查看: 3082|回复: 0
[LV工具模块] LabVIEW Statechart Module 2011 Win32Eng LV状态图模块SC2011
    昨天 16:26
  • 签到天数: 3674 天
    发表于 2020-9-1 00:07:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    下载地址1:
    下载地址2:
    SC2011.txt (389 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 75635296 字节 (72.13 MB)
    修改日期: 2012-07-20 02:55
    MD5: 0ccec1257d364b437b4988783733658d
    SHA1: a26773650f2b09016fa9e9b45dda8d3e6208053e
    SHA256: b8c10d039891009bb6c5a357986db51fbe949d9f635ce2707c5c6e811bc238b5
    CRC32: b859a0cb
    LabVIEW 2011 Statechart Module Readme
    Version 11.0.0
    June 2011
    This file contains information to introduce you to the LabVIEW 2011 Statechart Module. This file also provides you with help resources you can use while working with the Statechart Module.
    • LabVIEW 2011 Base, Full, or Professional Development System (32-bit) for Windows
    • Windows 7/Vista/XP SP2/Windows Server 2003 R2 (32-bit)/Windows Server 2008 R2 (64-bit). The LabVIEW 2011 Statechart Module does not support the Windows Server non-R2 editions.
    • 250 MB available disk space
    You can install all of your LabVIEW products—including the LabVIEW Statechart Module—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the LabVIEW Statechart Module along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Statechart Module.
    Examples for the Statechart Module are located in the labview\examples\Statechart directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2011 Statechart Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 Statechart Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Statechart Module.
    180468Compile fails when using multiple classes and Statecharts
    224569Scripting allows Statechart objects to be placed in non-Statechart VIs
    228612Making a State (containing a IsIn Node) as a sub-diagram results in a broken statechart under certain conditions.
    276756Code in Statechart 2010 Transition Node causes Error 1502 during VxWorks RT exe build
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-8 00:16
