查看: 3275|回复: 0
[LV工具模块] LabVIEW 2015 LEGO MINDSTORMS NXT Module Win32Eng
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-10-13 23:16:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LEGO MINDSTORMS Module for LabVIEW
    LEGO MINDSTORMS Module模块用于帮助学生使用基于LEGO MINDSTORMS EV3和NXT的机器人。
    LEGO MINDSTORMS模块是用于LabVIEW的一款系统工程软件,学生可以在教室或机器人竞赛中结合LEGO Education机器人平台使用该软件。该软件可作为教学工具,帮助学生对LEGO MINDSTORMS机器人进行视觉控制和编程。LEGO MINDSTORMS模块可以将任何LEGO MINDSTORMS Education平台改造为科学和工程学习平台。该模块还提供包括教程和交互式练习,旨在帮助学生进一步提高LabVIEW技能。LEGO、LEGO商标和MINDSTORMS是LEGO集团的注册商标。 版权.2020 the LEGO Group。
    文件大小: 157197088 字节 (149.91 MB)
    修改日期: 2015-07-02 05:24
    MD5: 8c51624d7897837856d5dfd7de758099
    SHA1: 26d04fdbf055d2d369df356e2e48e0499d0b95d7
    SHA256: b7812377df2a96a18c1898cac550df6cfb20cc7159d01c2170d78c0d97711d66
    CRC32: 86667dd8
    LMM2015.txt (455 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2015 Module for LEGO® MINDSTORMS® Readme for Windows
    June 2015
    This file contains information about the LabVIEW Module for LEGO® MINDSTORMS®, including bugs fixed for this release and a list of known issues.
    Finding Applications and Examples
    Use the LabVIEW Module for LEGO MINDSTORMS to create VIs that either run directly on an NXT or EV3 brick or that run on a host computer and communicate with an NXT or EV3 brick through a USB, Bluetooth, or Wi-Fi connection.
    The LabVIEW 2015 Module for LEGO MINDSTORMS requires the LabVIEW 2015 Full or Professional Development System.
    Refer to the LabVIEW 2015 on the National Instruments website for information about system requirements for LabVIEW 2015.
    The following list describes known issues at the time of release:
    • A LabVIEW crash, an error message about Fantom.dll, and inconsistent behavior from the NXT/EV3 Terminal are all consequences of deleting dependencies of Fantom.dll. To correct this behavior, navigate to the Control Panel\Programs\Programs and Features directory, and repair the LEGO MINDSTORMS NXT Driver installation.
    • After you connect to an NXT or EV3 brick using Bluetooth, the Find NXT/EV3 window displays the brick as available for connection even when Bluetooth is disabled or the brick is not present. If you try to connect to the brick when the Bluetooth connection is off, the display updates the status to unavailable.
    • The Moving output of the Motor Status VI is TRUE only when performing a move with the Move a Fixed Distance VI. These Boolean outputs always return FALSE if the move initiates with the Move DC Motors VI.
    • The following code is not supported in VIs that you download to an EV3 brick:
      • Some auto-indexing capabilities on While Loops—Auto-indexing input tunnels are supported.
      • Compare Elements mode for the Max & Min function is not supported for arrays and clusters.
      • Conditional terminals or parallelism on For Loops
      • Formula Nodes
      • Complex numbers used with the asin, acos, atan, and atan2 functions.
    • The following code is not supported in VIs that you download to an NXT brick:
      • Formula Nodes
      • Byte Array To String functions if you try to coerce a 32-bit array
      • Numeric operations involving a cluster and an array of clusters
      • Not function if you try to negate an array
      • Divide function if both inputs are zeros—Divide function returns zero instead of NaN.
      • Conversion functions if you try to convert floating point numbers to integers—Outputs are truncated instead of rounded to the nearest integer.
    • The Value property does not update front panel objects. Use local variables or wire values directly to terminals to update front panel objects.
    • Filenames with special or multibyte characters are not supported in the Robot Project Center.
    • Unexpected behavior can occur in the Schematic Editor when you work on a remote desktop.
    • When adding an image for your robot project profile, use an image that is 123 × 89 pixels (width × height).
    • In Direct Mode, the Draw VIs that are instances of the Display polymorphic VI do not clear the screen before drawing over the running program or menu screen. To avoid this, use the Clear Display VI before using the Draw VIs.
    • The LabVIEW Module for LEGO MINDSTORMS API is not supported in Application Builder.
    Refer to the following documents for more information about the LabVIEW Module for LEGO MINDSTORMS:
    • LabVIEW LEGO MINDSTORMS NXT Module Help—Use this to access information about LabVIEW Module for LEGO MINDSTORMS programming concepts, step-by-step instructions for using the LabVIEW Module for LEGO MINDSTORMS, and reference information about the NXT/EV3 VIs, palettes, menus, dialog boxes, and so on. Access the LabVIEW LEGO MINDSTORMS NXT Module Help by selecting Help»MINDSTORMS Module Help.
    • LabVIEW Help—Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about advanced LabVIEW concepts and procedures.
    Select Tools»NXT/EV3 Application Browser to access applications that you can run on an NXT or EV3 brick. These applications demonstrate several types of programs you can create with the LabVIEW Module for LEGO MINDSTORMS.
    Access example VIs that demonstrate common tasks using the LabVIEW Module for LEGO MINDSTORMS in the NI Example Finder by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules»NXT Robotics in the NI Example Finder window. You also can access these VIs by referring to the labview\examples\NXT Robotics directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    When you install NI software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Windows 8x DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Finding All Programs
    f you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    Important Information
    © 2009–2015 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks.
    LEGO and MINDSTORMS are trademarks of the LEGO Group. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-4-1 11:07
