查看: 4051|回复: 0
[LV工具模块] LabVIEW 2010 Robotics Full Win32Eng LV2010机器人模块Robotics2010完整版下载
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-8-6 23:12:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW机器人模块提供了用于设计机器人控制系统的硬件和软件开发工具。
    LabVIEW机器人模块是LabVIEW编程环境的一个附加软件。该模块包含了一个全面的机器人库,其中包括针对机器人传感器和执行器的内置连接、实现智能操作和鲁棒感知的基本算法,以及使机器人或车辆移动的运动功能。您可以将算法和控制代码部署到NI实时嵌入式硬件,LabVIEW机器人模块可帮助工程师和科学家设计和原型验证自动和半自动驾驶设备,包括农业和军事系统、机器人救援平台、水下和飞行器、个人和服务机器人、医疗机器人设备以及学术和科研机器人。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版:
    链接: 请注册登录视觉论坛会员,购买附件查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版校验和:
    (MD5)
    9ad1912722aa7410e8f30ebc245d05df
    (SHA256)
    e523c773f3207ed6dc2bed6b5cf962e7c2e5f989984d6bd8e7ed87480cab1816
    RBT2010.txt (582 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2010 Robotics Module Readme
    Version 10.0
    June 2010
    This file contains important last-minute information about the LabVIEW 2010 Robotics Module, including installation instructions, new features, and known issues.
    Purchasing Robotics Run-Time Licenses
    Accessing the Software and Help
    The LabVIEW Robotics Module is a software package that allows you to develop robotics applications using LabVIEW. The Robotics Module provides robotics-related algorithms, drivers that allow you to control certain sensors, hardware and software setup wizards, and example VIs that demonstrate robotics concepts.
    The Robotics Module has the following requirements:
    • LabVIEW Full or Professional Development System
    • At least 200 MB of disk space
      • Windows 7, including Windows 7 x64
      • Windows Vista, including Windows Vista x64
      • Windows XP, excluding Windows XP x64
    Note  Some Robotics Module features, such as the Robotics Project and Hardware Setup Wizards and many examples, require additional National Instruments software, such as the LabVIEW Real-Time and FPGA Modules and the NI-RIO drivers. Refer to the readme file on the installation media that shipped with your purchase for information about the products to which you have access.
    (LabVIEW 64-bit) The Robotics Module is not supported in LabVIEW (64-bit).
    You can install all of your LabVIEW products—including the Robotics Module—using the LabVIEW Platform DVDs. You can find installation instructions for the module along with activation instructions in the following locations:
    • LabVIEW Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    Note  If you purchased this product with an NI Software Suite or NI Product Bundle, such as the LabVIEW Robotics Starter Kit or Software Bundle, use the installation media that shipped with your purchase to install this product.
    If you install the Robotics Module from the LabVIEW Platform DVDs, and you want to also install the TORC JAUS Toolkit for LabVIEW and/or the Cogmation Toolkit for LabVIEW, you must click the drop-down arrow to the left of the Robotics Module item and select Custom Install from the list. Before the Robotics Module installs, additional dialog boxes open that require your input to install the toolkit(s).
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    You must purchase a Robotics Module Run-Time License for each target machine not produced by National Instruments onto which you want to install a custom Robotics Module application. Refer to the National Instruments Web site for more information about Robotics run-time licensing. Contact a National Instruments sales representative or visit ni.com to purchase run-time licenses.
    Note  Other products you use to develop robotics applications also might require run-time licenses. Refer to the documentation for those products for information about purchasing run-time licenses.
    After you install the Robotics Module, select Start»All Programs»NI LabVIEW Robotics 2010 to launch the LabVIEW Robotics environment.
    Refer to the Robotics Module book on the Contents tab in the LabVIEW Help for more information about the Robotics Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Robotics Module are located in the labview\examples\robotics directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. Refer to the Robotics Module»Reusing Robotics Examples topic on the Contents tab of the LabVIEW Help for information about adapting LabVIEW project-based examples that include hardware targets to fit a different target you want to use.
    Some robotics examples require additional National Instruments software, such as the LabVIEW FPGA Module, Control Design and Simulation Module, or Vision Development Module. In the NI Example Finder, select an example and refer to the Information section for a list of software you must install to run the example.
    Note  (Windows 7/Vista) When you open an FPGA VI in some LabVIEW project-based examples, the VI appears to have unsaved changes because the default LabVIEW font on Windows Vista differs from the default font on Windows XP. LabVIEW prompts you to save these cosmetic changes to the VI, which requires you to recompile the FPGA VI. If the VI has no other changes, you can save and recompile the VI to avoid this unsaved state when you open the FPGA VI in the future.
    The LabVIEW 2010 Robotics Module introduces the following enhancements.
    New Drivers
    The Sensing palette includes the following new drivers:
    • The new Ambient Light Sensor subpalette includes Vishay TEMT6000 drivers.
    • The new Encoder subpalette includes Maxon Encoder drivers.
    • The new Motion subpalette includes the following drivers:
      • Dynamixel Motor
      • Lynxmotion SSC32
      • TI MDL BDC24
    • The Sonar Range Finders subpalette includes Devantech SRF02 drivers.
    • The new Thermal subpalette includes Devantech TPA81 drivers.
    New Examples
    The labview\examples\robotics directory includes the following new examples:
    • OCR.lvproj
    • Ackermann Steering.lvproj
    • Astar on Occupancy Grid.lvproj
    The LabVIEW 2010 Robotics Module introduces the following behavior changes:
    • In LabVIEW 2009, after you install the Robotics Module, LabVIEW launches with a module-specific Getting Started window. In LabVIEW 2010, after you install the Robotics Module you can launch LabVIEW with the default Getting Started window or a LabVIEW Robotics Getting Started window. Refer to Accessing the Software and Help for instructions for launching the LabVIEW Robotics environment.
    • The Robotics Module 2009 installs a Cogmation subpalette on the Connectivity palette. In the Robotics Module 2010, the Cogmation VIs are installed by the Cogmation Toolkit for LabVIEW, which you can choose to install from the installation media you purchased. You must activate the Cogmation Toolkit for LabVIEW separately from the Robotics Module.
    • The scale of the front panel compass indicator contains fewer markers than in the Robotics Module 2009.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Robotics Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2010 Robotics Module. This is not an exhaustive list of issues fixed in the current version of the Robotics Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    226285Kinematic functions give incorrect results for serial arms with a non-identity base transform
    225301RS-232 VIs transmit pulses that are too long at high baud rates and should be more tolerant of jitter in received pulses
    215431Default size of aircraft attitude indicator is too large
    213616A* VIs consider infinite cost paths valid while AD* VIs do not
    210355The LabVIEW Robotics installer should not overwrite the main LabVIEW Getting Started Window
    207806The library for Kinematics VIs contains VIs that don't belong in vi.lib
    206809Rotate Vector by Quaternion VI returns a quaternion instead of a vector
    203125Error -63044 with the Robotics Hardware Setup Wizard in DownloadBitFile.vi. with NI-RIO 3.3 or later
    201025Parallel Control Loops (Simulated) example contains Map Reference.ctl, which is broken
    200994Robotics Module license file improperly named
    197674MaxSonar EZ1 RT example VI for Analog does not correctly close FPGA VI references
    197145Checkbox for systems on remote subnet and IP address control are not clickable in the Robotics Project Wizard
    196618Some sensor drivers cannot load without NI-DAQmx, especially given the Starter Kit software setup, and no warning is given
    196614Cannot drop MobileRobots API Property and Invoke Nodes in VIs created with Starter Kit software
    196330Robotics Hardware Setup can cause the Robotics Starter Kit servo motor to become unresponsive
    195944LabVIEW FPGA Module quits working after 60 days of evaluation
    195942Uninstalling LabVIEW Robotics removes the main LabVIEW Getting Started window
    195872Deployment Failed error with Robotics Hardware Setup Wizard
    195652Default size of compass indicator is too large
    195312While Loop in Skilligent example VI should stop running when an error occurs
    194940LabVIEW Robotics DVD installs LabVIEW Real-Time English when LabVIEW 2009 Japanese is already installed
    194323Navigation VIs should return helpful error when empty queue occurs
    193406Applanix driver needs a menu file so driver is visible in palettes
    193300'Start' menu link text too long to fully display on Windows 7 computers
    192495Robotics Hardware Setup Wizard should be able to find devices on other subnets
    189724Robotics Module Getting Started Window remains even when module is not licensed
    187152On Robotics»Sensing palette, most driver subpalettes do not have context help
    Important Information
    © 2009–2010 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    GMT+8, 2026-4-1 12:20
