查看: 4779|回复: 0
[NI软件产品] LabVIEW 2012SP1 FPGA Module Xilinx Compilation Tools and Patch Linux32Eng LV2012SP1 FPGA编译工具(ISE 13.4)及补丁
    2 小时前
    发表于 2020-8-26 21:13:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2012SP1RHEL56,3.52GB
    LV2012SP1FPGA编译工具(ISE13.4)补丁
    2012sp1f1_FPGA_Compile_Worker_Patch_Linux,304KB
    发布日期
    13-3-4
    受支持的操作系统
    Red Hat Enterprise Linux 5.6 (32-bit)
    语言
    English
    校验和
    MD5: 20b8269fee1cd5c7690e95eb853714e0
    SHA1: fab5c7a02300646675f01ba2752dd494a72e5baa
    SHA256: b88a0cb18f7fbb189e3c1fcd33f0b9f8cdf2b6faadbce3bc5d4998a434ead85e
    CRC32: 0743f8f9
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-ISE13.4-LV2012SP1.txt (255 Bytes, 下载次数: 1, 售价: 10 圆)
    Compile Worker for Linux Readme (LabVIEW FPGA Module)
    Version 12.0.1
    December 2012
    This file contains important information about the LabVIEW FPGA Module Compile Worker for Linux.
    Installation
    You can install the Compile Worker for Linux using the LabVIEW FPGA Module Addtional Xilinx Compilation Tools DVD. You can find installation instructions for the Compile Worker for Linux along with activation instructions in the following locations:
    • LabVIEW FPGA Module Release and Upgrade Notes, available in your FPGA Module software kit or online at ni.com/manuals.
    • Activation Instructions for National Instruments Software, which are available on the LabVIEW intallation media.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the FPGA Module.
    © 2003–2012 National Instruments. All rights reserved.
    I.     Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    II.     Third-Party Copyright Notices
    The Compile_Worker_Notice.txt file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    /usr/local/natinst/nifpgacompileworker/doc/
    Xilinx® is a registered trademark of Xilinx, Inc.
    Linux® is a registered trademark of Linus Torvalds in the U.S. and other countries.
    GMT+8, 2026-4-23 10:50
