查看: 3398|回复: 0
[LV工具模块] LabVIEW 2017 DataFinder Win32Eng LV2017数据查找工具包DFTK2017下载
    12 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-8-5 19:42:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW DataFinder工具包可帮助您使用LabVIEW中的DataFinder搜索引擎。
    LabVIEW DataFinder工具包是LabVIEW的一个软件附件,可连接至DataFinder来管理和搜索数据文件,而不论其格式或位置如何。该附件包含My DataFinder桌面应用程序,可创建描述性信息的索引,并与测试文件一起存储。借助该附件,您可创建应用程序来用于访问索引信息,通过简单关键词或高级条件查询的方式在测试数据中查找动态和相关关系。此外,LabVIEW DataFinder工具包可以连接到DataFinder Server,以实现大型集中式数据管理应用程序。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    DFTK2017.txt (247 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2017 DataFinder Toolkit Readme
    2017
    Version 17.0.0
    May 2017
    This file contains important information about LabVIEW 2017 DataFinder Toolkit, including installation instructions, new features, and known issues.
    Redistributing and Activating Executable Applications
    Notes on DataFinder Toolkit
    Automatic Installation of NI Products
    LabVIEW 2017 DataFinder Toolkit enables you to connect to NI DataFinder in order to manage and search your data files regardless of format or location. The Desktop DataFinder ("My DataFinder"), installed with this toolkit, creates an index of the descriptive information stored with your test files. With LabVIEW 2017 DataFinder Toolkit you can build applications to access the indexed information using either a simple keyword search as well as an advanced query to find trends and correlations in your test data. LabVIEW 2017 DataFinder Toolkit can also connect to NI DataFinder Server Edition, the DataFinder server for larger, centralized data management applications.
    To create applications or shared libraries using LabVIEW 2017 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2017
    • National Instruments LabVIEW 2017 DataFinder Toolkit
    To deploy and use applications or shared libraries using LabVIEW 2017 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2017 DataFinder Toolkit Run-Time
    LabVIEW 2017 DataFinder Toolkit can connect to and work with the following versions of DataFinder Server Edition:
    • National Instruments DataFinder Server Edition 2.0 or higher
    • National Instruments DataFinder Server Edition 2014 or higher for connecting to DataFinder Federation Server
    LabVIEW 2017 DataFinder Toolkit can change the configuration settings of the following versions of DataFinder when installed on the same computer:
    • National Instruments DataFinder Server Edition 2.1 or higher
    • National Instruments Desktop DataFinder 2010 or higher
    LabVIEW 2017 DataFinder Toolkit supports the following platforms:
    • Windows 10/8.11/7 SP12
    With this release, DataFinder Toolkit 2017 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. DataFinder Toolkit 2017 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use DataFinder Toolkit 2017 to an unsupported OS. Additionally, after installing DataFinder Toolkit 2017, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    (LabVIEW 64-bit) LabVIEW 2017 DataFinder Toolkit is not supported in LabVIEW (64 bit).
    Use Application Builder to create installers to distribute stand-alone applications and shared libraries built with LabVIEW 2017 DataFinder Toolkit. Include LabVIEW 2017 DataFinder Toolkit Run-Time installer. Activate LabVIEW 2017 DataFinder Toolkit Run-Time on the host computer using the NI License Manager.
    • For the My DataFinder in DataFinder Toolkit 2017, any index files from earlier Toolkit versions must be regenerated. This occurs automatically when launching My DataFinder. Depending on how many files are to be indexed, this may take quite some time.
    Known IssuesFirewall
      The firewall displays a warning while LabVIEW 2017 DataFinder Toolkit installs because the DataFinder, which you use for searching and navigating in files, then starts.
      If you want to be able to use all the functions offered by LabVIEW 2017 DataFinder Toolkit, National Instruments recommends that you select "Do not block" for all programs listed. This also applies when you want to evaluate LabVIEW 2017 DataFinder Toolkit. Refer to ni.com/info under the info code expm69.
    Installation
      LabVIEW 2017 DataFinder Toolkit and DIAdem Version 10.0, and later versions, install and use a shared software component (Desktop DataFinder - My DataFinder) that is updated when you install LabVIEW 2017 DataFinder Toolkit. When you uninstall LabVIEW 2017 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
      LabVIEW 2017 DataFinder Toolkit, DIAdem Version 9.0, LabWindows/CVI Version 8.1, DataFinder Server Edition 1.0 and LabVIEW Version 7.1, and later versions, use a shared software component (USI) that is updated when you install LabVIEW 2017 DataFinder Toolkit. When you uninstall LabVIEW 2017 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
    DataPlugins
      Use a DataPlugin built with LabVIEW DataPlugin SDK only with the same LabVIEW version with which you created this DataPlugin.
    Using configuration methods for DataFinder Server
      If you use the methods of the DataFinder toolkit to configure a DataFinder server, you must restart the "NI Skyline Service Manager" Windows service.
    Visit ni.com/security to view and subscribe in order to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    • Refer to KB 4CJDP38M, Automating the Installation of a Single Installer for more information on automatic installations of individual NI products.
    • Refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer? for a description of the version of the NI Installer your product contains.
    The following items are the IDs and titles of a subset of issues fixed in DataFinder Toolkit 2017. This is not an exhaustive list of issues fixed in the current DataFinder Toolkit version. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    CAR IDDescription
    549880Empty "paths to be indexed" inputs will be ignored.
    549882VIs or Invoke Nodes exposing a file path terminal, for instance Index Folder, will create a memory leak.
    602817After updating Windows 10, you can no longer configure DataFinder.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2017 DataFinder Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DataFinder Toolkit are located in the labview\examples\DataFinder directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Microsoft Windows 10 is the latest version of the Windows operating system. Windows 10 features significant changes compared to previous versions. Windows 10 combines features from both Windows 7 and Windows 8. Moreover, the operating system introduces several new capabilities. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2009–2017 National Instruments. All rights reserved.
    375404C-01
    GMT+8, 2026-4-1 12:19
