NI CompactRIO Module Support 14.1.1 Patch Win32Eng/Jpn/Chs NI-CompactRIO模块支持14.1.1补丁
NI CompactRIO模块支持
NI CompactRIO Module Support支持CompactRIO控制器、CompactRIO机箱和CompactRIO单板控制器。
NI CompactRIO Module Support是一个驱动软件,用于支持CompactRIO系统的识别、编程和部署。除LabVIEW之外,您还必须安装NI CompactRIO Module Support以及LabVIEW Real-Time模块和/或LabVIEW FPGA模块,才能开始对硬件进行编程。
14.1.1安装补丁之前请先安装NI-RIO 2014。
文件名: NI CompactRIO Module Support\CompactRIO Module Support 14.1.1.zip
文件大小: 292771623 字节 (279.21 MB)
修改日期: 2015-04-22 23:05
MD5: 9f5d735e0d157d9a0e402643ff3c159c(官方正确)
SHA1: 3d60341c4485d46ff2409c0b0bda2a9d8e36be39
SHA256: 4c3fce8320ec4a064c73fb97628cfc1c9c74d566eb93d0944e4bc13b30c2f909
CRC32: 5221a74d
NICRIOMS14.1.1.txt
(364 Bytes, 下载次数: 0, 售价: 1 圆)
NI CompactRIO Module Support 14.1.1 ReadmeApril 2015 ni.com/support This document contains important information about installing NI CompactRIO Module Support 14.1.1, descriptions of known issues for installing and using NI CompactRIO Module Support 14.1.1, and information about the hardware and software that NI CompactRIO Module Support 14.1.1 supports. - Installing NI CompactRIO Module Support 14.1.1
- What's New in NI CompactRIO Module Support 14.1.1
- Bug Fixes
- Known Issues
- Supported Platforms
- Supported Hardware and Software
- Product Security and Critical Updates
- Automating the Installation of NI Products
- How to Use NI Software with Microsoft Windows 8.x
- NI CompactRIO Module Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
Installing NI CompactRIO Module Support 14.1.1Complete the following steps to install NI CompactRIO Module Support 14.1.1 for use with LabVIEW. - Install one of the following supported versions of LabVIEW:
- LabVIEW 2014
- LabVIEW 2013 SP1
- LabVIEW 2012 SP1
- LabVIEW 2011 SP1
- Install LabVIEW Real-Time.
- Install LabVIEW FPGA.
- Install NI CompactRIO 14.0.
- Install NI CompactRIO Module Support 14.1.1.
Other Installation Notes- This installation requires that MSI Engine version 3.1 is installed on your computer. If you do not have MSI Engine version 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.
- If you are installing NI driver software on Microsoft Windows Vista, you must first uninstall all National Instruments software versions older than the February 2007 release before you proceed with this installation. Refer to the How Do I Remove Unsupported NI Software from Windows Vista to Install Officially Supported Versions? support document on ni.com for additional information and tools to assist you in upgrading NI driver software on Windows Vista.
- If you want to install from a network location, copy the entire contents of the installation disk to a single folder and run from that location.
↑ Back to Top What's New in NI CompactRIO Module Support 14.1.1This release provides support for the following C Series modules: ↑ Back to Top Bug Fixes| Issue ID | Description | | 498902 | Fixed an issue in which you cannot compile a Hybrid Interface mode bitfile for the following devices in LabVIEW 2014:- NI cRIO-903x
- NI cRIO-906x
- NI 9147/9
| | 519539 | Fixed a compilation compatibility issue for bitfiles containing NI 926x modules in combination with the 2014 SP1 version of Xilinx Compilation Tools. |
Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release. ↑ Back to Top Known IssuesRefer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release. ↑ Back to Top Supported PlatformsNI CompactRIO Module Support 14.1.1 supports the following platforms: | Operating System | 64-bit | 32-bit | Comments | | Windows 8.x | ✔ | ✔ | Refer to the How to Use NI Software with Microsoft Windows 8.x section of this document for more information about NI CompactRIO Module Support on Windows 8.x. | | Windows 7 Professional | ✔ | ✔ | — | | Windows Vista Business | ✔ | ✔ | Refer to the NI CompactRIO MOdule Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016 section of this document for more information about NI CompactRIO Module Support support for those versions. | | Windows XP Professional SP2 | — | ✔ | | Windows Server 2012 R2 | ✔ | — | — | | Windows Server 2008 R2 | ✔ | — | — | | Windows Server 2003 R2 | — | ✔ | Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport. |
↑ Back to Top Supported Hardware and SoftwareRefer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO Module Support. Visit to ni.com/compactrio for additional CompactRIO product support and information.
↑ Back to Top Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. ↑ Back to Top Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
↑ Back to Top How to Use NI Software with Microsoft Windows 8.xWhen you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile in the Apps view. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. | Note NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch NI MAX either from the Apps view or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: | Current Application | Icon Location | Pin to Action | | Windows 8.x Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | | Windows 8.x Desktop | Start screen | Right-click application and select Pin to Start | | Windows 8.x Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8) or click the down arrow on the bottom left of the screen (Windows 8.1). For more information about NI support for Windows 8.x, visit ni.com/windows8. ↑ Back to Top NI CompactRIO Module Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016NI CompactRIO Module Support will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI CompactRIO Module Support that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | NI LabVIEW | lifecycle | | NI LabWindows™/CVI™ | cvi_lifecycle | | NI Measurement Studio | mstudiolifecycle | | NI TestStand | tslcp | | NI DIAdem | ddlcp | | NI SignalExpress | selcp | | NI VeriStand | nivslifecycle |
↑ Back to Top Legal InformationCopyright © 2004–2015 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents
For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
