查看: 2709|回复: 0
[Patch补丁] NI CompactRIO Module Support 15.1.0 Patch Win32Eng/Jpn/Chs NI-CompactRIO模块支持15.1.0补丁
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-10-29 23:14:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO模块支持
    NI CompactRIO Module Support支持CompactRIO控制器、CompactRIO机箱和CompactRIO单板控制器。
    NI CompactRIO Module Support是一个驱动软件,用于支持CompactRIO系统的识别、编程和部署。除LabVIEW之外,您还必须安装NI CompactRIO Module Support以及LabVIEW Real-Time模块和/或LabVIEW FPGA模块,才能开始对硬件进行编程。
    15.1.0安装补丁之前请先安装NI-RIO 14.5.0。
    文件大小: 204142943 字节 (194.69 MB)
    修改日期: 2015-09-22 01:20
    MD5: 056344f9d4ecf4f8e213a2c4693d3e10(官方正确)
    SHA1: 968ea5c29338164e47909c87c256c64217516b75
    SHA256: e1a8e60ab330ff1375ed71cd6de364409b29607c6d0ae168a92e092c1377bc9e
    CRC32: 0163dabf
    NICRIOMS15.1.0.txt (365 Bytes, 下载次数: 0, 售价: 1 圆)
    NI CompactRIO Module Support 15.1 Readme
    September 2015
    This document contains important information about installing NI CompactRIO Module Support 15.1, descriptions of known issues for installing and using NI CompactRIO Module Support 15.1, and information about the hardware and software that NI CompactRIO Module Support 15.1 supports.
    • Installing NI CompactRIO Module Support 15.1
    • What's New in NI CompactRIO Module Support 15.1
    • Driver Version Naming Changes
    • Bug Fixes
    • Known Issues
    • Accessing the Help
    • Supported Platforms
    • Supported Hardware and Software
    • Product Security and Critical Updates
    • How to Use NI Software with Microsoft Windows 8.1/8.0
    • NI CompactRIO Module Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    • Legal Information
    Complete the following steps to install NI CompactRIO Module Support 15.1 for use with LabVIEW.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2015
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers August 2015.
    • Install NI CompactRIO Module Support 15.1.
    Other Installation Notes
    • This installation requires that MSI Engine version 3.1 is installed on your computer. If you do not have MSI Engine version 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.
    • If you are installing NI driver software on Microsoft Windows Vista, you must first uninstall all National Instruments software versions older than the February 2007 release before you proceed with this installation. Refer to the How Do I Remove Unsupported NI Software from Windows Vista to Install Officially Supported Versions? support document on ni.com for additional information and tools to assist you in upgrading NI driver software on Windows Vista.
    • If you want to install from a network location, copy the entire contents of the installation disk to a single folder and run from that location.
    ↑ Back to Top
    • Support for the following new hardware in LabVIEW 2015:
      • NI 9251
      • NI 9770
    ↑ Back to Top
    NI CompactRIO Module Support versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with.
    Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI CompactRIO Module Support 15.0 is the version released with LabVIEW 2015.
    The last version released under the old numbering scheme is NI CompactRIO Module Support 4.1. The first version released under the new numbering scheme is NI CompactRIO Module Support 13.0.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    ↑ Back to Top
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your C Series device.
    ↑ Back to Top
    Supported Platforms
    NI CompactRIO Module Support 15.1 supports the following platforms:
    Operating System64-bit32-bitComments
    Windows 8.1/8.0
    Refer to the How to Use NI Software with Microsoft Windows 8.1/8.0 section of this document for more information about NI CompactRIO Module Support on Windows 8.1/8.0.
    Windows 7 Professional
    Windows Vista Business
    Refer to the NI CompactRIO MOdule Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016 section of this document for more information about NI CompactRIO Module Support support for those versions.
    Windows XP Professional SP2
    Windows Server 2012 R2
    Windows Server 2008 R2
    Windows Server 2003 R2
    Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    ↑ Back to Top
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO Module Support.
    Visit to ni.com/compactrio for additional CompactRIO product support and information.
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    When you install National Instruments software on Microsoft Windows 8.1/8.0, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1/8.0. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Windows 8.1/8.0 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1/8.0 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1/8.0 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    For more information about NI support for Windows 8.1/8.0, visit ni.com/windows8.
    ↑ Back to Top
    NI CompactRIO Module Support will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI CompactRIO Module Support that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    ↑ Back to Top
    © 2004–2015 National Instruments. All rights reserved.
    375025D-01
    GMT+8, 2025-10-29 12:19
