查看: 2708|回复: 0
[Patch补丁] NI CompactRIO Module Support 12.0.1 Patch Win32Eng/Jpn/Chs NI-CompactRIO模块支持12.0.1补丁
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-10-29 23:02:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO模块支持
    NI CompactRIO Module Support支持CompactRIO控制器、CompactRIO机箱和CompactRIO单板控制器。
    NI CompactRIO Module Support是一个驱动软件,用于支持CompactRIO系统的识别、编程和部署。除LabVIEW之外,您还必须安装NI CompactRIO Module Support以及LabVIEW Real-Time模块和/或LabVIEW FPGA模块,才能开始对硬件进行编程。
    12.0.1安装补丁之前请先安装NI-RIO 12.0。
    文件大小: 147333735 字节 (140.51 MB)
    修改日期: 2012-08-14 22:55
    MD5: c95d62d97ac544d2044b9bc322e06aad(官方正确)
    SHA1: 49f1ebab0b01fb2f0bca141f10d74555ca394d36
    SHA256: 5b5247a6fddd9a5625ec308aeb9c7eb3cd558bad5543659875d79dde1419f6e6
    CRC32: 0e2bed06
    NICRIOMS12.0.1.txt (362 Bytes, 下载次数: 0, 售价: 1 圆)
    NI CompactRIO Module Support 12.0.1 Readme
    August 2012
    ni.com/support
    This file contains important information about NI CompactRIO Module Support 12.0.1, including information on installing NI CompactRIO Module Support 12.0.1, descriptions of known issues for installing and using NI CompactRIO Module Support 12.0.1, and information about the hardware and software supported by NI CompactRIO Module Support 12.0.1.
    • Installing NI CompactRIO Module Support 12.0.1
    • What Is New in NI CompactRIO Module Support 12.0.1
    • Supported Platforms
    • Supported Hardware and Software
    Complete the following steps to install NI CompactRIO Module Support 12.0.1 for use with LabVIEW.
    • Install LabVIEW.
    • Install LabVIEW Real-Time.
    • Install LabVIEW FPGA.
    • Install NI CompactRIO 12.0.
    • Install NI CompactRIO Module Support 12.0.1.
    Supported Versions of LabVIEW
    • LabVIEW 2012
    • LabVIEW 2011 SP1
    • LabVIEW 2010 SP1
    Back to Top
    • Support for NI 9683 in LabVIEW 2012
    Back to Top
    Supported Platforms
    NI CompactRIO Module Support 12.0.1 supports the following platforms:
    • Windows 7 Professional (32-bit and 64-bit)
    • Windows Vista Business (32-bit and 64-bit)
    • Windows XP Professional SP2
    • Windows Server 2003 (32-bit)
      Note: Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport
    Back to Top
    NI CompactRIO Module Support 12.0.1 provides support for C Series modules in all CompactRIO, Single-Board RIO, and R Series systems. Refer to the NI Developer Zone at ni.com for a complete list of the hardware that is supported by this and previous versions of NI CompactRIO as well as what versions of LabVIEW software are supported by each version of NI CompactRIO.
    For additional CompactRIO product support and information, refer to ni.com/compactrio.
    Back to Top
    Other Installation Notes
    This installation requires that version 3.1 of the MSI (Windows Installer) Engine is installed on your computer. If you do not have MSI 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.If you are installing NI driver software on Windows Vista, you must first uninstall all National Instruments software versions older than the February 2007 release before proceeding with this installation. For additional information and tools to assist you in upgrading NI driver software on Windows Vista, refer to KnowledgeBase article 46BH366K at ni.com/kb.If you want to install from a network location, copy the entire contents of the installation disk to a single folder and run from that location.
    Uninstallation Instructions
    You can uninstall NI software and drivers by selecting National Instruments Software in the Windows Add/Remove Programs application.
    Important Information
    © 2004–2012 National Instruments. All rights reserved.
    GMT+8, 2025-10-29 12:18
