NI-XNET 17.5.1 Runtime Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序17.5.1运行时下载
NI-XNET
17.5.1Runtime
文件大小: 121469062 字节 (115.84 MB)
修改日期: 2019-06-25 02:43
MD5: e0b54a631b8be7f67efe86f1e625d889(官方正确)
SHA1: a80fd3efbbbab11c0b8c8b0165328bcf053a271f
SHA256: 0c0ab114c0c590b4f18fef36cc3c5c0ac7a51829566a599c1a70c1f976c0de5a
CRC32: 1020b23b
NI-XNET17.5.1RT.txt
(287 Bytes, 下载次数: 0, 售价: 5 圆)
NI-XNET 17.5.1 ReadmeJanuary 2018 This file contains important information about NI-XNET, including installation instructions, new features, a partial list of bugs fixed for NI-XNET 17.5.1, and known issues.
Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features and Changes Supported Hardware Known Issues Bug Fixes Additional Programming Topics Accessing the Help Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information Supported Operating SystemsNI-XNET supports the following operating systems: - Windows 10
- Windows 8.11
- Windows 7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions. NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems. Application Software SupportThis version of the NI-XNET software supports the following development environments: - LabVIEW 2014, 2015, 2016, and 2017
- LabVIEW Real-Time (RT) 2014, 2015, 2016, and 2017
- LabWindows/CVI 2013 and higher
- Microsoft Visual C/C++ 6.0
Installation InstructionsBefore installing the NI-XNET software, log on as Administrator or as a user with Administrator privileges. The NI-XNET software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-XNET software. - Insert the NI-XNET software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-XNET software CD.
- The installation wizard guides you through the necessary steps to install the NI-XNET software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
- When the installation is complete, click Finish.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New NI-XNET 17.5.1 Features and Changes as Compared to NI-XNET 17.5The NI-XNET 17.5.1 release changes the following: - Bug Fix for cDAQ-9171 support.
New NI-XNET 17.5 Features and Changes as Compared to NI-XNET 17.0.1The NI-XNET 17.5 release adds the following features: The NI-XNET 17.5 release changes the following: - Removed support for CVI 2012.
New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0The NI-XNET 17.0.1 release changes the following: - Bug Fix for LabVIEW 64-bit support.
New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1The NI-XNET 17.0 release adds the following features: The NI-XNET 17.0 release changes the following: - Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
- Removed support for LabVIEW 2013.
- Removed support for CVI 2010.
New NI-XNET 16.1 Features and Changes as Compared to NI-XNET 16.0The NI-XNET 16.1 release adds the following features: - Added support for the NI USB-850x USB modules.
- Added C-API examples for J1939.
- Enabled setting a custom baudrate for ISO CAN FD in the Bus Monitor and Database Editor.
- Enabled excluding IDs in the Bus Monitor.
- Enabled setting a node address for J1939 in the Bus Monitor.
The NI-XNET 16.1 release changes the following: - Removed support for CVI 8.5, 9.0, and 2009.
Supported Hardware- NI USB-8502 (High-Speed/FD CAN)
- NI USB-8506 (LIN)
- NI PCI-8511 (Low-Speed/Fault-Tolerant CAN)
- NI PCI-8512 (High-Speed/FD CAN)
- NI PCI-8513 (Software-Selectable/FD CAN)
- NI PCI-8516 (LIN)
- NI PCI-8517 (FlexRay)
- NI PCIe-8510 (Hardware-Selectable)
- NI PXI-8511 (Low-Speed/Fault-Tolerant CAN)
- NI PXI-8512 (High-Speed/FD CAN)
- NI PXI-8513 (Software-Selectable/FD CAN)
- NI PXI-8516 (LIN)
- NI PXI-8517 (FlexRay)
- NI PXIe-8510 (Hardware-Selectable)
- NI TRC-8542 NI-XNET CAN HS/FD Transceiver Cable
- NI TRC-8543 NI-XNET CAN XS (LS/FT, HS/FD)Transceiver Cable
- NI TRC-8546 NI-XNET LIN Transceiver Cable
- C Series modules:
- NI 9861 (C Series Low-Speed CAN)
- NI 9862 (C Series High-Speed/FD CAN)
- NI 9866 (C Series LIN)
- NI 9860 (C Series Hardware-Selectable)
Supported platforms for XNET C Series modules:
- CompactDAQ—NI-DAQmx 14.1 (or newer) is required for:
- USB Chassis: NI cDAQ-9171, NI cDAQ-9174, and NI cDAQ-9178
- Ethernet Chassis: NI cDAQ-9181, NI cDAQ-9184, and NI cDAQ-9188
- Wireless Chassis: NI cDAQ-9191
- cDAQ Controller: NI cDAQ-9138 (Windows and RT) and NI cDAQ-9139 (Windows and RT)
- cDAQ Controller: NI cDAQ-9132 (Windows and RT) and NI cDAQ-9134 (Windows and RT)
- CompactDAQ—NI-DAQmx 14.5 (or newer) is required for:
- cDAQ Controller: NI cDAQ-9135 (Windows and RT)
- CompactDAQ—NI-DAQmx 15.1 (or newer) is required for:
- USB Chassis: NI cDAQ-9179
- cDAQ Controller: NI cDAQ-9136 (Windows and RT) and NI cDAQ-9137 (Windows and RT)
- CompactDAQ—NI-DAQmx 17.1 (or newer) is required for:
- Ethernet Chassis: NI cDAQ-9185 and NI cDAQ-9189
- CompactRIO—NI Compact RIO 17.6 (or newer) and LabVIEW 2014 (or newer) are required for the following targets:
- Real-Time Controller: NI cRIO-9012, NI cRIO-9014, NI cRIO-9022, NI cRIO-9023, NI cRIO-9024, and NI cRIO-9025
- CompactRIO Reconfigurable Chassis: NI cRIO-9111, NI cRIO-9112, NI cRIO-9113, NI cRIO-9114, NI cRIO-9116, and NI cRIO-9118
- Integrated CompactRIO Real-Time Controller: NI cRIO-9081, NI cRIO-9082, NI cRIO-906x, and NI cRIO-903x
- LabVIEW FPGA 2014 is required to build and deploy a bitstream with NI 986x modules in the project.
- When using NI Compact RIO 17.0 (or newer) with NI cRIO-903x or NI cRIO-906x, a bitstream is not needed with NI 986x modules in the project.
- CompactRIO—NI Compact RIO 17.6 (or newer) and LabVIEW 2015 (or newer) are required for the following targets:
- Single-Board RIO: NI sbRIO-9627, NI sbRIO-9607
- CompactRIO Real-Time Controller: NI cRIO-9032, NI cRIO-9037
- LabVIEW FPGA 2015 (or newer) is required to build and deploy a bitstream with NI 986x modules in the project.
- CompactRIO—NI Compact RIO 17.6 (or newer) and LabVIEW 2016 (or newer) are required for the following targets:
- CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
- CompactRIO—NI Compact RIO 17.6 (or newer) and LabVIEW 2017 (or newer) are required for the following targets:
- CompactRIO Real-Time Controller: cRIO-904x
- The cRIO-904x requires NI CompactRIO 17.6 (or newer) and NI-DAQmx 17.6 (or newer). NI CompactRIO 17.6 (or newer) normally includes the necessary support for DAQmx 17.6
The NI-XNET software supports only National Instruments CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products. Known IssuesIssue Number | Issue | — | FlexRay PXI-8517 boards may have memory issues on PXI controllers with less than 2 GB RAM. | — | When using an .ncd or .dbc database, the baud rate defaults to 500 k (250 k for J1939 databases), and the IO mode defaults to CAN 2.0. You need to programmatically override these values in your session if you need different values. | — | Changing transceiver cables on NI 9860, PXIe-8510 and PCIe-8510 on RT targets requires a refresh of MAX. | — | Changed behavior of Frame Default Payload property: If Application Protocol of a Cluster is J1939, the default for Default Payload bytes is now 0xFF instead of 0x00. As a consequence, unused bits in the frame will be set to 1 instead of 0 when J1939 is used (like required by J1939). | — | Variant Handling, as described within the AUTOSAR 4.x Generic Structure Template, is unsupported by NI-XNET. All AUTOSAR XML elements using the tag will be discarded. | — | If reading AUTOSAR files, some types of frames are not assigned to ECUs as "Tx" (transmitted frames) or "Rx" (received frames). | 667510 | Changed Alias properties such as Baud Rate and IOMode are ignored the first time a database is opened. Workaround: Close and re-open the session. | 672838 | Inserting a USB-8502 device can result in an unusable device with internal errors on PharLap. Workaround: Remove and reinsert the device or reboot the system. | 673342 | NI-XNET Interface and Device property nodes can return erroneous session handles. Workaround: Typecast the Interface or Device Session to an NI-XNET Session and pass it to XNET Clear. |
Bug FixesThe following items are the IDs and titles of a subset of issues fixed between NI-XNET 16.1 and NI-XNET 17.5. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-XNET. Bug ID | Fixed Issue | 679472 | cDAQ-9171 does not work with NI-XNET 17.5. | 668124 | Using invalid NI-XNET sessions can crash the RT application. | 646672 | CAN frames with invalid DLC pass through the controller then the firmware sends the Kernel driver a larger than expected array. | 639597 | The option "Browse for Database File" on an NI-XNET IO control crashes LabVIEW 2017 (64-Bit). | 631818 | NI-XNET Echoed frames always have the CAN Data type regardless of the type actually transmitted. | 612384 | NI-XNET Compatibility Library for NI-CAN does not support hardware with transceiver cables. | 612146 | DBC Import: Unable to read the frame name if there are space characters behind the last character of the frame name and the ':' character following the name. | 611887 | NI-XNET controls fail to trigger the value changed event. | 610257 | Error for too many Frame Stream sessions says too many frames instead of too many sessions in NI-XNET error code 0xBFF63012. | 609492 | NI-XNET LIN C Series devices are unrecoverable after bus power is removed and error -1074384887 is detected. | 576222 | Manage NI-XNET Databases does not work on RT targets with a non-blank password. |
Additional Programming TopicsNI-CAN CompatibilityIf you intend to use the NI-CAN API with your NI-XNET PCI/PXI hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual. Deployed databases on LabVIEW Real-Time targetsWhen upgrading the NI-XNET software on your LabVIEW Real-Time target, you need to re-deploy your database files to that target using a host computer that runs the same version of NI-XNET as the target. Removing and inserting C Series modules on CompactRIO targets during device communication is not supportedInserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage. Accessing the HelpRefer to the NI-XNET Hardware and Software Help, accessible from National Instruments»NI-XNET»NI-XNET Documentation, for information about NI-XNET. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Customize and Automate Installation of a Suited Intaller.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Legal InformationCopyright © 2009–2018 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 374802K-01 |
