查看: 3231|回复: 0
[LV工具模块] LabVIEW SystemLink Toolkit 2020R2.1 Win32/64Eng LabVIEW系统连接工具包SLT20.1.1下载
    前天 10:18
  • 签到天数: 3555 天
    连续签到: 7 天
    发表于 2020-9-18 22:46:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW SystemLink工具包提供了LabVIEW或LabVIEW NXG与SystemLink Server或SystemLink Cloud账户进行通信的工具。
    LabVIEW SystemLink工具包是一个软件附件,包含用于LabVIEW的SystemLink API。该附件可通过编程方式访问SystemLink数据服务,这样就可在SystemLink Web应用程序之外集成SystemLink和LabVIEW。您可以使用LabVIEW SystemLink工具包为测试和测量系统创建VI或WebVI。
    校验和
    文件大小: 451813376 字节 (430.88 MB)
    修改日期: 2020-08-10 14:00
    MD5: 130028375e30eb415dd1f2e71cbef821(官方正确)
    SHA1: 2e97d3b86f415507dd3cdb332125652457944d3d
    SHA256: 2b4d2f88c0e530cbbff7c3505d24d88d93b3e1802d8db2c43bb0555bdc2fed72
    CRC32: c1ffb19a
    百度网盘下载地址和NI官方下载地址:
    链接: 请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服
    SL20.1.1.txt (313 Bytes, 下载次数: 0, 售价: 10 元)
    NI SystemLink 2020 R2 Readme
    July 2020
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Breaking REST API Changes
    SystemLink Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server. SystemLink TDM is a Big Analog Data™ solution for automated preparation and analysis of large amounts of data in various formats and structures from different geographic locations.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes, SystemLink TDM
    OS (64-bit only)
    Windows Server 2019 R2
    Windows Server 2016
    Windows Server 2012 R2 1
    Windows 7 SP1 or higher
    Windows Server 2016
    Processor
    4-core recommended or higher
    8-core recommended or higher
    RAM
    16 GB minimum
    32+ GB recommended
    32 GB minimum
    64+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    1 NI software installs VC2015 runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2, which require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  Refer to SystemLink Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  SystemLink TDM does not support server versions from the Microsoft Semi-Annual Channel. In addition, SystemLink TDM does not support Windows Server Core mode.
    Target Requirements (Managed Nodes)
    NI Linux Real-Time
    OS
    Windows 7 SP1 (64-bit) or higher
    Windows 7 SP1 (32-bit) or higher
    NI Linux Real-Time 2019, 2020
    (Supports LabVIEW RT 2019, 2020, and NXG 5.0)
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Safari
    Note: NI SystemLink 2020 R1 and later web applications do not support Internet Explorer.
    Supported Software
    NI SystemLink 2020 R2 supports the following LabVIEW versions:
    • LabVIEW 2017, 2018, 2019, 2020
    • LabVIEW RT 2017, 2018, 2019, 2020
    • LabVIEW NXG 5.0
    SystemLink TDM supports the following DIAdem versions as clients:
    • DIAdem 2015, 2017, 2018, 2019 (recommended)
    SystemLink uses Volume License Manager to license server modules and add-ons as well as clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    You can access a list of bugs fixed in this version online. Refer to the public bugs list for a list of fixed bugs.
    The following changes to SystemLink REST APIs could affect the functionality of existing code.
    SystemLink TDM General:
    • /browse endpoints no longer exist. These have been moved to DataFinder, Data Preprocessor and Analysis Automation.
    • /file endpoints no longer exist.
    DataFinder:
    • Security API has been deprecated.
    Analyisis Automation:
    • "visiblefor" option has been deprecated.
    Refer to the NI SystemLink Manual, accessible from ni.com, for more information about NI SystemLink and the services and APIs it offers.
    SystemLink will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2017-2020 National Instruments. All rights reserved.
    377243N-01
    GMT+8, 2025-6-2 03:40
