NI-XNET 18.5 Runtime Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序18.5运行时下载
NI-XNET
18.5Runtime
文件大小: 188171764 字节 (179.45 MB)
修改日期: 2019-06-25 02:43
MD5: bb5b63fab4b44a005583a4443caad9dd(官方正确)
SHA1: 3ea3c6fcfb7614e4a283766368a2d9198493ac2f
SHA256: 11e2d316e379fdd9973735dfed5ea6375d968ca304cf4107803c569b4b2fb02e
CRC32: 1770de69
NI-XNET18.5RT.txt
(287 Bytes, 下载次数: 2, 售价: 5 圆)
NI-XNET 18.5 ReadmeNovember 2018 This file contains important information about NI-XNET, including installation instructions and known issues. Overview Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features and Changes Supported Hardware Known Issues Bug Fixes Additional Programming Topics Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 LabVIEW NXG Support and Considerations Legal Information OverviewNI-XNET is an NI instrument driver that features a common set of easy-to-use functions for reading and writing CAN, LIN, and FlexRay frames and signals in many different platforms including USB, PXI, PCI, NI CompactDAQ, and NI CompactRIO. Supported Operating SystemsNI-XNET supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Embedded Standard 7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions. NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems. Application Software SupportThe following table lists the application software versions supported by NI-XNET. Application Software1 | Versions Supported by NI-XNET 18.5 | LabVIEW | 2015, 2016, 2017, and 2018 | LabVIEW Real-Time (RT) | 2015, 2016, 2017, and 2018 | LabVIEW NXG | 3.0 | LabWindows™/CVI™ | 2012 and later | 1 Application software support for LabVIEW NXG is not included with NI-XNET and must be downloaded separately via NI Package Manager. Refer to Installing NI-XNET for LabVIEW NXG for instructions. | Microsoft Visual Studio SupportNI-XNET supports the following Microsoft Visual Studio versions and associated programming languages. Programming Languages | Versions Supported by NI-XNET 18.5 | Microsoft Visual C/C++ | 6.0 and later | Installation InstructionsRefer to the following instructions to install NI-XNET from a DVD. To install NI-XNET for LabVIEW NXG, refer to Installing NI-XNET for LabVIEW NXG. Before installing the NI-XNET software, log on as Administrator or as a user with Administrator privileges. The NI-XNET software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-XNET software. - Insert the NI-XNET software DVD into the DVD drive. If the installer does not launch automatically, navigate to the DVD using Windows Explorer and launch the autorun.exe file from your NI-XNET software DVD.
- Click Install.
- The installation wizard guides you through the necessary steps to install the NI-XNET software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
- When the installation is complete, click Finish.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New Features and ChangesNew NI-XNET 18.5 Features and Changes as Compared to NI-XNET 18.0The NI-XNET 18.5 release adds the following features: - Added support for LabVIEW NXG 3.0.
- Added support for LabVIEW 2018 SP1.
- Added support for the USB-8501 NI-XNET CAN LS/FT Interface.
- Added support for importing CAN FD settings from FIBEX 4.1.2 databases.
- Added support for J1939 session property, SAE J1939:Include Destination Address in PGN, in LabVIEW NXG.
The NI-XNET 18.5 release changes the following: - Lowered the default value for the nxPropSession_J1939ResponseTimeTrSD property from 0.05 s to 0 s to improve performance in handling multipacket messages.
- Improved performance when opening large database files.
- Removed support for LabVIEW NXG 2.0 and 2.1.
New NI-XNET 18.0 Features and Changes as Compared to NI-XNET 17.5.1The NI-XNET 18.0 release adds the following features: - Added ability in System Designer to discover XNET hardware ports and select new names for them. (LabVIEW NXG)
- Added a new J1939 session property, SAE J1939:Include Destination Address in PGN. (C and LabVIEW 2018 only)
- Added support for LabVIEW NXG 2.1.
- Added support for LabVIEW 2018.
The NI-XNET 18.0 release changes the following: - Removed support for LabVIEW 2014.
New NI-XNET 17.5.1 Features and Changes as Compared to NI-XNET 17.5The NI-XNET 17.5.1 release changes the following: - Bug Fix for cDAQ-9171 support.
New NI-XNET 17.5 Features and Changes as Compared to NI-XNET 17.0.1The NI-XNET 17.5 release adds the following features: New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0The NI-XNET 17.0.1 release changes the following: - Bug Fix for LabVIEW 64-bit support.
New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1The NI-XNET 17.0 release adds the following features: The NI-XNET 17.0 release changes the following: - Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
- Removed support for LabVIEW 2013.
- Removed support for CVI 2010.
New NI-XNET 16.1 Features and Changes as Compared to NI-XNET 16.0The NI-XNET 16.1 release adds the following features: - Added support for the USB-8502 and USB-8506.
- Added C-API examples for J1939.
- Enabled setting a custom baud rate for ISO CAN FD in the Bus Monitor and Database Editor.
- Enabled excluding IDs in the Bus Monitor.
- Enabled setting a node address for J1939 in the Bus Monitor.
The NI-XNET 16.1 release changes the following: - Removed support for CVI 8.5, 9.0, and 2009.
Supported Hardware- USB-8501 (Low-Speed/Fault-Tolerant CAN)
- USB-8502 (High-Speed/FD CAN)
- USB-8506 (LIN)
- PCI-8511 (Low-Speed/Fault-Tolerant CAN)
- PCI-8512 (High-Speed/FD CAN)
- PCI-8513 (Software-Selectable/FD CAN)
- PCI-8516 (LIN)
- PCI-8517 (FlexRay)
- PCIe-8510 (Hardware-Selectable)
- PXI-8511 (Low-Speed/Fault-Tolerant CAN)
- PXI-8512 (High-Speed/FD CAN)
- PXI-8513 (Software-Selectable/FD CAN)
- PXI-8516 (LIN)
- PXI-8517 (FlexRay)
- PXIe-8510 (Hardware-Selectable)
- TRC-8542 NI-XNET CAN HS/FD Transceiver Cable
- TRC-8543 NI-XNET CAN XS (LS/FT, HS/FD)Transceiver Cable
- TRC-8546 NI-XNET LIN Transceiver Cable
C Series modules: - NI 9860 (C Series Hardware-Selectable)
- NI 9861 (C Series Low-Speed CAN)
- NI 9862 (C Series High-Speed/FD CAN)
- NI 9866 (C Series LIN)
Supported platforms for XNET C Series modules: - CompactDAQ—NI-DAQmx 15.0 (or later) is required for:
- USB Chassis: cDAQ-9171, cDAQ-9174, and cDAQ-9178
- Ethernet Chassis: cDAQ-9181, cDAQ-9184, and cDAQ-9188
- Wireless Chassis: cDAQ-9191
- cDAQ Controller: cDAQ-9138 (Windows and RT) and cDAQ-9139 (Windows and RT)
- cDAQ Controller: cDAQ-9132 (Windows and RT) and cDAQ-9134 (Windows and RT)
- cDAQ Controller: cDAQ-9133 (Windows and RT) and cDAQ-9135 (Windows and RT)
- CompactDAQ—NI-DAQmx 15.1 (or later) is required for:
- USB Chassis: cDAQ-9179
- cDAQ Controller: cDAQ-9136 (Windows and RT) and cDAQ-9137 (Windows and RT)
- CompactDAQ—NI-DAQmx 17.1 (or later) is required for:
- Ethernet Chassis: cDAQ-9185 and cDAQ-9189
- CompactRIO—CompactRIO 18.0 (or later) and LabVIEW 2015 (or later) are required for the following targets:
- LabVIEW FPGA is required to build and deploy a bitstream with NI 986x modules in the project, unless otherwise specified.
- Real-Time Controller: cRIO-9012, cRIO-9014, cRIO-9022, cRIO-9023, cRIO-9024, and cRIO-9025
- CompactRIO Reconfigurable Chassis: cRIO-9111, cRIO-9112, cRIO-9113, cRIO-9114, cRIO-9116, and cRIO-9118
- Integrated CompactRIO Real-Time Controller: cRIO-9081, cRIO-9082, cRIO-906x, and cRIO-903x
- Single-Board RIO: sbRIO-9627, sbRIO-9607
- CompactRIO Real-Time Controller: cRIO-9032, cRIO-9037
- When using a cRIO-903x or cRIO-906x, a bitstream is not needed with NI 986x modules in the project.
- CompactRIO—CompactRIO 18.0 (or later) and LabVIEW 2016 (or later) are required for the following targets:
- CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
- When using a cRIO-903x, a bitstream is not needed with NI 986x modules in the project.
- CompactRIO—CompactRIO 18.0 (or later) and LabVIEW 2017 (or later) are required for the following targets:
- CompactRIO Real-Time Controller: cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9047, cRIO-9048, and cRIO-9049
- When using a cRIO-904x, NI 986x modules will only be usable in Real-Time mode, and no bitstream is necessary.
Note The NI-XNET software supports only National Instruments CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products. Known IssuesIssue Number | Summary | 672838 | Inserting a USB-850x device can result in an unusable device with internal errors on PharLap. Workaround: Remove and reinsert the device or reboot the system. | 687624 | NI-XNET CAN FD sessions (non-BRS) require CAN FD Baudrate to be set. | 696254 | NI-XNET may incorrectly set the CAN I/O Mode for CAN FD clusters and frames imported from databases that comply with ARXML 4.2 or later. | 697677 | NI-XNET does not import the DBC BO_TX_BU property from DBC files and prevents a TX frame from being mapped to multiple transmit ECUs. | 703292 | The J1939 address claim procedure does not detect conflicts between two ECUs running on the same XNET interface. | 704022 | NI-XNET Read CAN Frames can return fewer than the requested number of J1939 frames without reporting an error as specified in the documentation. | 705533 | Frame Out Queued sessions do not retransmit cyclic J1939 frames with payloads greater than 8 bytes. These transmit one time when the session starts, then only when new data is written to the session. | 705671 | Switching a J1939 session to a different ECU Node Name does not use the address from the new ECU, even if that ECU has already claimed an address. The node address must be set after the node name to properly configure the session. | 710192 | The NI-XNET Database Editor does not allow you to create a signal with the same name as one previously deleted. Avoid this issue by saving the database and re-opening it after deleting the signal. | 710389 | NI-XNET Wait (Transmit Complete) may cause a stale FlexRay frame to retransmit if the transmit queue is already empty. |
Bug FixesThe following items are the IDs and titles of a subset of issues fixed in this release. This is not an exhaustive list of issues fixed. If you have a CAR ID, you can search this list to validate that the issue has been fixed. Bug ID | Summary | 675253 | When using the Port Configuration Utility, it is not possible to rename ports beyond 160. | 684491 | In LabVIEW NXG, some XNET modules appear outside their PXI chassis in System Designer. | 684861 | NI-XNET cannot send or receive J1939 PDU1 broadcasts. | 684951 | Unaddressed J1939 Input Queue and Signal sessions do not receive data unless a stream session is also open on the interface. | 685825 | J1939 FIBEX databases that contain ECU names are not imported correctly, and saving the database will result in overwriting the name with 0. | 687144 | Extremely long strings passed to the XNET Create Session VI can cause LabVIEW to crash. | 687422 | Default value for the nxPropSession_J1939ResponseTimeTrSD property adversely affects performance. | 687562 | Rev C (and later) PCI/PXI-8511 and -8512 devices might switch to Bus Off when attempting to transmit immediately following a reboot or Self-Test. | 688639 | Having multiple startup VIs that contain NI-XNET project sessions can cause a LabVIEW RT target to hang. | 690135 | J1939 Address Claim does not behave properly when set through the ECU property rather than the Node Name and Node Address properties. | 691298 | TRC-8453 fails to communicate on first use after switching from LS to HS mode. | 695102 | NI-XNET crashes when opening DBC files containing very large signals, if the range is represented as an integer. | 696778 | The NI-XNET Session Property Node may apply active frame properties to the wrong frame, when the name of one frame is the prefix of another frame in the database. | 700188 | NI-XNET cannot import CAN FD settings from FIBEX 4.1.2 databases. | 704457 | J1939 ECUs are not destroyed when the last session using the ECU is closed, preventing other ECUs on the network from claiming the node address. | 705988 | Modifying the list of displayed signals in the NI-XNET Bus Monitor may result in incorrectly displayed unit name. | 708226 | Closing the Register Values dialog window when modifying a custom baud in the NI-XNET Bus Monitor or NI-XNET Database Editor may make the application unresponsive. |
Additional Programming TopicsNI-CAN CompatibilityIf you intend to use the NI-CAN API with NI-XNET hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual. Deployed databases on LabVIEW Real-Time targetsWhen upgrading the NI-XNET software on your LabVIEW Real-Time target, you need to re-deploy your database files to that target using a host computer that runs the same version of NI-XNET as the target. Removing and inserting C Series modules on CompactRIO targets during device communication is not supportedInserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage. This does not apply to controllers which support the NI-DAQmx programming method, such as the cRIO-904x family. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My NI Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using NI-XNET with LabVIEW NXG. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
Installing NI-XNET for LabVIEW NXGLabVIEW NXG is installed using NI Package Manager. Complete the following steps to install NI-XNET for LabVIEW NXG. - Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
- Click Download LabVIEW NXG.
- NI Package Manager installs, and then automatically opens a download window.
- Select LabVIEW NXG Suite, and click the green Install button.
- Select LabVIEW NXG and NI-XNET.
- Complete the installer instructions to download LabVIEW NXG and NI-XNET.
LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. Legal InformationCopyright © 2009–2018 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
374802M-01 |
