查看: 2790|回复: 0
[LV工具模块] LabVIEW Statechart Module 2010 Win32Eng LV状态图模块SC2010
    昨天 16:26
  • 签到天数: 3674 天
    发表于 2020-9-1 00:04:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    下载地址1:
    下载地址2:
    SC2010.txt (389 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 63711840 字节 (60.76 MB)
    修改日期: 2012-08-03 21:32
    MD5: 3cac98bbc91d99f992697997ad4725fd
    SHA1: 563336a0c4d4fd0ee14b74a3012d0204dc2a3271
    SHA256: 0664e81d87ff4020182aa461f51cb53ae1fc26ab036b21d44fab13a7e9bfe4f9
    CRC32: b5553c8a
    LabVIEW 2010 Statechart Module Readme
    Version 10.0.0
    June 2010
    This file contains information to introduce you to the LabVIEW 2010 Statechart Module. This file also provides you with help resources you can use while working with the Statechart Module. The file contains the following information that you need to understand.
    In LabVIEW 2010, you can minimize subVI overhead by inlining subVIs into their calling VIs. In the LabVIEW 2010 Statechart Module, the default is to inline all internal VIs and VIs for guard and action code. While subVI inlining improves performance, it also can increase the memory footprint of a statechart. To disable subVI inlining, place a checkmark in the Disable Inline Settings? checkbox on the Statechart Code Generation page of the Project Library Properties dialog box. You can access the Project Library Properties dialog box by right-clicking a .lvsc file in the Project Explorer window and selecting Properties from the shortcut menu.
    For more information about subVI inlining, refer to the SubVI Overhead section of the VI Execution Speed topic in the LabVIEW Help.
    • LabVIEW 2010 Base, Full, or Professional Development System for Windows
    • 250 MB additional available disk space
    The LabVIEW 2010 Statechart Module supports the Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit) editions. The LabVIEW 2010 Statechart Module does not support the Windows Server non-R2 editions.
    You can install all of your LabVIEW products—including the LabVIEW Statechart Module—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the LabVIEW Statechart Module along with activation instructions in the following locations:
    • LabVIEW 2010 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help from the pull-down menu in LabVIEW, for information about the Statechart Module.
    LabVIEW examples for the Statechart Module are located in the labview\examples\Statechart folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2010 Statechart Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2010 Statechart Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Statechart Module.
    143338Adding a VI with a large VI hierarchy to a guard or action is slow.
    162906LabVIEW hangs when editing values in the Edit Triggers and Groups dialog box.
    167089Statecharts saved in LabVIEW 8.5.x containing states you view as a subdiagram do not load correctly in LabVIEW 8.6 or later.
    172955Software labels for some controls in the Edit Trigger and Groups dialog box do not match the text in the Context Help window.
    177155Inserting items into signals using the Configure State and Configure Transition dialog boxes may not appear in the correct position.
    180266Statechart communication VI icons do not update correctly when you change the system font.
    183441You cannot enable the Disconnect Type Definitions option when building a statechart application using the Application Builder.
    184208States and regions with the same ID can be overwritten when you generate documentation for a statechart.
    198045You cannot change the headings of Triggers and Groups using the Edit Triggers and Groups dialog box.
    198618Stand-alone applications that contain statecharts do not run.
    202636You cannot maintain hierarchy within a statechart when you build a Real-Time application.
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-10-8 00:15
