查看: 3124|回复: 0
[LV工具模块] LabVIEW Statechart Module 2018 Win32Eng LV状态图模块SC2018
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2020-9-1 00:23:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    下载地址1:
    下载地址2:
    SC2018.txt (389 Bytes, 下载次数: 1, 售价: 10 圆)
    文件大小: 207007624 字节 (197.42 MB)
    修改日期: 2018-05-17 21:40
    MD5: b7f19a09c7fb665ea90be31df43fd62a
    SHA1: 321a4a1468fbe99c5d9e8dfc370e5742e1f4fe84
    LabVIEW 2018 Statechart Module Readme
    March 2018
    This file contains important information about the LabVIEW 2018 Statechart Module, including system requirements, installation instructions, and known issues.
    The Statechart Module provides a programming model that you can use to design applications at a higher level than was previously possible. With the Statechart Module, you can develop statechart diagrams, define behaviors with LabVIEW dataflow programming, and deploy the statecharts to desktop PCs, real-time controllers, field-programmable gate arrays (FPGAs), and embedded targets.
    In addition to the system requirements for the LabVIEW Development System, the Statechart Module has the following requirements:
    • LabVIEW 2018 Base, Full, or Professional Development System for Windows (32-bit)
    • At least 250 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018.
    The Statechart Module supports the following operating systems:
    • Windows 10 (version 1709)/8.11/7 SP12
    Note  In 2016 the Statechart Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 Statechart Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 Statechart Module to an unsupported OS. Additionally, after installing the LabVIEW 2018 Statechart Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    You can install all of your LabVIEW products—including the Statechart Module—using the LabVIEW 2018 Platform media.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2018 Statechart Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Statechart Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Statechart Module are located in the labview\examples\Statechart directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2007–2018 National Instruments. All rights reserved.
    374719D-01
    SHA256: 5fde72df5469f81f66eb55e1265a2d863d973077727ff51646a630608dd05749
    CRC32: 85bad4d4
    GMT+8, 2025-10-29 12:14
