查看: 2584|回复: 0
[NI驱动程序] NI-XNET 18.5 Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序18.5下载
    半小时前
  • 签到天数: 3538 天
    连续签到: 8 天
    发表于 2020-10-20 23:38:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-XNET
    18.5
    文件大小: 725246061 字节 (691.65 MB)
    修改日期: 2019-06-25 02:43
    MD5: b4a3e1e67861eca602112293aac23049(官方正确)
    SHA1: 82b2c6c9489bd469d116a96519d081a996d841b8
    SHA256: 41273f84b8b902e41365f2acd0606bc65c2ebafecc0eeec3cf7eaaea22a66209
    CRC32: 7f9e8697
    NI-XNET18.5.txt (272 Bytes, 下载次数: 1, 售价: 10 元)
    NI-XNET 18.5 Readme
    November 2018
    This file contains important information about NI-XNET, including installation instructions and known issues.
    New Features and Changes
    Additional Programming Topics
    LabVIEW NXG Support and Considerations
    NI-XNET is an NI instrument driver that features a common set of easy-to-use functions for reading and writing CAN, LIN, and FlexRay frames and signals in many different platforms including USB, PXI, PCI, NI CompactDAQ, and NI CompactRIO.
    NI-XNET supports the following operating systems:
    • Windows 10/8.11/7 SP12
    The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions.
    NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems.
    The following table lists the application software versions supported by NI-XNET.
    Application Software1Versions Supported by NI-XNET 18.5
    2015, 2016, 2017, and 2018
    LabVIEW Real-Time (RT)
    LabVIEW NXG
    3.0
    LabWindows™/CVI™
    2012 and later
    1 Application software support for LabVIEW NXG is not included with NI-XNET and must be downloaded separately via NI Package Manager. Refer to Installing NI-XNET for LabVIEW NXG for instructions.
    NI-XNET supports the following Microsoft Visual Studio versions and associated programming languages.
    Programming LanguagesVersions Supported by NI-XNET 18.5
    Microsoft Visual C/C++
    6.0 and later
    Refer to the following instructions to install NI-XNET from a DVD. To install NI-XNET for LabVIEW NXG, refer to Installing NI-XNET for LabVIEW NXG.
    Before installing the NI-XNET software, log on as Administrator or as a user with Administrator privileges. The NI-XNET software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-XNET software.
    • Insert the NI-XNET software DVD into the DVD drive. If the installer does not launch automatically, navigate to the DVD using Windows Explorer and launch the autorun.exe file from your NI-XNET software DVD.
    • Click Install.
    • The installation wizard guides you through the necessary steps to install the NI-XNET software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    New Features and ChangesNew NI-XNET 18.5 Features and Changes as Compared to NI-XNET 18.0
    The NI-XNET 18.5 release adds the following features:
    • Added support for LabVIEW NXG 3.0.
    • Added support for LabVIEW 2018 SP1.
    • Added support for the USB-8501 NI-XNET CAN LS/FT Interface.
    • Added support for importing CAN FD settings from FIBEX 4.1.2 databases.
    • Added support for J1939 session property, SAE J1939:Include Destination Address in PGN, in LabVIEW NXG.
    The NI-XNET 18.5 release changes the following:
    • Lowered the default value for the nxPropSession_J1939ResponseTimeTrSD property from 0.05 s to 0 s to improve performance in handling multipacket messages.
    • Improved performance when opening large database files.
    • Removed support for LabVIEW NXG 2.0 and 2.1.
    New NI-XNET 18.0 Features and Changes as Compared to NI-XNET 17.5.1
    The NI-XNET 18.0 release adds the following features:
    • Added ability in System Designer to discover XNET hardware ports and select new names for them. (LabVIEW NXG)
    • Added a new J1939 session property, SAE J1939:Include Destination Address in PGN. (C and LabVIEW 2018 only)
    • Added support for LabVIEW NXG 2.1.
    • Added support for LabVIEW 2018.
    The NI-XNET 18.0 release changes the following:
    • Removed support for LabVIEW 2014.
    New NI-XNET 17.5.1 Features and Changes as Compared to NI-XNET 17.5
    The NI-XNET 17.5.1 release changes the following:
    • Bug Fix for cDAQ-9171 support.
    New NI-XNET 17.5 Features and Changes as Compared to NI-XNET 17.0.1
    The NI-XNET 17.5 release adds the following features:
    • Read LIN clusters from AUTOSAR 3.x and 4.x files.
      • Extract LIN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach LIN frames to the ECUs as "Rx/Tx."
      • Extract LIN cluster specific information (i.e. schedules and configuration frames).
      Notes  NI-XNET supports PDUs only if there is a 1:1 mapping between the PDU and frame layout. The import is limited to features supported by the NI-XNET driver.
    • Added user accessible checksum values to NI-XNET LIN frames.
    • Added support for ISC-178X smart cameras.
    • Added support for signals larger than 52 bits in the API and the Database Editor.
      • Signals up to 64 bits can be read/written as double floating point (rounded).
      • Signals of any size can be read/written as byte strings using a conversion session.
    New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0
    The NI-XNET 17.0.1 release changes the following:
    • Bug Fix for LabVIEW 64-bit support.
    New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1
    The NI-XNET 17.0 release adds the following features:
    • Support for LabVIEW 2017.
    • Support for PCIe-8510.
    • Read CAN clusters from AUTOSAR 3.x and 4.x files.
      • Extract CAN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach CAN frames to the ECUs as "Rx/Tx."
      • Extract CAN FD specific settings.
    The NI-XNET 17.0 release changes the following:
    • Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
    • Removed support for LabVIEW 2013.
    • Removed support for CVI 2010.
    New NI-XNET 16.1 Features and Changes as Compared to NI-XNET 16.0
    The NI-XNET 16.1 release adds the following features:
    • Added support for the USB-8502 and USB-8506.
    • Added C-API examples for J1939.
    • Enabled setting a custom baud rate for ISO CAN FD in the Bus Monitor and Database Editor.
    • Enabled excluding IDs in the Bus Monitor.
    • Enabled setting a node address for J1939 in the Bus Monitor.
    The NI-XNET 16.1 release changes the following:
    • Removed support for CVI 8.5, 9.0, and 2009.
    • USB-8501 (Low-Speed/Fault-Tolerant CAN)
    • USB-8502 (High-Speed/FD CAN)
    • USB-8506 (LIN)
    • PCI-8511 (Low-Speed/Fault-Tolerant CAN)
    • PCI-8512 (High-Speed/FD CAN)
    • PCI-8513 (Software-Selectable/FD CAN)
    • PCI-8516 (LIN)
    • PCI-8517 (FlexRay)
    • PCIe-8510 (Hardware-Selectable)
    • PXI-8511 (Low-Speed/Fault-Tolerant CAN)
    • PXI-8512 (High-Speed/FD CAN)
    • PXI-8513 (Software-Selectable/FD CAN)
    • PXI-8516 (LIN)
    • PXI-8517 (FlexRay)
    • PXIe-8510 (Hardware-Selectable)
    • TRC-8542 NI-XNET CAN HS/FD Transceiver Cable
    • TRC-8543 NI-XNET CAN XS (LS/FT, HS/FD)Transceiver Cable
    • TRC-8546 NI-XNET LIN Transceiver Cable
    C Series modules:
    • NI 9860 (C Series Hardware-Selectable)
    • NI 9861 (C Series Low-Speed CAN)
    • NI 9862 (C Series High-Speed/FD CAN)
    • NI 9866 (C Series LIN)
    Supported platforms for XNET C Series modules:
    • CompactDAQ—NI-DAQmx 15.0 (or later) is required for:
      • USB Chassis: cDAQ-9171, cDAQ-9174, and cDAQ-9178
      • Ethernet Chassis: cDAQ-9181, cDAQ-9184, and cDAQ-9188
      • Wireless Chassis: cDAQ-9191
      • cDAQ Controller: cDAQ-9138 (Windows and RT) and cDAQ-9139 (Windows and RT)
      • cDAQ Controller: cDAQ-9132 (Windows and RT) and cDAQ-9134 (Windows and RT)
      • cDAQ Controller: cDAQ-9133 (Windows and RT) and cDAQ-9135 (Windows and RT)
    • CompactDAQ—NI-DAQmx 15.1 (or later) is required for:
      • USB Chassis: cDAQ-9179
      • cDAQ Controller: cDAQ-9136 (Windows and RT) and cDAQ-9137 (Windows and RT)
    • CompactDAQ—NI-DAQmx 17.1 (or later) is required for:
      • Ethernet Chassis: cDAQ-9185 and cDAQ-9189
    • CompactRIO—CompactRIO 18.0 (or later) and LabVIEW 2015 (or later) are required for the following targets:
      • LabVIEW FPGA is required to build and deploy a bitstream with NI 986x modules in the project, unless otherwise specified.
      • Real-Time Controller: cRIO-9012, cRIO-9014, cRIO-9022, cRIO-9023, cRIO-9024, and cRIO-9025
      • CompactRIO Reconfigurable Chassis: cRIO-9111, cRIO-9112, cRIO-9113, cRIO-9114, cRIO-9116, and cRIO-9118
      • Integrated CompactRIO Real-Time Controller: cRIO-9081, cRIO-9082, cRIO-906x, and cRIO-903x
      • Single-Board RIO: sbRIO-9627, sbRIO-9607
      • CompactRIO Real-Time Controller: cRIO-9032, cRIO-9037
      • When using a cRIO-903x or cRIO-906x, a bitstream is not needed with NI 986x modules in the project.
    • CompactRIO—CompactRIO 18.0 (or later) and LabVIEW 2016 (or later) are required for the following targets:
      • CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
      • When using a cRIO-903x, a bitstream is not needed with NI 986x modules in the project.
    • CompactRIO—CompactRIO 18.0 (or later) and LabVIEW 2017 (or later) are required for the following targets:
      • CompactRIO Real-Time Controller: cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9047, cRIO-9048, and cRIO-9049
      • When using a cRIO-904x, NI 986x modules will only be usable in Real-Time mode, and no bitstream is necessary.
    Note  The NI-XNET software supports only National Instruments CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Issue NumberSummary
    672838
    Inserting a USB-850x device can result in an unusable device with internal errors on PharLap. Workaround: Remove and reinsert the device or reboot the system.
    687624
    NI-XNET CAN FD sessions (non-BRS) require CAN FD Baudrate to be set.
    696254
    NI-XNET may incorrectly set the CAN I/O Mode for CAN FD clusters and frames imported from databases that comply with ARXML 4.2 or later.
    697677
    NI-XNET does not import the DBC BO_TX_BU property from DBC files and prevents a TX frame from being mapped to multiple transmit ECUs.
    703292
    The J1939 address claim procedure does not detect conflicts between two ECUs running on the same XNET interface.
    704022
    NI-XNET Read CAN Frames can return fewer than the requested number of J1939 frames without reporting an error as specified in the documentation.
    705533
    Frame Out Queued sessions do not retransmit cyclic J1939 frames with payloads greater than 8 bytes. These transmit one time when the session starts, then only when new data is written to the session.
    705671
    Switching a J1939 session to a different ECU Node Name does not use the address from the new ECU, even if that ECU has already claimed an address. The node address must be set after the node name to properly configure the session.
    710192
    The NI-XNET Database Editor does not allow you to create a signal with the same name as one previously deleted. Avoid this issue by saving the database and re-opening it after deleting the signal.
    710389
    NI-XNET Wait (Transmit Complete) may cause a stale FlexRay frame to retransmit if the transmit queue is already empty.
    The following items are the IDs and titles of a subset of issues fixed in this release. This is not an exhaustive list of issues fixed. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Bug IDSummary
    675253When using the Port Configuration Utility, it is not possible to rename ports beyond 160.
    684491In LabVIEW NXG, some XNET modules appear outside their PXI chassis in System Designer.
    684861NI-XNET cannot send or receive J1939 PDU1 broadcasts.
    684951Unaddressed J1939 Input Queue and Signal sessions do not receive data unless a stream session is also open on the interface.
    685825J1939 FIBEX databases that contain ECU names are not imported correctly, and saving the database will result in overwriting the name with 0.
    687144Extremely long strings passed to the XNET Create Session VI can cause LabVIEW to crash.
    687422Default value for the nxPropSession_J1939ResponseTimeTrSD property adversely affects performance.
    687562Rev C (and later) PCI/PXI-8511 and -8512 devices might switch to Bus Off when attempting to transmit immediately following a reboot or Self-Test.
    688639Having multiple startup VIs that contain NI-XNET project sessions can cause a LabVIEW RT target to hang.
    690135J1939 Address Claim does not behave properly when set through the ECU property rather than the Node Name and Node Address properties.
    691298TRC-8453 fails to communicate on first use after switching from LS to HS mode.
    695102NI-XNET crashes when opening DBC files containing very large signals, if the range is represented as an integer.
    696778The NI-XNET Session Property Node may apply active frame properties to the wrong frame, when the name of one frame is the prefix of another frame in the database.
    700188NI-XNET cannot import CAN FD settings from FIBEX 4.1.2 databases.
    704457J1939 ECUs are not destroyed when the last session using the ECU is closed, preventing other ECUs on the network from claiming the node address.
    705988Modifying the list of displayed signals in the NI-XNET Bus Monitor may result in incorrectly displayed unit name.
    708226Closing the Register Values dialog window when modifying a custom baud in the NI-XNET Bus Monitor or NI-XNET Database Editor may make the application unresponsive.
    Additional Programming TopicsNI-CAN Compatibility
    If you intend to use the NI-CAN API with NI-XNET hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual.
    Deployed databases on LabVIEW Real-Time targets
    When upgrading the NI-XNET software on your LabVIEW Real-Time target, you need to re-deploy your database files to that target using a host computer that runs the same version of NI-XNET as the target.
    Removing and inserting C Series modules on CompactRIO targets during device communication is not supported
    Inserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage. This does not apply to controllers which support the NI-DAQmx programming method, such as the cRIO-904x family.
    The following sections detail considerations for using NI-XNET with LabVIEW NXG.
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install NI-XNET for LabVIEW NXG.
    • Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, and then automatically opens a download window.
    • Select LabVIEW NXG Suite, and click the green Install button.
    • Select LabVIEW NXG and NI-XNET.
    • Complete the installer instructions to download LabVIEW NXG and NI-XNET.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 2009–2018 National Instruments. All rights reserved.
    374802M-01
    GMT+8, 2025-5-13 08:39
