查看: 2824|回复: 0
[NI软件产品] NI DIAdem 2014 Win32Eng/Ger NI数据管理软件DIADEM2014基本高级专业版下载DIAdem14.0.0
    3 小时前
    发表于 2020-8-9 19:43:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    diadem_14.0.0f5641_english.zip,从2014版起,将默认包含DAC模块,不再另外发行DAC版本的DIAdem软件。
    英语版百度网盘下载地址和NI官方下载地址:
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    DIAdem14.0.0-2014.txt (264 Bytes, 下载次数: 2, 售价: 10 圆)
    德语版百度网盘下载地址和NI官方下载地址:
    DIAdem14.0.0-2014 Ger.txt (526 Bytes, 下载次数: 0, 售价: 10 圆)
    DIAdem 2014 Release Notes
    2014
    Version 14.0.0
    July 2014
    This file contains information on DIAdem 2014:
    Notes on DIAdem 2014
    Compatibility of DIAdem 2014 to DIAdem 2012
    New Features in DIAdem 2014
    DIAdem is the National Instruments software for analyzing and documenting data from various sources.
    For correct DIAdem performance, the following minimum requirements must be met:
    Hardware
    CPUx86 compatible processor, 1.6 GHz or more
    Amount of memory1 GB or more
    Hard disk memoryDepending on the operating system, up to 2.8 GB free storage space, of which at least 1.8 GB on the system partition
    Graphics boardColor depth at least 16-bit (High Color), 24-bit, or 32-bit (True Color) recommended
    Screen resolutionAt least 1024x768
    Operating Systems
    • Windows XP Professional 32-bit Service Pack 3 or later
    • Windows Vista 32-bit or 64-bit with Service Pack 2 (as 32-bit application)
    • Windows 7 32-bit or 64-bit with Service Pack 1 (as 32-bit application)
    • Windows 8.1 32-bit or 64-bit (as 32-bit application)
    • Windows Server 2003 R2 32-bit with Service Pack 2
    • Windows Server 2008 R2 64-bit with Service Pack 1 (as 32-bit application)
    • Windows Server 2012 R2 64 Bit (as 32-bit application)
    Note  DIAdem runs only with restrictions on the N or KN edition of Windows because the multimedia support is missing. You can obtain this as "Media Feature Pack" from Microsoft and install it later.
    Under Windows Server 2012 R2 64-bit you cannot play videos in DIAdem VIEW.
    Administration
    FirewallThe firewall displays warnings while DIAdem installs and while DIAdem launches, for the following reasons:
    The usireg component executes during the installation of DataPlugins. The DataFinder, which you use for searching and navigating in files, then starts. When DIAdem launches, a DNS query determines whether to license locally or whether to use a license server.
    If you want to be able to use all the DIAdem functions, National Instruments recommends that you select "Do not block" for all programs listed. This also applies when you want to evaluate DIAdem. Refer to ni.com/info under the info code winxpsp2.
    Windows User RightsDIAdem and its components are basically executable under the preconfigured Microsoft Windows user accounts from User upwards. DIAdem must be installed with complete administrator rights.
    If you operate various DIAdem versions on one computer, you only have the entire range of functions in each version if you have administrator rights.
    Miscellaneous
    • Internet Explorer
    • If you want to display maps in the panels VIEW and VISUAL with Microsoft MapPoint, you must install MS MapPoint version 2010 and later.
    • Recommended:
      - Adobe Reader to display manual files
      - Adobe Flash Player for Microsoft Internet Explorer to display the tutorials
    • DIAdem Version 9.0 and LabVIEW Version 7.1, and later versions, use a shared software component that is updated when you install DIAdem. When you uninstall DIAdem, the current version of the shared component remains. This is intentional and has been tested extensively.
      The installation functions were tested parallel to earlier DIAdem versions down to DIAdem 11.0.
    • For the DataFinder in DIAdem 2014, any index files from earlier DIAdem versions must be regenerated. This occurs automatically when you launch DIAdem. Depending on how many files are to be indexed, this may take quite some time.
    • It is strongly recommended that you install DIAdem in the suggested folders on Windows Vista or later Windows versions, or that you specify the folder exclusively in the path selection dialog box in the setup program. In particular, changing the suggested program path manually in the installation program can cause problems in DIAdem.
    • When executing DIAdem or DIAdem scripts under Windows Server 2003, runtime errors might occur due to an error in the runtime library of the system. As a workaround, Microsoft has provided a hotfix which you can download at http://support.microsoft.com/?scid=kb%3Ben-us%3B955536.
    • To activate DIAdem 2012 and later versions, you must create a user profile on ni.com. The evaluation period is now 7 days without a user profile. If you create a user profile, this period is extended by an additional 45 days.
    • Previously the path for graphic displays (MediaWritePath) was synchronized with the document path by default. From DIAdem 2014, a media file, such as a PDF, can be saved in any folder without changing the other paths. Select Settings»DIAdem Settings»Select Path to switch this behavior to the extended path behavior.
    • The GFSODBC.DLL is not registered by default in the DIAdem GPI registration. You can register the DLL manually over the GPI registration. However, we recommend you use the ADO interface to access databases in VBS. Refer to the help files for more information.
    • The following changes were made in order to align the DIAdem VIEW interface with the REPORT interface:
      • The ContourCurves collection was renamed CurvesContour.
      • The collection Curves was renamed Curves2D.
      • The properties CurrCurve, LeadingCurve, and SetLeadingCurve were moved from View.ActiveSheet.ActiveArea.DisplayObj into the curves collection of the respective display type.
        The previous names and properties are still available so that scripts can still run, however auto-completion by the script editor is no longer available.
    • In DIAdem-ANALYSIS, Linear mapping was moved from the Curve Fitting bar to the Channel Functions bar.
    • In DIAdem DAC the menu item Insert»Display Instruments»Display in DIAdem INSIGHT was removed.
    • When loading a DAC block diagram, DIAdem now checks whether the block diagram contains outdated blocks. The block diagram can still run with these blocks, however the outdated blocks are identified with a label. Please replace these with current blocks.
      In addition, the DLL 'GfSPack4.DLL' is no longer registered automatically. If an existing block diagram uses blocks from this DLL, the loading of the block diagram already leads to an error message, which prompts the user to register the DLL manually over the GPI registration. Only after this registration can such a block diagram run again.
    • In order to use the following DIAdem drivers the following NI software components must be installed:
      DriverComponentsVersion
      ADCSAutomotive Diagnostic Command Set>= 1.1.1
      DAQmx driverNI-DAQmx>= 9.4
      ECU MCECU Measurement and Calibration Toolkit>= 2.3.1
      XNETNI-XNET>= 1.3.0
    • In DIAdem SCRIPT the AUT/VBS converter can no longer be requested from the interface. It can still be started with the AUTToVBS script command.
    • The outdated command ChnGet() is labeled obsolete in the DIAdem Help. It still works in DIAdem 2014 but will be omitted in future versions.
    • From Version 2012 SP2, the file, group, and channel properties with the names registertxt1 ... registertxt3, and the channel properties registerint1 ... registerint6, and registerval1 ... registerval6 are no longer indexed. These properties are no longer available for search queries.
    • The local "My DataFinder" can no longer be shared for remote access. For these scenarios please use the DataFinder Server Edition.
    • The algorithm for how DIAdem REPORT specifies the display of curves when group references are not explicit, has changed. This may lead to the modified display of existing layouts. You can modify this behavior with the "REPORT channel references refer to the structure view of the Data Portal" setting in the Compatibility dialog box. For more details refer to the "Compatibility" section in the help.
    • The REPORT text object has been revised and rarely used methods and functions were removed. These include paragraph formatting function and the support of objects of other applications such as pictures or Excel tables. The following functions also no longer work:
      TxtBufOpen()
      TxtBufClose()
      TxtBufShow()
      TxtBufFontAttr()
      TxtBufTextSearch()
      TxtBufNextLine()
      TxtBufLineSelect()
      TxtBufTabCellSet()
      TxtBufRGBSet()
      TxtBufHSISet()
      TxtBufBackHSISet()
      If you have further questions about the functions of the text object, please contact our support.
    • VBS code for opening a REPORT dialog box in the old script syntax can no longer run. You must convert the request to the new API.
      Old:GraphObjOpen("2D-Axis1")
      Call SudDlgShow("Main",ResourceDrv&"D2Axis.SUC")
      GraphObjClose("2D-Axis1")
      New:Report.ActiveSheet.Objects.Item("2D-Axis1").ShowPropertiesDlg
    • If a curve transformation is used in a REPORT layout, the "Curve Transformation" dialog box was overloaded, and variables, which require the previous call of GraphObjOpen, such as, for example, CurveNo, are accessed within this dialog box, you must now call GraphObjOpen within the user dialog box.
      Add the following line at the beginning of the script:  Call GraphObjOpen(CurrMainObjectName)
      Add the following line at the end of the script:
        Call GraphObjClose(CurrMainObjectName)
    • From DIAdem 2014, performance reasons require a modified algorithm for deleting a channel group. The algorithm might cause a change in the channel numbering of newly created channels. If the recommended channel reference by name or index is used, no changes occur.
      The following commands are affected:GroupDel(...)
      Data.Root.ChannelGroups.Remove(...)
      Data.Remove()
    • The AutoTeachLstMode variable is obsolete and will no longer be supported in DIAdem 2015 and later versions.
    • The script command DataFinder.Search(Query) returns an error if a non-indexed custom property is used in the query. In DIAdem 2012, 0 results were returned in this case.
    New Features in DIAdem 2014General
    Double-click on the right side of the worksheet tab on the bottom in the panels DIAdem VIEW, DIAdem REPORT, and DIAdem SCRIPT to create a new page.
    The configuration dialog boxes of all DIAdem modules were combined to one joint dialog box.
    The dialog box that refers to files that were not saved when you exit DIAdem has been revised.
    DIAdem NAVIGATOR, DataFinder, Data Portal
    DIAdem now supports assignment channels, which assign texts to values or value ranges in the channel properties.
    The first column of the search results list can be loaded in the context menu.
    The setting "Reset Column Width" was added to the context menu of the search results.
    The function for reduced loading - context menu Data Reduction - defines data sections.
    The DataPlugin wizard supports the combination of a date and a time channel.
    A user-defined property can be deleted or renamed in the context menu in the Data Portal.
    The Bus Log Converter can now convert the IOS file format from IOSiX, however, the converter only includes the CAN bus logfiles and the GPS data.
    DIAdem VIEW
    DIAdem VIEW offers the new display types Bode, Polar, Orbit, and Shaft Centerline.
    Curves can be temporarily deactivated in 2D axis system.
    Constants can be defined in 2D axis system.
    An individual axis scaling with individual curve assignments was added to the displays n Y-Axes and n Systems.
    The 2D axis system now also supports harmonic cursors and sideband cursors.
    Columns can be locked in channel tables. These remain visible when you scroll over the columns.
    If you drag and drop a channel from the Data Portal into a channel table, which displays all channels, the columns are positioned in such a way that this channel becomes visible.
    DIAdem VIEW supports the Media Foundation for the display of videos.
    DIAdem ANALYSIS
    The Integration function provides two integration methods.
    The new channel function Numeric Channels <-> Assignment Channels creates assignment channels from numeric channels, waveform channels, and text channels and vice versa.
    The new channel function Wrap / Unwrap Phase processes jumps in a channel.
    The new channel function Resampling maps signals on another frequency range or with an interpolation channel.
    The channel function Sort Channel Values now supports several control channels for a staged sorting of channels.
    The new function Frequency Weighting (A-, B-, C-Filtering) executes a frequency weighted filtering of noise signals.
    The setting Calculate both sides was added to the Cross Correlation function.
    The new function AC/DC Coupling removes the bias from a signal.
    The Full Spectrum FFT calculates various FFT analyses for vibration sensor signals. Initially the analyses are separate and then the spectra are combined to a complex FFT.
    The new function Pulse Detection analyses and corrects tachometer signals.
    The new function Order Analysis for Bode Display calculates the amplitude and phase of certain orders for vibration sensor signals.
    The Shaft Centerline function calculates the movements of a rotating shaft in the bearing box.
    DIAdem REPORT
    In the layout REPORT objects can be aligned with a grid.
    The curve expansion now also supports channel groups.
    Every dialog box in DIAdem REPORT has a preview to show the settings made in the layout.
    The format setting hhh displays time data as hours including those that are greater than 24 hours.
    If you disable the setting Allow interactive rotation, you can fixate the axes in 3D axis systems.
    Partial load structure displays and hyperbola displays were added to the Characteristic Diagram which now supports automatic labeling of the isolines along an imagined line.
    In 2D tables you can now define different background colors for columns and rows and format cells event-driven.
    DIAdem DAC/ DIAdem VISUAL
    The NI ECU Measurement and Calibration Driver was revised and now offers a new configuration dialog box.
    The Script Driver was revised and an interrupt-controlled measurement was added.
    The FFT calculation in packet processing now supports any block size.
    The new display instrument Map Display displays the measured GPS signals with a position pointer and a track in the map.
    DIAdem SCRIPT
    Complex tasks can be distributed to different processor cores with the multicore scripting function. In this case, so-called DIAdem workers take over the processing of individual task sections.
    A curve preview can now display 2D graphics in SUD dialog boxes.
    The following items are the IDs and titles of a subset of issues fixed in DIAdem 2014. This is not an exhaustive list of issues fixed in the current version of the DIAdem. If you have a CAR ID, you can search this list to validate that the issue has been fixed. The DIAdem Knowledgebase contains a list of fixed issues from earlier DIAdem versions under the search term Fixed Issues.
    CAR IDDescription
    General
    397167DIAdem does not export WMF files as placeable WMF files.
    402973DIAdem does not convert date/time values which contain time information that are before 12/30/1899 correctly from the DIAdem time format into the VBS time format.
    403684DIAdem does not always load the newest installed LabVIEW Run-Time Engine when initializing the LabVIEW Run-Time Engine with default parameters.
    413440The version information for the script engine and the debugger contains a comma instead of a point in front of the build number.
    415377If a channel name contains the % character, the program might crash when a channel property is dragged and dropped from the Data Portal onto a panel.
    420518If a TUC file for the definition of a unit set contains units whose names contain one or more commas, DIAdem cannot read this file.
    425087The "DIAdem PDF Export" printer does not use the specified margins.
    443285If you access the value of a channel in a REPORT table or with the Cht command and the value is larger than the maximum channel length, you do not receive an error message but the value NoValue.
    460887If you are working with two or more monitors arranged on top of each other and have specified this in the screen display settings of your operating system, DIAdem hides the Data Portal when you switch panels if DIAdem is on the upper monitor.
    464451If you generate a long time channel in the time unit milliseconds with the ChnGenTime command and save it in a TDMS file, this channel deviates from the originally generated channel in the millisecond range when it is loaded.
    Data Portal
    381807If the Data Portal contains many channel groups, deleting the top channel groups is slow.
    462640DIAdem does not always process 2-byte digits at the end of a channel name correctly.
    NAVIGATOR
    367100When Vector log files with the filename extension .mdf are converted with the Bus Log Converter, the generated values of the time channels are a factor 10 to low.
    368184The Bus Log Converter does not support the logfile format KVASER.log.
    375356When PCAN Trace files from version 10.3 are converted in the Bus Log Converter, the program might crash if records have more than 8 data bytes.
    382995When the loading parameters are missing, the LoadData() command uses the loading parameters of the data store open in NAVIGATOR without checking whether the elements to be loaded originate from this data store.
    390999The LoadChannelByName() command always refreshes the Data Portal even if the refresh mode was disabled with the UIAutoRefreshSet() command.
    393772The Bus Log Converter returns the ID of a frame as group property only if the ID is a decimal display.
    403222The DataPlugin Text Wizard does not load date/time information with AM/PM correctly.
    403391You cannot load elements derived from AoTest or AoSubtest from the search results list of ASAM data stores.
    409302The DataFinder generates additional tdms_index files for TDMS files even if no tdms_index files existed previously.
    415743DIAdem only loads the first element of multiple selections of aoTest type elements or aoSubTest type elements from the data stores into the Data Portal.
    421487The Excel DataPlugin Wizard cannot read XLSX files which contain empty cell tags () within a definition, for example, .
    425293If DIAdem NAVIGATOR is closed, the return value of the Navigator.LoadProperty() method is not filled.
    435433If you convert a Vector-ASCII file with decimal normal and extended IDs with the Bus Log Converter, DIAdem marks from the first extended ID all IDs as extended.
    436609The Bus Log Converter cannot open certain FIBEX files.
    436623If the first cells of an Excel table are empty, the Excel DataPlugin wizard cannot always specify the data type of a channel correctly.
    436689Search queries for data stores cannot be extended with drag and drop from the Data Portal.
    463861Only the first column in a search results list might be visible and it might be impossible to scroll to further columns.
    468795You cannot save DAT files as Real32 or Real48 data types if the DAT file contains NoValues.
    469724If data is saved in ATFX format, an instance attribute with the same name is exported in addition to the PropertyID.
    VIEW
    336519In logarithmic display, 2D axis systems cannot be scaled below the curve minimum.
    374295If scrolling in the cursor range in the layout is enabled for at least four 2D axis systems and the arrow keys are used for scrolling, the program crashes.
    399937If you want to display dynamic isolines in a contour display in the full screen mode, the program crashes.
    411276The cursor does not always move evenly in 2D axis systems if the x-channels are monotonic falling.
    413171If an x-axis is zoomed a lot, DIAdem might label all ticks the same.
    418748In a contour display the width of the legend columns cannot be changed.
    446319Reducing the points of a track does not work optimal when a map display is zoomed.
    476530In the dialog box of the map display the maximum zoom level is 18, even though there are up to 19 zoom levels.
    ANALYSIS
    359813If the peak value or time-at-level classification methods are used, rounding errors occur which result in incorrect assignments and results if one class limit is 0 and the values are classified between -1E-16 and -1E-18.
    360320The ChnPeakDetect command does not check whether a x-channel is monotonic rising.
    360650In some cases you cannot select the setting "Create index channel" in the FFT dialog box with a time signal.
    362549In the English and Japanese version of the "Find Peaks" function, the search criteria Maxima and Minima are reversed.
    363402If you execute a crash calculation which creates new custom properties at the input channel, DIAdem does not display these new properties directly in the properties window.
    368399The ChnPeakDetect command does not check whether NoValues exist before executing, but aborts the calculation without an error message about NoValues when the signal contains NoValues.
    371903The THIV calculation (Theoretical Head Impact Velocity) returns incorrect results when the distance between head and centre of gravity is not equal zero.
    375146The order analysis in the time domain divides the start value and the end value into incorrect rpm steps when the "Reduction according to RPM" setting is enabled.
    378827In the English version there are errors when executing the calculation template Calculation_Example.tca. The associated dialog box to edit this calculation cannot be opened.
    452506If the last values in the y-channel are constant, linear mapping calculates incorrect values.
    REPORT
    251342If you move several objects several times, the object positions are imprecise.
    350860In a number-oriented layout, DIAdem deletes x-channel entries if these entries were created with the object-oriented script interface and the dialog box of the 2D axis system was exited with cancel.
    366035If the start value and end value of a scaling are the same in a 2D axis system, the display can only continue if you press ESC.
    375177If you use the object-oriented API to add a subaxis to a 2D axis system in a script, the program might crash.
    378351After exporting a PDF, DIAdem sets the default printer to "DIAdem PDF Export".
    378384Printing PDFs does not work if no free printer port or LPT port is available.
    380997If you select the scaled setting and the user-defined setting as page size, DIAdem ignores the specified page ratio and uses instead the default page ratio.
    383000If you use the %(/yPosition) setting, DIAdem does not position the points in 3D axis systems correctly.
    383216Sometimes, DIAdem does not plot isolines in a 3D axis system.
    398184If you select the text position "Centered and clipped", DIAdem does not display the curves in the display mode "Line and points" in a 2D axis system.
    399754DIAdem does not always display all columns in the legend of a 2D axis system if you deleted other columns before.
    399756If you select several objects of which at least one object has a fixed height/width ratio, you can only change the group size with a fixed height/width ratio.
    404582If values were deleted from a channel, the 2D table display does not check the current channel length of text channels and displays too many values.
    4086452D axis systems do not support the VU function as x-constants.
    422835Display errors might occur when reports are zoomed.
    423844Incorrect channels assignments might occur in 2D axis systems.
    425330Depending on the selected line width, DIAdem does not print very narrow rectangles.
    427655If you exit a REPORT dialog box with "Cancel" or use the "Undo" function, DIAdem deletes the TagTemporary property.
    429778If you try to set the frame of a master layout into the foreground, the program crashes.
    435410If you use channels with the length 0 in a characteristic diagram display, the display is incorrect and the program might crash.
    435444DIAdem does not highlight curves that protrude the axis if you move the mouse over them.
    435984In the expanded mode in 2D axis systems, DIAdem ignores the setting "Display curve".
    438720The double-click might not work in a report.
    456413DIAdem does not save the legend position correctly if you use the setting "Bound to axis system".
    365690DIAdem might create invalid channel references in the curve transformation in a 2D axis system.
    SCRIPT
    377669The ASCIIBlockLoad() command does not load all values from a text file.
    383205The DirLstGet() command returns an error during the recursive search if the function encounters a folder that only contains other folders.
    402226If you specify an output format, rounding errors might occur during the conversion of numbers with the Str function.
    402970The RTT function cannot convert vbDate values which contain fractions of seconds.
    416125The FileNameGet command does work if the selection lists for filename extensions are very long.
    426071The Round method cannot calculate quantity based.
    428636The functions NotB, SHR, SHL, GetB, and SetB accept a negative bit index and ignore prefixes.
    428989The DataPlugin script function Workbook.Sheets.Exists() always returns TRUE, even if the worksheet does not exist.
    436760DIAdem might crash if the LabVIEW Run-Time Engine is initialized and deinitialized several times in a script.
    442154In the scaled display, DIAdem REPORT changes the properties Top and Right when changing the properties Bottom and Left with the object-oriented interface.
    DAC
    364919Auto scaled displays or displays with interactively changeable y-scaling ranges do not display measurement values if a preceding scaling block contains negative slopes.
    365260If several script blocks use the same script in a block diagram, the scripts might influence each other.
    370297When a measurement starts or ends with the block PC loudspeaker, an error message might occur under Windows 8 (32 Bit).
    373511In the ECU MC driver dialog box, DIAdem does not arrange the signals according to their function or sub-function.
    392828If you start a block diagram with an AUT script block which does not contain a valid AUT file, you cannot use DIAdem afterwards.
    394106The parse function of the script driver returns an incorrect value for ASCII characters over 127.
    397179Measurements which save data directly in the Data Portal generate too many channel groups if the settings "With section creation" and "Use new channels for every measurement" are used.
    403725In measurements with a software clock with the NI DAQmx driver, the first measurement value is NoValue.
    405947If you try to measure different bus systems in the same DAC clock system in the XNET driver, DIAdem measures only the channel from the first bus correctly.
    406245During long-term measurements with the NI-CAN driver in the single point mode the buffer on the CAN board might overflow.
    406513The program might crash if you double-click a bus or a block terminal of a subblock diagram.
    411275When the filenames are generated automatically, the DAC storage block always saves the measurement data in files which start with DACDATA.
    411277If you start measurements very often under Windows 7, DIAdem might not be able to execute commands.
    411471When you start a measurement with the NI-DAQmx driver, sporadic error messages from the synchronization manager might occur.
    421483DIAdem displays numeric and table displays even if the setting is "No color".
    429777The digit and table display in VISUAL ignores the selected background color if you disable the frame around the values.
    432292Under Windows 8, the size of the VISUAL window might change during a measurement.
    436640The dialog box for the "Numeric Input" block cannot be opened.
    449635The program crashes, if you measure or output the same signal several times in a measurement with the NI DAQmx driver.
    456771The XNET driver does not always save the setting for the bus termination of CAN and LIN.
    462684When loading a block diagram, DIAdem renames a block that has a base name if this block diagram contains a second block with the base name and the postfix 0.
    462719The packet blocks for frequency weighting and level calculation do not function correctly when the unit for the x-values is missing in the data packets. If the unit is missing, the blocks will assume the x-values are in seconds in future versions.
    469599In the offset correction block, DIAdem displays an error when an input signal is not active.
    For more information on DIAdem, go to the DIAdem help Help»Contents.
    Use Help»Examples in DIAdem to start the DIAdem ExampleFinder. You can find DIAdem examples in the examples directory below the program directory. You can modify examples to suit your needs, or you can copy and paste parts of the examples into your own files.
    • Refer to KB 4CJDP38M, Automating the Installation of a Single Installer for more information on automatic installations of individual NI products.
    • Refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer? for a description of the version of the NI Installer your product contains.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as NI MAX, to either the Start screen or the Taskbar on the desktop, as necessary:
    Finding All Programs
    NI DIAdem Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    As of July 1, 2016, NI DIAdem will no longer support the operating systems Microsoft Windows Vista, MS Windows XP, and MS Windows Server 2003. Versions of DIAdem that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2003—2014 National Instruments Ireland Resources Limited. All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, This includes photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    • Legal notice: Notices are located in the \_Legal Information and directories.
    • EULAs: EULAs are located in the \Shared\MDF\Legal\license directory.
    • Review \_Legal Information.txt for information on including legal information in installers built with NI products: \_Legal Information.txt
    GMT+8, 2026-4-23 11:02
