查看: 2965|回复: 0
[NI软件套件] NI-XNET 18.0 Runtime Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序18.0运行时下载
    8 小时前
  • 签到天数: 3535 天
    发表于 2020-10-20 23:36:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-XNET
    18.0Runtime
    文件大小: 183607872 字节 (175.10 MB)
    修改日期: 2019-06-25 02:43
    MD5: 1c721494276122b94493a1c66d4a1a8d(官方正确)
    SHA1: e112e8452f42d0e5a47d5b8edea7d9f06b45d378
    SHA256: 31b7de247904eeab857df64ab84b64d69450f5e57661c4dfac6b7adbfa8be478
    CRC32: 80124396
    NI-XNET18.0RT.txt (287 Bytes, 下载次数: 0, 售价: 5 元)
    NI-XNET 18.0 Readme
    May 2018
    This file contains important information about NI-XNET, including installation instructions and known issues.
    New Features and Changes
    Additional Programming Topics
    LabVIEW NXG Support and Considerations
    NI-XNET is an NI instrument driver that features a common set of easy-to-use functions for reading and writing CAN, LIN, and FlexRay frames and signals in many different platforms including USB, PXI, PCI, NI CompactDAQ, and NI CompactRIO.
    NI-XNET supports the following operating systems:
    • Windows 10/8.11/7 SP12
    The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions.
    NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems.
    The following table lists the application software versions supported by NI-XNET.
    Application Software1Versions Supported by NI-XNET 18.0
    2015, 2016, 2017, and 2018
    LabVIEW Real-Time (RT)
    LabVIEW NXG
    2.1
    LabWindows™/CVI™
    2013 and higher
    1 Application software support for LabVIEW NXG is not included with NI-XNET and must be downloaded separately via NI Package Manager. Refer to Installing NI-XNET for LabVIEW NXG for instructions.
    NI-XNET supports the following Microsoft Visual Studio versions and associated programming languages.
    Programming LanguagesVersions Supported by NI-XNET 18.0
    Microsoft Visual C/C++
    6.0 and later
    Refer to the following instructions to install NI-XNET from a DVD. To install NI-XNET for LabVIEW NXG, refer to Installing NI-XNET for LabVIEW NXG.
    Before installing the NI-XNET software, log on as Administrator or as a user with Administrator privileges. The NI-XNET software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-XNET software.
    • Insert the NI-XNET software DVD into the DVD drive. If the installer does not launch automatically, navigate to the DVD using Windows Explorer and launch the autorun.exe file from your NI-XNET software DVD.
    • Click Install.
    • The installation wizard guides you through the necessary steps to install the NI-XNET software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    New Features and ChangesNew NI-XNET 18.0 Features and Changes as Compared to NI-XNET 17.5.1
    The NI-XNET 18.0 release adds the following features:
    • Added ability in System Designer to discover XNET hardware ports and select new names for them. (LabVIEW NXG)
    • Added a new J1939 session property, SAE J1939:Include Destination Address in PGN. (C and LabVIEW 2018 only)
    • Added support for LabVIEW NXG 2.1.
    • Added support for LabVIEW 2018.
    The NI-XNET 18.0 release changes the following:
    • Removed support for LabVIEW 2014.
    New NI-XNET 17.5.1 Features and Changes as Compared to NI-XNET 17.5
    The NI-XNET 17.5.1 release changes the following:
    • Bug Fix for cDAQ-9171 support.
    New NI-XNET 17.5 Features and Changes as Compared to NI-XNET 17.0.1
    The NI-XNET 17.5 release adds the following features:
    • Read LIN clusters from AUTOSAR 3.x and 4.x files.
      • Extract LIN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach LIN frames to the ECUs as "Rx/Tx."
      • Extract LIN cluster specific information (i.e. schedules and configuration frames).
      Notes  NI-XNET supports PDUs only if there is a 1:1 mapping between the PDU and frame layout. The import is limited to features supported by the NI-XNET driver.
    • Added user accessible checksum values to NI-XNET LIN frames.
    • Added support for ISC-178X smart cameras.
    • Added support for signals larger than 52 bits in the API and the Database Editor.
      • Signals up to 64 bits can be read/written as double floating point (rounded).
      • Signals of any size can be read/written as byte strings using a conversion session.
    The NI-XNET 17.5 release changes the following:
    • Removed support for CVI 2012.
    New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0
    The NI-XNET 17.0.1 release changes the following:
    • Bug Fix for LabVIEW 64-bit support.
    New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1
    The NI-XNET 17.0 release adds the following features:
    • Support for LabVIEW 2017.
    • Support for PCIe-8510.
    • Read CAN clusters from AUTOSAR 3.x and 4.x files.
      • Extract CAN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach CAN frames to the ECUs as "Rx/Tx."
      • Extract CAN FD specific settings.
    The NI-XNET 17.0 release changes the following:
    • Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
    • Removed support for LabVIEW 2013.
    • Removed support for CVI 2010.
    New NI-XNET 16.1 Features and Changes as Compared to NI-XNET 16.0
    The NI-XNET 16.1 release adds the following features:
    • Added support for the USB-850x USB modules.
    • Added C-API examples for J1939.
    • Enabled setting a custom baud rate for ISO CAN FD in the Bus Monitor and Database Editor.
    • Enabled excluding IDs in the Bus Monitor.
    • Enabled setting a node address for J1939 in the Bus Monitor.
    The NI-XNET 16.1 release changes the following:
    • Removed support for CVI 8.5, 9.0, and 2009.
    • USB-8502 (High-Speed/FD CAN)
    • USB-8506 (LIN)
    • PCI-8511 (Low-Speed/Fault-Tolerant CAN)
    • PCI-8512 (High-Speed/FD CAN)
    • PCI-8513 (Software-Selectable/FD CAN)
    • PCI-8516 (LIN)
    • PCI-8517 (FlexRay)
    • PCIe-8510 (Hardware-Selectable)
    • PXI-8511 (Low-Speed/Fault-Tolerant CAN)
    • PXI-8512 (High-Speed/FD CAN)
    • PXI-8513 (Software-Selectable/FD CAN)
    • PXI-8516 (LIN)
    • PXI-8517 (FlexRay)
    • PXIe-8510 (Hardware-Selectable)
    • TRC-8542 NI-XNET CAN HS/FD Transceiver Cable
    • TRC-8543 NI-XNET CAN XS (LS/FT, HS/FD)Transceiver Cable
    • TRC-8546 NI-XNET LIN Transceiver Cable
    • C Series modules:
      • NI 9861 (C Series Low-Speed CAN)
      • NI 9862 (C Series High-Speed/FD CAN)
      • NI 9866 (C Series LIN)
      • NI 9860 (C Series Hardware-Selectable)
        Supported platforms for XNET C Series modules:
        • CompactDAQ—NI-DAQmx 15.0 (or newer) is required for:
          • USB Chassis: cDAQ-9171, cDAQ-9174, and cDAQ-9178
          • Ethernet Chassis: cDAQ-9181, cDAQ-9184, and cDAQ-9188
          • Wireless Chassis: cDAQ-9191
          • cDAQ Controller: cDAQ-9138 (Windows and RT) and cDAQ-9139 (Windows and RT)
          • cDAQ Controller: cDAQ-9132 (Windows and RT) and cDAQ-9134 (Windows and RT)
          • cDAQ Controller: cDAQ-9133 (Windows and RT) and cDAQ-9135 (Windows and RT)
        • CompactDAQ—NI-DAQmx 15.1 (or newer) is required for:
          • USB Chassis: cDAQ-9179
          • cDAQ Controller: cDAQ-9136 (Windows and RT) and cDAQ-9137 (Windows and RT)
        • CompactDAQ—NI-DAQmx 17.1 (or newer) is required for:
          • Ethernet Chassis: cDAQ-9185 and cDAQ-9189
        • CompactRIO—CompactRIO 18.0 (or newer) and LabVIEW 2015 (or newer) are required for the following targets:
          • LabVIEW FPGA is required to build and deploy a bitstream with NI 986x modules in the project, unless otherwise specified.
          • Real-Time Controller: cRIO-9012, cRIO-9014, cRIO-9022, cRIO-9023, cRIO-9024, and cRIO-9025
          • CompactRIO Reconfigurable Chassis: cRIO-9111, cRIO-9112, cRIO-9113, cRIO-9114, cRIO-9116, and cRIO-9118
          • Integrated CompactRIO Real-Time Controller: cRIO-9081, cRIO-9082, cRIO-906x, and cRIO-903x
          • Single-Board RIO: sbRIO-9627, sbRIO-9607
          • CompactRIO Real-Time Controller: cRIO-9032, cRIO-9037
          • When using a cRIO-903x or cRIO-906x, a bitstream is not needed with NI 986x modules in the project.
        • CompactRIO—CompactRIO 18.0 (or newer) and LabVIEW 2016 (or newer) are required for the following targets:
          • CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
          • When using a cRIO-903x, a bitstream is not needed with NI 986x modules in the project.
        • CompactRIO—CompactRIO 18.0 (or newer) and LabVIEW 2017 (or newer) are required for the following targets:
          • CompactRIO Real-Time Controller: cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9047, cRIO-9048, and cRIO-9049
          • When using a cRIO-904x, NI 986x modules will only be usable in Real-Time mode, and no bitstream is necessary.
    The NI-XNET software supports only National Instruments CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Issue NumberIssue
    672838
    Inserting a USB-850x device can result in an unusable device with internal errors on PharLap. Workaround: Remove and reinsert the device or reboot the system.
    675253
    When using the Port Configuration Utility, it is not possible to rename ports beyond 160.
    684861
    NI-XNET does not handle J1939 PDU1 broadcasts properly.
    684951
    Unaddressed J1939 Input Queue and Signal sessions do not receive data unless a stream session is also open on the interface.
    685825
    J1939 FIBEX databases that contain ECU names are not imported correctly, and saving the database will result in overwriting the name with 0.
    687144
    Extremely long strings passed to the XNET Create Session VI can cause LabVIEW to crash.
    687562
    Rev C (and later) PCI/PXI-8511 and -8512 devices might switch to Bus Off when attempting to transmit immediately following a reboot or Self-Test.
    687624
    NI-XNET CAN FD sessions (non-BRS) require CAN FD Baudrate to be set.
    688639
    Having multiple startup VIs that contain NI-XNET project sessions can cause a LabVIEW RT target to hang.
    The following items are the IDs and titles of a subset of issues fixed in this release. This is not an exhaustive list of issues fixed. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Bug IDSummary
    664692In certain situations, removed hardware could appear as CAN-1, LIN-1, or FlexRay-1.
    667510Properties configured when adding an alias are ignored the first time the database is opened after modifying the source database.
    673342Errors returned from XNET property nodes cannot be cleared until all running VIs stop in LabVIEW.
    674352Bus Monitor and Database Editor display incorrect baud rate details for custom baud rates.
    679050In a built application (exe), some XNET I/O Controls do not show any values in the drop-down menu.
    684806Applications mixing the use of 32-bit and 64-bit baud rate properties causes errors.
    684870Expanding an XNET Device, Subframe, or LIN Schedule Entry IO control in an empty project crashes LabVIEW NXG.
    686078Default output payloads not handled properly for J1939 frames with payloads greater than 255 bytes.
    686083Transmitting multiple J1939 frames of different sizes in rapid succession results in corrupted frames on the bus.
    686442Reading single point frame input sessions with an insufficient frame count can cause LabVIEW to crash.
    Additional Programming TopicsNI-CAN Compatibility
    If you intend to use the NI-CAN API with your NI-XNET PCI/PXI hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual.
    Deployed databases on LabVIEW Real-Time targets
    When upgrading the NI-XNET software on your LabVIEW Real-Time target, you need to re-deploy your database files to that target using a host computer that runs the same version of NI-XNET as the target.
    Removing and inserting C Series modules on CompactRIO targets during device communication is not supported
    Inserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage.
    The following sections detail considerations for using NI-XNET with LabVIEW NXG.
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install NI-XNET for LabVIEW NXG.
    • Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, and then automatically opens a download window.
    • Select LabVIEW NXG Suite, and click the green Install button.
    • Select LabVIEW NXG 2.1 and NI-XNET.
    • Complete the installer instructions to download LabVIEW NXG and NI-XNET.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 2009–2018 National Instruments. All rights reserved.
    374802L-01
    GMT+8, 2025-5-10 17:42
