查看: 3684|回复: 0
[NI软件产品] NI FlexLogger 2020R3(20.2.0) Win64Eng 美国国家仪器FlexLogger应用软件2020R3版即ni-flexlogger_20.2.0
    6 小时前
  • 签到天数: 3862 天
    连续签到: 55 天
    发表于 2020-8-6 00:46:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexLogger是可快速配置传感器和记录混合信号数据的应用软件,用于验证机电系统,而且完全无需编程。
    FlexLogger应用软件可帮助您使用NI DAQ硬件构建灵活、可扩展的数据记录系统,而且无需任何编程。您可以使用针对特定传感器的配置工作流程来快速设置、显示和记录来自模拟传感器、数字信号和车载通信总线等测量的同步数据,您还可以通过生成电压、电流或数字信号来驱动执行器或控制设定点,这些信号可以通过事件触发器自动响应不断变化的条件。FlexLogger可自动保存记录测试配置的元数据,以便您可以快速跟踪测试结果并比较多个测试的结果。 您还可以通过集成的数据查看器交互式地查看测试结果,以便直观地检查数据并得出结论。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    链接: 请注册登录视觉论坛会员,购买附件查看 提取码: 请注册登录视觉论坛会员,购买附件查看
    (因为单个文件大于4GB,超出百度网盘文件上限,分割成两个压缩文档分包)
    请注册登录视觉论坛会员,购买附件查看
    (MD5) 2ff96b915d1f7400f2781cb4e07e3777
    (SHA256) ea4b121d813b4241f05a67f223fc342358c7fe4af94c9ed91f86a9888182b4c5
    FL2020R3.txt (352 Bytes, 下载次数: 0, 售价: 10 圆)
    FlexLogger 2020 R3 Readme
    June 2020
    This file contains important information about FlexLogger, including system requirements, installation instructions, and supported hardware.
    Extending FlexLogger with the FlexLogger Plugin Development Kit
    Changes to Log File Metadata in FlexLogger 2019 R4
    FlexLogger Drops Support for Windows 7 64-bit in 2021
    FlexLogger is application software for quick sensor configuration and data logging of mixed signals to verify electromechanical systems, all without programming.
    Back to Top
    FlexLogger has the following minimum system requirements:
    Operating System
    RAM/Processor
    Required Software1
    • 64-bit version of Windows 10/8.12/7 SP13
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    • Latest graphics drivers4
    • 12 GB disk space
    • 4 GB RAM (8 GB or more recommended)
    • NI-DAQmx software 20.0 or higher
    • NI-XNET software 20.0 or higher
    1 Required drivers are included with the FlexLogger installer.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install these updates.
    4 For optimal system performance and stability, NI recommends using a Windows 10 operating system with the latest graphics drivers for your system installed.
    Back to Top
    NI automates FlexLogger installation using NI Package Manager. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Back to Top
    Back to Top
    New Features2020 R3 (June 2020)
    • Improved shunt calibration feedback, including calculated values displayed in channel details and error messaging
    • Scan for TEDS sensors at the project level
    • Added support for resistance measurements. Refer to the Supported Hardware section for specific model support information.
    • Support for LabVIEW 2020 in the FlexLogger Plugin Development Kit 1.3
    • (Preview Feature) Publish tags and files to a connected SystemLink Server. This preview features requires a seperate license for SystemLink Server.
    2020 R2 (April 2020)
    • Configure multiple I/O channels simultaneously, including alarm configuration
    • Apply shunt calibration to multiple channels simultaneously
    • Added read-only channel support for TEDS sensors
    • Alarm and event information logged to test TDMS file
    • Support for digital input plugin channels in the FlexLogger Plugin Development Kit 1.2
    2020 R1 (January 2020)
    • Added PXI Express support for SC Express, sound and vibration, and automotive bus modules. Refer to the Supported Hardware section for specific model information.
    • Added hardware support for:
      • NI 9262
    • Added support for LVDT/RVDT sensors
    • XY graph type added to Screens
    • Event triggering on test stop
    Back to Top
    The following tables detail the hardware models supported in FlexLogger.
    CompactDAQ
    CompactDAQ Chassis
    [td]
    NI Product
    Model Name
    CompactDAQ ChassiscDAQ-9171
    cDAQ-9174
    cDAQ-9178
    cDAQ-9179
    cDAQ-9181
    cDAQ-9184
    cDAQ-9185This chassis supports network synchronization using IEEE 802.1AS protocol. Refer to the Using Network Synchronization in Your Acquisition topic for more information.
    cDAQ-9188
    cDAQ-9188XT
    cDAQ-9189This chassis supports network synchronization using IEEE 802.1AS protocol. Refer to the Using Network Synchronization in Your Acquisition topic for more information.
    cDAQ-9191
    Note: FlexLogger does not currently support the use of onboard counters in CompactDAQ chassis.
    C Series Modules
    [td]
    NI Product
    Model Name
    C Series Voltage Input ModulesNI 9201
    NI 9202
    NI 9205
    NI 9206
    NI 9209
    NI 9215
    NI 9220
    NI 9221
    NI 9222
    NI 9223
    NI 9224
    NI 9225
    NI 9228
    NI 9229
    NI 9238
    NI 9239
    NI 9242
    NI 9244
    NI 9251
    NI 9252The NI 9252 module supports hardware filtering. Refer to the Reducing Signal Noise topic for more information.
    C Series Voltage Output ModulesNI 9262
    NI 9263
    NI 9264
    NI 9269
    C Series Current Input ModulesNI 9203
    NI 9208
    NI 9227
    NI 9246
    NI 9247
    NI 9253The NI 9253 module supports hardware filtering. Refer to the Reducing Signal Noise topic for more information.
    C Series Current Output ModulesNI 9265
    NI 9266
    C Series Voltage and Current Input ModuleNI 9207
    C Series Sound and Vibration Input ModulesNI 9230
    NI 9231
    NI 9232
    NI 9234
    NI 9250
    C Series Temperature Input ModulesNI 9210
    NI 9211
    NI 9212
    NI 9213
    NI 9214
    NI 9216FlexLogger supports resistance measurements for the NI 9216.
    NI 9217FlexLogger supports resistance measurements for the NI 9217.
    NI 9226FlexLogger supports resistance measurements for the NI 9226.
    C Series Universal Analog Input ModulesNI 9218For the NI 9218, all connectivity accessories must be configured in MAX in order to appear in your FlexLogger project.
    NI 9219FlexLogger supports resistance measurements for the NI 9219.
    C Series Strain/Bridge Input ModulesNI 9235
    NI 9236
    NI 9237
    C Series Counter Input ModuleNI 9361FlexLogger supports pull-up resistor functionality and input voltage threshold for the NI 9361.
    C Series Digital Modules (serial digital I/O)NI 9375
    • The NI 9375 can only use one port (input or output) at a time in a project.
    • You cannot use parallel and serial modules together on the same FlexLogger project unless they are installed in separate cDAQ chassis.
    NI 9403
    NI 9425
    NI 9426
    NI 9476
    NI 9477
    NI 9478
    C Series Digital Modules (parallel digital I/O)NI 9344You cannot use parallel and serial modules together on the same FlexLogger project unless they are installed in separate cDAQ chassis.
    NI 9401
    NI 9402
    NI 9411
    NI 9421
    NI 9422
    NI 9423
    NI 9435
    NI 9436
    NI 9437
    NI 9472
    NI 9474
    NI 9475
    NI 9481
    NI 9482
    NI 9485
    C Series CAN and Vehicle Multiprotocol Interface ModulesNI 9860FlexLogger supports all compatible transceiver cables for the NI 9860 (TRC-8542, TRC-8543, and TRC-8546).
    NI 9861
    NI 9862
    C Series LIN Interface ModuleNI 9866
    FieldDAQ Devices
    [td]
    NI Product
    Model Name
    Voltage Input Devices for FieldDAQFD-11601External powered sensor configuration is supported in FlexLogger.
    FD-11603Revision B and later of the FD-11603 supports hardware filtering. Refer to the Reducing Signal Noise topic for more information.
    FD-11605
    Sound and Vibration Input Devices for FieldDAQFD-11634
    Strain/Bridge Input Devices for FieldDAQFD-11637Revision B and later of the FD-11637 supports hardware filtering. Refer to the Reducing Signal Noise topic for more information.
    Temperature Input Devices for FieldDAQFD-11613
    FD-11614
    Note: FieldDAQ devices support network synchronization using IEEE 802.1AS protocol. Refer to the Using Network Synchronization in Your Acquisition topic for more information.
    Note: FieldDAQ devices support hardware filtering. Refer to the Reducing Signal Noise topic for more information. (See Notes column for exceptions.)
    PXI Express
    PXI Chassis
    [td]
    NI Product
    PXIe-1062QFlexLogger does not support any module used in a PXI peripheral slot.
    PXIe-1065
    PXIe-1066DC
    PXIe-1073
    PXIe-1075
    PXIe-1078
    PXIe-1082
    PXIe-1082DC
    PXIe-1084
    PXIe-1085 (12 GB/s and 24GB/s)
    PXIe-1092
    PXIe-1095
    PXI Controllers
    Supported embedded controllers must meet the minimum system requirements. Refer to the System Requirements section for more information.
    PXI Remote Control Modules
    [td]
    NI Product
    PXIe-8301
    PXIe-8360
    PXIe-8370
    PXIe-8375
    PXIe-8381
    PXIe-8388
    PXIe-8389
    PXIe-8394
    PXIe-8398
    PXIe-8399
    PXI Modules
    [td][tr][/tr]
    NI Product
    Model Name
    Compatible Accessories
    PXI Analog Input ModulesPXIe-4300
    • TB-4300
    • TB-4300B
    • TB-4300C
    PXIe-4302
    • TB-4302
    • RM-4302
    • TB-4302C
    PXIe-4303
    • TB-4302
    • RM-4302
    • TB-4302C
    PXIe-4304
    • TB-4304
    • RM-4304
    PXIe-4305
    • TB-4304
    • RM-4304
    PXIe-4309
    • TB-4309 (ST)
    • TB-4309 (MT)
    PXIe-4310
    • TB-4310
    PXIe-4481
    PXI Strain/Bridge Input ModulePXIe-4330
    • TB-4330
    • RM-24999
    PXIe-4331
    • TB-4330
    • RM-24999
    PXIe-4339
    • TB-4339
    • TB-4339B
    • TB-4339C
    • RM-4339
    PXI Displacement Input ModulePXIe-4340
    • TB-4340
    PXI Temperature Input ModulePXIe-4353
    • TB-4353
    • TC-4353
    PXIe-4357
    • TB-4357
    FlexLogger supports resistance measurements for the PXIe-4357.
    PXI Analog Output ModulePXIe-4322
    • TB-4322
    PXI Sound and Vibration ModulesPXIe-4464
    PXIe-4480
    FlexLogger does not currently support the Charge measurement type.
    PXIe-4492
    FlexLogger automatically selects the Medium (100 Hz) data rate for the PXIe-449x. Using data rates between 1,000 Hz and 8,000 Hz with the PXIe-449x may cause delays when configuring channels.
    PXIe-4496
    PXIe-4497
    PXIe-4498
    PXIe-4499
    PXI Vehicle Multiprotocol Interface ModulePXIe-8510 (2-Port and 6-port)
    • TRC-8542
    • TRC-8543
    • TRC-8546
    PXI CAN Interface ModulePXI-8512 (1-port and 2-port)
    Must be used in a PXIe Hybrid Compatible slot of a supported PXI Express chassis. For additional information on PXI compatibility with PXI Express chassis, visit ni.com/r/pxicompatibility.
    PXI LIN Interface ModulePXI-8516
    Note: FlexLogger does not currently support synchronization between multiple chassis or other devices in the system.
    USB Devices
    [td]
    NI Product
    Model Name
    CAN Interface DevicesUSB-8502
    LIN Interface DevicesUSB-8506
    Back to Top
    You can access the software and documentation known issues list online. Visit FlexLogger 2020 R3 Known Issues for an up-to-date list of known issues.
    Back to Top
    You can access the software and documentation bug fixes online. Visit FlexLogger 2020 R3 Bug Fixes. This is not an exhaustive list of issues fixed in the current version of FlexLogger.
    Back to Top
    You can extend the functionality of FlexLogger by creating and importing a custom plugin using the FlexLogger Plugin Development Kit (version 1.3). The FlexLogger Plugin Development Kit is available for download in NI Package Manager. Refer to the FlexLogger Plugin Development Kit 1.3 Readme for more information.
    Back to Top
    The online FlexLogger manual contains the most current help for your product version. Refer to the FlexLogger Manual, accessible from Help»FlexLogger manual, for more information about using FlexLogger.
    Users without online access can choose to use an offline version of the FlexLogger manual. To enable the use of the offline FlexLogger manual, go to File» Preferences»General and select Always use offline manual.
    Back to Top
    In FlexLogger 2019 R4, metadata properties organized as a hierarchy are defined by a tilde (~) character between properties. Previous FlexLogger versions used a double greater symbol (>>) to separate these metadata properties. Any data post-processing configured to use >> may produce unexpected results.
    Back to Top
    Back to Top
    Back to Top
    FlexLogger Drops Support for Windows 7 (64-Bit)
    FlexLogger will drop support for Windows 7 (64-bit) operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on this operating system. For detailed information about NI operating system support, visit ni.com/r/windows764bit.
    Back to Top
    © 2017–2020 National Instruments. All rights reserved.
    377046K-01
    GMT+8, 2026-4-20 14:04
