查看: 3548|回复: 0
[NI软件产品] LabVIEW 2015SP1 FPGA Module Xilinx Compilation Tools and Patch Win32Eng LV2015SP1 FPGA编译工具(Vivado 2014.4)及补丁
    2 小时前
    发表于 2020-8-22 01:18:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2015sp1Xilinx14_4,3.68GB
    发布日期
    16-3-8
    受支持的操作系统
    Windows Vista 32-bit
    Windows Vista 64-bit
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    校验和
    MD5: b1f4b74482a8a6926f20e698e5db1a6d
    SHA1: 9ac61625d5a50834c883ec5f356792c22f9647f5
    SHA256: bc38a8a5bee103d05e5d6a12153bf95b7e5008e0fd8f6682bf6a2b5bb8c101bc
    CRC32: 32f03cea
    补丁LVFPGAVivado2015SP1_f2.exe,460MB,
    发布日期
    16-9-27
    受支持的操作系统
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    MD5: 0af6b0cd97505636d43263c9266c07fa
    SHA1: 6e4ea6d8e20f6e8b1e10a6c8ac9305418a45e984
    SHA256: 781aaa6a2d817511fa261ed363b3042cfa657de36fb37bf546ec4c1056fa28c7
    CRC32: 5514b432
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGA-Vivado2014.4CT-2015SP1.txt (522 Bytes, 下载次数: 2, 售价: 10 圆)
    LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tools for Windows Readme
    December 2015
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows, including system requirements and installation instructions.
    This media gives you access to Xilinx compilation tools for Vivado 2014.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Windows computer. You also must install these tools on the development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use FPGA IP Builder, or use third-party simulation.
    The following table lists the system requirements for the Xilinx compilation tools. Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW.
    Vivado 2014.4
    ISE 14.7
    Operating SystemWindows 7 Service Pack 1/Vista (32-bit and 64-bit)Windows 7 Service Pack 1/Vista/XP Professional (32-bit and 64-bit)
    Disk Space
    11 GB
    Note  NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    The following sections contain the NI hardware supported by the Xilinx compilation tools on Windows.
    Xilinx Compilation Tools for Vivado 2014.4
    Use the Xilinx Compilation Tools for Vivado 2014.4 to compile FPGA VIs for the following devices:
    • IC-317x
    • NI 914x
    • NI cRIO-903x, NI cRIO-906x
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5820R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    • NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    • NI USB-785xR
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Xilinx Compilation Tools for ISE 14.7
    Use the Xilinx Compilation Tools for ISE 14.7 to compile FPGA VIs for the following devices:
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PCIe-784xR, NI PCIe-785xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    • NI 9144, NI 9146, NI 9148, NI 915x
    Install the Xilinx Compilation Tools for ISE 10.1 if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code FPGATool101 to download the Xilinx Compilation Tools for ISE 10.1.
    You can find installation instructions in the LabVIEW FPGA Module Release and Upgrade Notes, which are available online at ni.com/manuals and on the LabVIEW Platform media.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    NI LabVIEW FPGA Module Xilinx Compilation Tools for Windows Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW FPGA Module Xilinx Compilation Tools for Windows will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of LabVIEW FPGA Module Xilinx Compilation Tools for Windows that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    Info Code
    LabWindows™/CVI™cvi_lifecycle
    © 2012–2015 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW \FPGA\Legal
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    374738D-01
    LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tool for Vivado 2014.4 Patch Details
    Updated Mar 17, 2020
    This document contains information about all patches available for the following LabVIEW products:
    • LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tool for Vivado 2014.4
    All issues fixed in each patch are listed in the tables below. National Instruments strongly recommends that you install the latest patch to all LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tool for Vivado 2014.4 installations.
    Issues Fixed in LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tool for Vivado 2014.4 f2
    ID
    Description
    574086
    IP Integration Node and CLIP can fail to import external VHDL for FPGA targets that use the Vivado compiler.
    GMT+8, 2026-4-23 10:50
