRefer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release. ↑ Back to Top Known IssuesRefer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release. ↑ Back to Top Accessing the HelpIn the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your C Series device. ↑ Back to Top Supported PlatformsNI CompactRIO Module Support 17.1 supports the following platforms: | Operating System | 64-bit | 32-bit | Comments | | Windows 10 | ✓ | ✓ | Refer to the Using NI Software with Microsoft Windows 10 section of this document for more information about using NI CompactRIO Module Support on Windows 10. | | Windows 8.1 Update 11 | ✓ | ✓ | Refer to the Using NI Software with Microsoft Windows 8.1 section of this document for more information about using NI CompactRIO Module Support on Windows 8.1. | | Windows 7 Professional SP12 | ✓ | ✓ | — | | Windows Server 2012 R2 Update1 | ✓ | — | — | | Windows Server 2008 R2 SP12 | ✓ | — | — | Notes:
1 NI software installs VC2015 Runtime and .NET Framework 4.6.1. Windows 8.1 Update 1 and Windows Server 2012 R2 Update require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. |
↑ Back to Top Supported Hardware and SoftwareRefer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO Module Support. Visit to ni.com/compactrio for additional CompactRIO product support and information. ↑ Back to Top Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. ↑ Back to Top Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
↑ Back to Top Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. ↑ Back to Top Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. ↑ Back to Top Legal InformationCopyright © 2004–2017 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
375025H-01 |
