查看: 3225|回复: 0
[NI软件产品] NI FlexLogger 2019R3.1(1.8.1) Win64Eng 美国国家仪器FlexLogger应用软件2019R3.1版即ni-flexlogger_1.8.1
    半小时前
  • 签到天数: 3559 天
    连续签到: 4 天
    发表于 2020-8-6 00:17:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexLogger是可快速配置传感器和记录混合信号数据的应用软件,用于验证机电系统,而且完全无需编程。
    FlexLogger应用软件可帮助您使用NI DAQ硬件构建灵活、可扩展的数据记录系统,而且无需任何编程。您可以使用针对特定传感器的配置工作流程来快速设置、显示和记录来自模拟传感器、数字信号和车载通信总线等测量的同步数据,您还可以通过生成电压、电流或数字信号来驱动执行器或控制设定点,这些信号可以通过事件触发器自动响应不断变化的条件。FlexLogger可自动保存记录测试配置的元数据,以便您可以快速跟踪测试结果并比较多个测试的结果。 您还可以通过集成的数据查看器交互式地查看测试结果,以便直观地检查数据并得出结论。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    (因为单个文件大于4GB,超出百度网盘文件上限,分割成两个压缩文档分包)
    请注册登录视觉论坛会员,购买附件查看
    (MD5) 4d5482a30c0c85f56e365ceaceedb4fc
    (SHA256) ee9d00aff398828033fc0201eef900a50203de1b9083b61049f0b782969ef3d9
    FL2019R3.1.txt (350 Bytes, 下载次数: 0, 售价: 10 元)
    FlexLogger 2019 R3 Readme
    July 2019
    This file contains important information about FlexLogger, including system requirements, installation instructions, and supported hardware.
    Extending FlexLogger I/O with the FlexLogger Plugin Development Kit
    FlexLogger Drops Support for Windows 7 64-bit in 2021
    FlexLogger is application software for quick sensor configuration and data logging of mixed signals to verify electromechanical systems, all without programming.
    Back to Top
    FlexLogger has the following minimum system requirements:
    Operating System
    RAM/Processor
    Required Software1
    • 64-bit version of Windows 10/8.12/7 SP13
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    • 4 GB disk space
    • 4 GB RAM
    • NI-DAQmx software 19.0 or higher
    • NI-XNET software 19.0 or higher
    1 Required drivers are included with the FlexLogger installer.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Back to Top
    NI automates FlexLogger installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Back to Top
    Back to Top
    New Features2019 R3 (July 2019)
    • Added hardware support for the FD-11605
    • Alarms for input channels, including the following features:
      • Alarm history pane
      • Event triggering from alarms
    • Reset values on output channels
    • Additional measurement types for counter input modules:
      • Angular position
      • Linear position
      • Pulse
    • Hardware filter support for FieldDAQ
    • Support for custom I/O plugins created with the FlexLogger Plugin Development Kit 1.0
    • Boolean logic for analog channels
    • Digital input event triggering
    • Output support for LIN
    • LIN master support
    • Offline FlexLogger manual access
    2019 R2 (April 2019)
    • Added hardware support for:
      • FD-11634
      • NI 9866
      • USB-8506
    • Output support for CAN
    • Input support for LIN
    • Capability to add timestamped notes during test
    • Lowpass and highpass Butterworth filter channels added to Channel Specification
    • TSN synchronization feedback
    • No limits on Slow/Medium/Fast/Digital sample rate configuration
    • System memory monitoring and dynamic visualization settings
    • Pull-up resistor support and threshold voltage support for the NI 9361
    • Powered sensor support for the FD-11601
    2019 R1 (December 2018)
      • NI 9231
      • FD-11601
      • FD-11614
      • TRC-8546 transceiver cable for the NI 9860
    • Enhanced system visualization in Channel Specification
    • Conditional events to automate outputs
    • RMS and Mean averaging of channels added to Channel Specification
    • Capture test metadata
    • Improved graph visualization
    • Analog input channel data filtering
    • Ability to reassign I/O or automotive channel configurations
    • Automatically log channel characteristics
    • Screen visualization shows minimum and maximum data values in visible range
    Back to Top
    The following lists detail the hardware models supported in FlexLogger.
    CompactDAQCompactDAQ Chassis
    • cDAQ-9171
    • cDAQ-9174
    • cDAQ-9178
    • cDAQ-9179
    • cDAQ-9181
    • cDAQ-9184
    • cDAQ-9185
    • cDAQ-9188
    • cDAQ-9188XT
    • cDAQ-9189
    • cDAQ-9191
      Note: FlexLogger supports network synchronization using IEEE 802.1AS protocol. Refer to your chassis documentation, available on ni.com/manuals, for more information.
    C Series Voltage Input Modules
    • NI 9201
    • NI 9202
    • NI 9205
    • NI 9206
    • NI 9209
    • NI 9215
    • NI 9220
    • NI 9221
    • NI 9222
    • NI 9223
    • NI 9224
    • NI 9225
    • NI 9228
    • NI 9229
    • NI 9238
    • NI 9239
    • NI 9242
    • NI 9244
    • NI 9251
    C Series Voltage Output Modules
    • NI 9263
    • NI 9264
    • NI 9269
    C Series Current Input Modules
    • NI 9203
    • NI 9208
    • NI 9227
    • NI 9246
    • NI 9247
    C Series Current Output Modules
    • NI 9265
    • NI 9266
    C Series Voltage and Current Input Modules
    • NI 9207
    C Series Sound and Vibration Input Modules
    • NI 9230
    • NI 9231
    • NI 9232
    • NI 9234
    • NI 9250
    C Series Temperature Input Modules
    • NI 9210
    • NI 9211
    • NI 9212
    • NI 9213
    • NI 9214
    • NI 9216
    • NI 9217
    • NI 9226
    C Series Universal Analog Input Modules
    • NI 9218
    • NI 9219
    C Series Strain/Bridge Input Modules
    • NI 9235
    • NI 9236
    • NI 9237
    C Series Counter Input Modules
    • NI 9361
    C Series Digital Modules
    • Serial Digital I/O Modules
      • NI 9375
        Note: The NI 9375 can only use one port (input or output) at a time in a project.
      • NI 9403
      • NI 9425
      • NI 9426
      • NI 9476
      • NI 9477
      • NI 9478
    • Parallel Digital I/O Modules
      • NI 9344
      • NI 9401
      • NI 9402
      • NI 9411
      • NI 9421
      • NI 9422
      • NI 9423
      • NI 9435
      • NI 9436
      • NI 9437
      • NI 9472
      • NI 9474
      • NI 9475
      • NI 9481
      • NI 9482
      • NI 9485
    Note: You cannot use parallel and serial modules together on the same FlexLogger project unless they are installed in separate cDAQ chassis.
    C Series CAN Interface Modules
    • NI 9861
    • NI 9862
    C Series Vehicle Multiprotocol Interface Modules
    • NI 9860
    CAN Interface Devices
    • NI USB-8502
    C Series LIN Interface Modules
    • NI 9866
    LIN Interface Devices
    • NI USB-8506
    FieldDAQVoltage Input Device for FieldDAQ
    • FD-11601
    • FD-11603
    • FD-11605
    Note  Revision B and later of the FD-11603 supports hardware filtering.
    Sound and Vibration Input Device for FieldDAQ
    • FD-11634
    Strain/Bridge Input Device for FieldDAQ
    • FD-11637
    Note  Revision B and later of the FD-11637 supports hardware filtering.
    Temperature Input Device for FieldDAQ
    • FD-11613
    • FD-11614
    Note: FlexLogger supports network synchronization using IEEE 802.1AS protocol. Refer to your device documentation, available on ni.com/manuals, for more information.
    Note: FieldDAQ supports hardware filtering. Refer to the FlexLogger Manual for more information.
    Back to Top
    You can extend the functionality of FlexLogger 2019 R3 by creating and importing a custom I/O plugin using the FlexLogger Plugin Development Kit (version 1.0). The FlexLogger Plugin Development Kit is available for download in NI Package Manager. Refer to the FlexLogger Plugin Development Kit 1.0 Readme for more information.
    Back to Top
    The online FlexLogger manual contains the most current help for your product version. Refer to the FlexLogger Manual, accessible from Help»Online manual, for more information about using FlexLogger.
    Users without online access can choose to use an offline version of the FlexLogger manual if that option is selected at installation. To enable the use of the offline FlexLogger manual, go to Preferences»General and select Use the installed FlexLogger manual.
    Note: Installed manual use within FlexLogger 2019 R3 is currently available in English only. To access other language versions of the installed manual, go to C:\Program Files (x86)\National Instruments\Help Viewer\Documentation and double-click the NIHELP file for your language.
    Back to Top
    Back to Top
    Back to Top
    FlexLogger Drops Support for Windows 7 (64-Bit)
    FlexLogger will drop support for Windows 7 (64-bit) operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on this operating system. For detailed information about NI operating system support, visit ni.com/r/windows764bit.
    Back to Top
    © 2017–2019 National Instruments. All rights reserved.
    377046F-01
    GMT+8, 2025-6-6 08:40
