查看: 7298|回复: 3
[LV工具模块] LabVIEW 2018 Robotics Full Win32Eng LV2018机器人模块Robotics2018完整版下载
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-8-7 00:51:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW机器人模块提供了用于设计机器人控制系统的硬件和软件开发工具。
    LabVIEW机器人模块是LabVIEW编程环境的一个附加软件。该模块包含了一个全面的机器人库,其中包括针对机器人传感器和执行器的内置连接、实现智能操作和鲁棒感知的基本算法,以及使机器人或车辆移动的运动功能。您可以将算法和控制代码部署到NI实时嵌入式硬件,LabVIEW机器人模块可帮助工程师和科学家设计和原型验证自动和半自动驾驶设备,包括农业和军事系统、机器人救援平台、水下和飞行器、个人和服务机器人、医疗机器人设备以及学术和科研机器人。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    RBT2018.txt (680 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2018 Robotics Module Readme
    March 2018
    This file contains important information about the LabVIEW 2018 Robotics Module, including installation instructions, and known issues. This file also contains information about using the LabVIEW Robotics Starter Kit and LabVIEW Robotics Software Bundle.
    Recommended Device Drivers for Robotics
    LabVIEW Robotics Module Runtime
    The LabVIEW Robotics Module is a software package that allows you to develop robotics applications using LabVIEW. The Robotics Module provides robotics-related algorithms, drivers that allow you to control certain sensors, hardware and software setup wizards, and example VIs that demonstrate robotics concepts.
    The LabVIEW Robotics Starter Kit gives you access to the products you need to program the robot in your Starter Kit package. The LabVIEW Robotics Software Bundle gives you access to the Robotics Module and many other products in the LabVIEW platform.
    In addition to the system requirements for the LabVIEW Development System, the Robotics Module has the following requirements:
    • LabVIEW 2018 Full or Professional Development System
    • At least 700 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018.
    The Robotics Module supports the following operating systems:
    • Windows 10 (version 1709)/8.11/7 SP12
    Note  In 2016 the LabVIEW Robotics Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 Robotics Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 Robotics Module to an unsupported OS. Additionally, after installing the LabVIEW 2018 Robotics Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    You can install all of your LabVIEW products—including the Robotics Module, Robotics Starter Kit, and Robotics Software Bundle—using the LabVIEW 2018 Platform media.
    Note  Some Robotics Module features, such as the Robotics Project Wizard, Robotics Hardware Setup Wizard, and many examples, require additional NI software, such as the LabVIEW Real-Time Module, LabVIEW FPGA Module, and NI-RIO drivers. If you purchased the Robotics Starter Kit or Robotics Software Bundle, you have access to this software. If you purchased just the Robotics Module, select Start»All Programs»National Instruments»NI License Manager to launch the NI License Manager, which displays the software for which you have access.
    Installing Hardware
    If you purchase the Robotics Starter Kit or Robotics Software Bundle, you need to install and configure NI hardware after you install the device drivers. If you use an NI Single-Board RIO or CompactRIO product, you can use the Robotics Hardware Setup Wizard, which launches after you install the Robotics Starter Kit or Robotics Software Bundle and restart the computer, to configure the target. In the Robotics Hardware Setup Wizard, complete the instructions that appear on the screen to detect RT targets in the system and configure a target for use. You also can select Start»All Programs»National Instruments»LabVIEW Robotics»Robotics Hardware Setup to launch the Robotics Hardware Setup Wizard.
    If you use another type of target, use the NI Measurement & Automation Explorer (NI MAX) to detect, configure, and test an RT target. Launch MAX by selecting Start»All Programs»National Instruments»NI MAX or by double-clicking the NI MAX icon on the desktop.
    Refer to the installation instructions included with your device for additional information about installing and configuring your NI device.
    Purchasing Robotics Module Run-Time Licenses
    You must purchase a Robotics Module Run-Time License for each target machine not produced by NI onto which you want to install a robotics application. Refer to the NI website for more information about Robotics Module run-time licensing. Contact an NI sales representative or visit ni.com to purchase run-time licenses.
    Note  Other products you use to develop robotics applications also might require run-time licenses. Refer to the documentation for those products for information about purchasing run-time licenses.
    Products in the Robotics Starter Kit
    The Robotics Starter Kit contains the following products, which you can evaluate for one year. When your evaluation period ends, you can purchase the Robotics Software Bundle, which gives you access to the Robotics Module and many other products in the LabVIEW platform, including the products in the Robotics Starter Kit. Refer to the product readmes for information about each product, including installation and activation instructions, known issues, and bug fixes.
    • LabVIEW Development System
    • Control Design and Simulation Module
    • FPGA Module
    • MathScript RT Module
    • Real-Time Module
    • Robotics Module
    • Vision Development Module
    Note  The Robotics Starter Kit contains compilation tools for Virtex5 and newer devices, such as the Starter Kit hardware target. The Robotics Starter Kit installer also installs NI-RIO which includes NI-RIO drivers and supports for the Starter Kit hardware target.
    Products in the Robotics Software Bundle
    The Robotics Software Bundle contains the following products. Refer to the product readmes for information about each product, including installation and activation instructions, known issues, and bug fixes.
      • Control Design Assistant
    • FPGA Module
    • SoftMotion Module
    • Real-Time Module
    • Robotics Module
    • Statechart Module
    Note  The Robotics Software Bundle also contains compilation tools for Virtex5 and newer devices.
    NI recommends that you install the device drivers under the following categories from the NI Device Drivers media for use in programming common robotics applications.
    Note  When an item in the Features tree of the NI Device Drivers media allows you to choose support for multiple versions of LabVIEW, select support for LabVIEW 2018.
    • Data Acquisition
      • NI-DAQmx
    • Instrument Control
    • Reconfigurable I/O
    • Motion
    • Vision Acquisition Software
    • Distributed I/O
    • Real-Time and Embedded
    • NI I/O Trace
    The Robotics Module includes the LabVIEW Robotics Module Runtime. The Robotics Module Runtime allows you to build installers to distribute stand-alone applications, shared libraries, and source distributions to a computer that does not have the LabVIEW Development System or the Robotics Module. When you build an installer, add the Robotics Module Runtime and the LabVIEW Run-Time Engine to the installer build.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the Robotics Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Robotics Module.
    Refer to the LabVIEW Robotics Starter Kit Safety Guide (StarterKit_Safety_Guide.pdf in the labview\readme directory) for important information about protecting yourself from injury and protecting the Starter Kit hardware from damage.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Robotics Module are located in the labview\examples\robotics directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Refer to the Robotics Module»Reusing Robotics Examples topic on the Contents tab of the LabVIEW Help for information about adapting LabVIEW project-based examples that include hardware targets to fit a different target you want to use.
    Some robotics examples require additional NI software, such as the LabVIEW FPGA Module, Control Design and Simulation Module, or Vision Development Module. In the NI Example Finder, select an example and refer to the Information section for a list of software you must install to run the example.
    © 2009–2018 National Instruments. All rights reserved.
    375330D-01
    发表于 2021-3-20 09:13:10 | 显示全部楼层 来自:浙江省温州市 电信
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 2024-2-4 18:45:10 | 显示全部楼层 来自:广东省东莞市 电信
    GMT+8, 2026-4-1 10:46
