查看: 2575|回复: 0
[LV工具模块] LabVIEW Statechart Module 2013 Win32Eng LV状态图模块SC2013
    5 小时前
  • 签到天数: 3528 天
    发表于 2020-9-1 00:13:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    下载地址1:
    下载地址2:
    SC2013.txt (389 Bytes, 下载次数: 2, 售价: 10 元)
    文件大小: 101126944 字节 (96.44 MB)
    修改日期: 2013-08-06 02:44
    MD5: 87c8470027c72dd6d13dd74d5af580c8
    SHA1: ae83ca90883ab2f7c77900c32c75827a154732d6
    SHA256: 4ee4d5e11322b9182ceaf6ee8c5cc7dbd706ff39a80108193df65bd4364f481d
    CRC32: 838383fb
    LabVIEW 2013 Statechart Module Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW Statechart Module, including installation instructions, a partial list of bugs fixed for LabVIEW 2013 Statechart Module, and known issues.
    In addition to the system requirements for the LabVIEW Development System, the Statechart Module has the following requirements:
    • LabVIEW 2013 Base, Full, or Professional Development System (32-bit) for Windows
    • At least 250 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    You can install all of your LabVIEW products—including the Statechart Module—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Statechart Module Updates and Notifications
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Statechart Module.
    The following items are the IDs and titles of a subset of issues fixed in the Statechart Module. This is not an exhaustive list of issues fixed in the current version of the Statechart Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    374402Bug (Error 91 is thrown) in 2012 statecharts with LVOOP queues.
    401226LabVIEW development environment crashes when connecting to a real-time debuggable executable containing a Run statechart.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Statechart Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Statechart Module are located in the labview\examples\Statechart directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI LabVIEW Statechart Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Statechart Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Statechart Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2007–2013 National Instruments. All rights reserved.
    GMT+8, 2025-4-29 13:17
