NI PXI Platform Services 15.1 Driver Runtime Win32/64Eng PXI平台服务NI-PXIPS15.1运行时下载
PXI Platform Services用于支持NI PXI机箱和控制器,遵循PXI软件规范,并为其他NI产品提供系统服务。
PXI Platform Services用于识别NI PXI和PXI Express机箱和模块,以及允许触发路由。 对于特定NI模块,使用完整的模块功能仍需要适用的硬件驱动程序。 NI PXI Platform Services已包含在NI仪器驱动程序中,但有些情况下,某些应用程序只需要PXI Platform Services软件,例如在没有安装其他NI PXI硬件驱动程序的情况下使用NI MXI产品或使用NI PXI或PXI Express机箱。
百度网盘下载(限速,请开会员或使用工具下载):
请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
NI官方下载地址(可能无法下载完成或地址无效):
PXIPS15.1RT.txt
(289 Bytes, 下载次数: 0, 售价: 5 圆)
文件大小: 92773435 字节 (88.48 MB)
修改日期: 2019-06-25 03:11
MD5: 7315fffd6835b2c3e722852720c85aaf
SHA1: 22d67759c105b41e65895b96a574e84b13118675
SHA256: 91ba1d3b25a2e12f7d6ecdad8b745b0ec6eea2aafb3d0cb672c15fb267d1b08e
CRC32: cba0f2c0
PXI Platform Services 15.1 ReadmeAugust 2016 This file contains important information about PXI Platform Services, including new features and a partial list of bugs fixed. Parts of this document are only relevant to a full installation and do not apply to a runtime-only installation. Release Notes System Requirements Application Software Support Supported Interfaces Product Security and Critical Updates PXI System Monitoring Enhancements and Bug Fixes NI Software Support for Microsoft Windows 7, Windows Vista, Windows XP, and Windows Server 2003 Automating the Installation of NI Products How to Use NI Software with Microsoft Windows 8.1 How to Use NI Software with Microsoft Windows 10 Legal Information Release NotesIf you are using PXI Platform Services 15.1 to upgrade a Windows system that serves as a host for one or more LabVIEW Real-Time targets, it is highly recommended that you also update your targets to leverage new features and improved performance. Note: You cannot use PXI Platform Services 15.1 to configure a LabVIEW Real-Time target with a version of PXI Platform Services earlier than 2.0. Back to top System RequirementsPXI Platform Services 15.1 supports the following platforms. For the most up to date information, refer to KnowledgeBase 53399AQ7, PXI Platform Services Operating System Support. - Windows 10/8.1/7 (32-bit and 64-bit)
- Windows Vista SP1 or later (32-bit and 64-bit)
- Windows XP SP3 or later (32-bit)
- Windows Server 2012 R2 (64-bit)
- Windows Server 2008 R2 with SP2 or later (64-bit)
- Windows Server 2003 R2 with SP2 or later (32-bit)
Note: Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might need to take, refer to KB 54D9I6M6. Application Software SupportThe following table lists the application software versions, including service packs, supported by PXI Platform Services 15.1. Application Software | Versions Supported by PXI Platform Services | LabVIEW | 2012 SP1, 2013 SP1, 2014 SP1, 2015 SP1 | Supported InterfacesPXI Platform Services supports PXI and PXI Express functionality on hardware found in KnowledgeBase 531FRFQ7, PXI Platform Services Hardware Support. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. Back to top PXI System MonitoringNI PXI Chassis System MonitoringPXI Platform Services 3.2.1 was the first version to support the PXI-8250 module via the NI System Configuration API. Note: NI System Configuration 5.4 (or later) is required for LabVIEW API support. NI PXI Express Chassis System MonitoringPXI Platform Services 3.1 was the first version to support system monitoring via NI System Configuration API. NI PXI Express Remote Controllers may require a firmware update in order to take advantage of the system monitoring features. For more information, refer to KnowledgeBase 5Z8ENB62, Why can I not use System Monitoring on my NI PXIe-1066DC or NI PXIe-1085 Chassis with a MXI(e) Controller? NI System Monitor Minimum RequirementIf NI System Monitor is installed on your system, upgrading PXI Platform Services to version 3.1 or later also requires an upgrade of NI System Monitor to version 1.2 or later. Back to top Enhancements and Bug Fixes- Version 15.1
- Version 15.0.2
- Version 15.0.1
- Version 15.0
- Version 14.1
- Version 14.0
- Version 4.0.1
- Version 4.0
- Version 3.2.3
- Version 3.2.2
- Version 3.2.1
- Version 3.2
- Version 3.1
- Version 3.0.4
- Version 3.0.3
- Version 3.0.2
- Version 3.0.1
- Version 3.0
- Version 2.5.6
- Version 2.5.4
- Version 2.5.3
- Version 2.5.2
- Version 2.5.1
- Version 2.3
Back to top Enhancements and Bug Fixes in Version 15.1New Hardware SupportAdded support for new PXI hardware. Fixed Issue: MAX Delay for network-capable Chassis374646: There was a short delay in MAX when viewing details for a chassis with a built-in Ethernet port. Back to top Enhancements and Bug Fixes in Version 15.0.2New Hardware SupportAdded support for new PXI hardware. Back to top Enhancements and Bug Fixes in Version 15.0.1New Hardware SupportAdded support for new PXI Express hardware. Back to top Enhancements and Bug Fixes in Version 15.0Self-Test for PXI Platform HardwareSelf-test is available for PXI chassis and embedded and remote controllers; this feature can be accessed through MAX and NI System Configuration API. Self-test verifies basic hardware functionality. Geographic AliasesPXI controllers, MXI modules, and the PXI-8250 now provide an alias that conveys information about their location in a system (for example, PXI2Slot1). You can see this alias in the Devices and Interfaces section in MAX. New chassis attributes in MAXHardware revision and PXI_CLK10 source information is now available for PXI chassis in MAX. Patch for PXIe-1085/PXIe-1078 ChassisPXI Platform Services 15.0 includes the PXIe-1085/PXIe-1078 patch that was released for PXI Platform Services 3.2.2 through 14.1. For more details about this patch, refer to KB 6WG9H3SZ. Fixed Issues: Improved MAX Stability378807, 440251, 507983, 520787, 520922: In some cases, there could be stability issues with PXI hardware in MAX. Fixed Issue: Duplicate Devices in MAX363174: MXI-4 and PXI-8360 devices were shown twice in Devices and Interfaces in MAX. Back to top Enhancements and Bug Fixes in Version 14.1New Hardware SupportAdded support for new PXI Express hardware. Fixed Issue: Could not create chassis item in Measurement & Automation Explorer (MAX)505008: When using LabVIEW Real-Time with some using older NI PXI controllers that are unable to automatically identify, the chassis could not be created in MAX. Back to top Enhancements and Bug Fixes in Version 14.0Driver Version Naming ChangesPXI Platform Services versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: PXI Platform Services 14.0. For example, PXI Platform Services 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is PXI Platform Services 4.0.1. The first version released under the new numbering scheme is PXI Platform Services 14.0. Runtime InstallerStarting with version 14.0, PXI Platform Services is available as a runtime installer. PXI Platform Services Runtime is a minimal installer which does not include configuration through Measurement & Automation Explorer (MAX). When building an installer using National Instruments application development environments (ADEs) such as LabVIEW, you will now have the option of including this subset of PXI Platform Services in your distribution. System MonitorSupport for System Monitor is deprecated in PXI Platform Services and will be removed in a future release. Monitoring capabilities are available through the NI System Configuration API. Customers using System Monitor should migrate their applications to NI System Configuration API. Fixed issue: Chassis not automatically identified in MAX441696: When using a PXI Express Chassis and controller under a heavy load, the chassis could sometimes fail to auto-identify in MAX. Back to top Enhancements and Bug Fixes in Version 4.0.1New Hardware SupportAdded support for new PXI Express hardware. Back to top Enhancements and Bug Fixes in Version 4.0PXI Specification UpdatesPXI Platform Services 4.0 adds support for the new PXI-9 specification, revision 1.0. This version also includes updates to meet the requirements of the following PXISA specification versions: - PXI-2 Software Specification, revision 2.4
- PXI-4 Module Description, revision 1.1
- PXI-6 PXI Express Software Specification, revision 1.2
The PXI Express chassis description files now list the PXI specification compliance version. For more information on PXI specifications, go to pxisa.org. PXI Platform Services on Real-Time SystemsWhen deploying software to your Real-Time system, PXI Platform Services is now visible in the Add/Remove software tree in Measurement & Automation Explorer (MAX). If you have more than one version of PXI Platform Services 4.0 or later installed on your host, you may select which version of PXI Platform Services will be deployed to the target. For more information about deploying software to Real-Time targets, see the MAX Help, available on the Help menu in MAX. Fixed Issues in Measurement & Automation ExplorerPXI Platform Services 4.0 fixes the following issues in MAX: - 37850: In some instances, NI PXI-8360 and PXI-MXI-4 devices may not be visible in MAX.
- 393204: In some cases, there could be stability issues with PXI hardware in MAX.
Back to top Enhancements and Bug Fixes in Version 3.2.3New Hardware SupportAdded support for new PXI Express hardware. Back to top Enhancements and Bug Fixes in Version 3.2.2New Hardware SupportAdded support for new PXI and PXI Express hardware. Removed Hardware SupportPXI Platform Services will no longer provide support for the following hardware: - PXI-1002 chassis
- PXI-1006 chassis
- PXI-1010 chassis
- PXI-1011 chassis
- PXI-1020 chassis
- PXI-1025 chassis
- PXI-8150 controller
- PXI-8150B controller
- PXI-8170 controller
- PXI-8174 controller
- PXI-8175 controller
- PXI-8176 controller
- PXIe-8103 controller
Back to top Enhancements and Bug Fixes in Version 3.2.1Windows 8 FixesMinor updates to improve the Windows 8 user experience. Back to top Enhancements and Bug Fixes in Version 3.2Windows 8 SupportPXI Platform Services 3.2 adds support for Windows 8 (32-bit and 64-bit). The following are known issues with Windows 8: - The fast startup capability introduced in Windows 8 may cause improper functioning of your hardware and device drivers. To properly initialize drivers, choose Restart or Shut Down when prompted at the end of the installation. To prevent future problems with installing or removing hardware, National Instruments recommends disabling fast startup. Refer to ni.com/info and enter the Info Code Win8FastStartup for more information.
- Upgrading from a Windows 7 (or older) system is not supported
NI PXI Express Remote Controller Firmware UpdaterPXI Platform Services has enabled the ability to update NI PXI Express Remote Controller Firmware. For more information, refer to the documentation of the specific firmware. Back to top Enhancements and Bug Fixes in Version 3.1NI PXI Express Chassis MonitoringAdded support for monitoring NI PXI Express chassis via NI System Configuration API. LabVIEW SupportSupport for LabVIEW 8.6 and LabVIEW 2009 is discontinued in this release. Back to top Enhancements and Bug Fixes in Version 3.0.4New Hardware SupportAdded support for new PXI and PXI Express hardware. Back to top Enhancements and Bug Fixes in Version 3.0.3New Hardware SupportAdded support for new PXI and PXI Express hardware. Back to top Enhancements and Bug Fixes in Version 3.0.2New Hardware SupportAdded support for new PXI and PXI Express hardware. Back to top Enhancements and Bug Fixes in Version 3.0.1Fixed Issue: Addressed failure with RT Reboot of Hypervisor System313181 Fatal exception, Code:0xC0000005 error, detected when restarting RT side of a Hypervisor system. Back to top Enhancements and Bug Fixes in Version 3.0Updates to Measurement & Automation Explorer Graphical User InterfacePXI Platform Services has updated the user interface for PXI Systems in Measurement & Automation Explorer. The following changes were made: - Better error detection.
- Improved performance.
- Identify bus as a chassis function replaced with Create New Chassis Wizard.
- Updated help.
- Controllers and MXI Modules now appear inside Slot View and Devices and Interfaces.
- Majority of National Instruments PXI embedded controllers are now automatically identified.
- MXI connectivity information is provided through Devices and Interfaces.
- Removed redundant PXI System tree under Devices and Interfaces.
LabVIEW SupportSupport for LabVIEW 8.5 is discontinued in this release. Back to top Enhancements and Bug Fixes in Version 2.5.6New Software SupportPXI Platform Services 2.5.6 adds support for PXI Express systems on NI Real-Time Hypervisor. LabVIEW 8.2 SupportSupport for LabVIEW 8.2 is discontinued in this release. Back to top Enhancements and Bug Fixes in Version 2.5.4Windows 2000PXI Platform Services 2.5.4 removes support for Windows 2000. Windows Server SupportPXI Platform Services 2.5.4 adds support for Windows Server 2003 R2 (32-bit only) and Windows Server 2008 R2. Back to top Enhancements and Bug Fixes in Version 2.5.3Windows 7 SupportPXI Platform Services 2.5.3 adds support for Windows 7 x86 (32-bit) and Windows 7 x64 (64-bit). Back to top Enhancements and Bug Fixes in Version 2.5.2Updates to Measurement & Automation Explorer Graphical User InterfacePXI Platform Services has updated the user interface for PXI Systems in Measurement & Automation Explorer to add System View. Back to top Enhancements and Bug Fixes in Version 2.5.1New Software SupportPXI Platform Services 2.5.1 adds support for PXI systems on NI Real-Time Hypervisor. Back to top Enhancements and Bug Fixes in Version 2.3Windows Vista SupportPXI Platform Services 2.3 adds support for Windows Vista x86 (32-bit) and Windows Vista x64 (64-bit). Back to top PXI Platform Services Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003PXI Platform Services will drop support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of PXI Platform Services that ship after July 1, 2016 will not install or run on Windows 7 RTM (with no service pack), Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: Product | Info Code | LabVIEW | lifecycle | LabWindows™/CVI™ | cvi_lifecycle | Measurement Studio | mstudiolifecycle | TestStand | tslcp | DIAdem | ddlcp | SignalExpress | selcp | VeriStand | nivslifecycle |
Back to top Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information on silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information on silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
Back to top How to Use NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX) and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Back to top How to Use NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Legal InformationCopyright © 1998–2016 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
374995B-01 |
