查看: 2821|回复: 0
[LV工具模块] LabVIEW 2011 DataFinder Win32Eng LV2011数据查找工具包DFTK2011下载
    昨天 07:21
  • 签到天数: 3583 天
    连续签到: 3 天
    发表于 2020-8-5 16:34:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW DataFinder工具包可帮助您使用LabVIEW中的DataFinder搜索引擎。
    LabVIEW DataFinder工具包是LabVIEW的一个软件附件,可连接至DataFinder来管理和搜索数据文件,而不论其格式或位置如何。该附件包含My DataFinder桌面应用程序,可创建描述性信息的索引,并与测试文件一起存储。借助该附件,您可创建应用程序来用于访问索引信息,通过简单关键词或高级条件查询的方式在测试数据中查找动态和相关关系。此外,LabVIEW DataFinder工具包可以连接到DataFinder Server,以实现大型集中式数据管理应用程序。
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    请注册登录视觉论坛会员,购买附件查看
    DFTK2011.txt (250 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2011 DataFinder Toolkit Readme
    June 2011
    This file contains information to introduce you to the LabVIEW 2011 DataFinder Toolkit. This file also provides you with help resources you can use while working with the LabVIEW 2011 DataFinder Toolkit. The file contains the following information:
    New Features of LabVIEW 2011 DataFinder Toolkit
    System Requirements and Supported Platforms
    Installing and Activating DataFinder Toolkit
    Redistributing and Activating Executable Applications
    The LabVIEW 2011 DataFinder Toolkit enables you to connect to NI DataFinder in order to manage and search your data files regardless of format or location. The Desktop DataFinder ("My DataFinder"), installed with this toolkit, creates an index of the descriptive information stored with your test files. With the LabVIEW 2011 DataFinder Toolkit you can build applications to access the indexed information using either a simple keyword search as well as an advanced query to find trends and correlations in your test data. The LabVIEW 2011 DataFinder Toolkit can also connect to NI DataFinder Server Edition, the DataFinder server for larger, centralized data management applications.
    The LabVIEW 2011 DataFinder Toolkit will provide the following new features:
    • New VI Get Indexed Value List, that returns a list of strings which contains all indexed values for the specified string property.
    • New VI Get Indexed Value Limits, that returns the minimum indexed value and the maximum indexed value of the given numeric or date/time property.
    • New properties parent, children and name for the search result reference.
    • Management of NI DataFinder Server Edition 2011
    For more details please refer to the LabVIEW 2011 DataFinder Toolkit Help.
    To create applications or shared libraries using the LabVIEW 2011 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2011
    • National Instruments LabVIEW 2011 DataFinder Toolkit
    To deploy and use applications or shared libraries using the LabVIEW 2011 DataFinder Toolkit, you must be a properly licensed user and have the following software installed on the host computer:
    • National Instruments LabVIEW 2011 DataFinder Toolkit Run-Time
    The LabVIEW 2011 DataFinder Toolkit can connect to and work with the following versions of DataFinder Server Edition:
    • National Instruments DataFinder Server Edition 2.0 (or higher)
    The LabVIEW 2011 DataFinder Toolkit can change the configuration settings of the following versions of DataFinder when installed on the same computer:
    • National Instruments DataFinder Server Edition 2.1 (or higher)
    • National Instruments Desktop DataFinder 2010 (or higher)
    The LabVIEW 2011 DataFinder Toolkit supports the following platforms:
    • Windows XP Pro Service Pack 2 or later, excluding Windows XP x64
    • Windows Vista 32 bit
    • Windows Vista 64 bit (as 32 bit application)
    • Windows 7 32 bit
    • Windows 7 64 bit (as 32 bit application)
    (LabVIEW 64-bit) The LabVIEW 2011 DataFinder Toolkit is not supported in LabVIEW (64 bit).
    Installing and Activating LabVIEW 2011 DataFinder Toolkit
    You can install all of your LabVIEW products—including LabVIEW 2011 DataFinder Toolkit—by using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the LabVIEW 2011 DataFinder Toolkit along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    You can evaluate the products for free for 30 days. After the evaluation period for the LabVIEW 2011 DataFinder Toolkit expires, you are no longer able to perform the following actions:
    • Run VIs from the LabVIEW 2011 DataFinder Toolkit.
    • Run VIs that use VIs from the LabVIEW 2011 DataFinder Toolkit.
    • Build VIs that use VIs from the LabVIEW 2011 DataFinder Toolkit into an executable or shared library.
    • Access palettes installed by the LabVIEW 2011 DataFinder Toolkit .
    To activate the LabVIEW 2011 DataFinder Toolkit license, use the serial number you received on the Certificate of Ownership. You can activate the LabVIEW 2011 DataFinder Toolkit license in any of the following ways:
    • After you launch LabVIEW in evaluation mode, click the Activate Products button in the LabVIEW dialog box.
    • Select Help»Activate LabVIEW Components while LabVIEW is running in evaluation mode or select Start»All Programs»National Instruments»NI License Manager to launch the NI License Manager. The license activation does not take effect until you restart LabVIEW.
    Use Application Builder to create installers to distribute stand-alone applications and shared libraries built with the LabVIEW 2011 DataFinder Toolkit. Include the LabVIEW 2011 DataFinder Toolkit Run-Time installer. Activate the LabVIEW 2011 DataFinder Toolkit Run-Time on the host computer using the NI License Manager.
    The LabVIEW 2011 DataFinder Toolkit User Manual contains conceptual information about the LabVIEW 2011 DataFinder Toolkit and the DataFinder itself. Open this manual by selecting Start» Programs»National Instruments»LabVIEW 2011»LabVIEW Manuals and opening DataFinderTK.pdf or by navigating to the labview\manuals directory and opening LV_DataFinderTK.pdf.
    The LabVIEW 2011 DataFinder Toolkit Help contains reference information about DataFinder VIs and functions. Complete the following steps to access the LabVIEW 2011 DataFinder Toolkit Help.
    • Launch LabVIEW.
    • Select Help»Search the LabVIEW Help from the pull-down menu to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to Toolkits»DataFinder.
    LabVIEW examples for the LabVIEW 2011 DataFinder Toolkit are located in the labview\examples\DataFinder folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find example VIs by using the NI Example Finder. Select Help»Find Examples to launch the NI Example Finder.
    Use the Browse or Search page of the NI Example Finder to find an example VI. In the Browse page, the LabVIEW 2011 DataFinder Toolkit examples are located in the Toolkits and Modules»DataFinder folder.
    Notes on DataFinder ToolkitFirewall
      The firewall displays a warning while the LabVIEW 2011 DataFinder Toolkit  installs because the DataFinder, which you use for searching and navigating in files, then starts.
      If you want to be able to use all the functions offered by the LabVIEW 2011 DataFinder Toolkit, National Instruments recommends that you select "Do not block" for all programs listed. This also applies when you want to evaluate the LabVIEW 2011 DataFinder Toolkit. Refer to ni.com/info under the info code expm69.
    Installation
      The LabVIEW 2011 DataFinder Toolkit and DIAdem Version 10.0, and later versions, install and use a shared software component (Desktop DataFinder - My DataFinder) that is updated when you install the LabVIEW 2011 DataFinder Toolkit. When you uninstall the LabVIEW 2011 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
      The LabVIEW 2011 DataFinder Toolkit, DIAdem Version 9.0, LabWindows/CVI Version 8.1, DataFinder Server Edition 1.0 and LabVIEW Version 7.1, and later versions, use a shared software component (USI) that is updated when you install the LabVIEW 2011 DataFinder Toolkit. When you uninstall the LabVIEW 2011 DataFinder Toolkit, the current version of the shared component remains. This is intentional and has been tested extensively.
    DataPlugins
      Use a DataPlugin built with the LabVIEW DataPlugin SDK only with the same LabVIEW version with which you created this DataPlugin.
    © 2011 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-7-4 02:12
