查看: 4740|回复: 0
[LV工具模块] LabVIEW 2017 FPGA Module Win32Eng LabVIEW2017FPGA模块LVFPGA2017英文版
    13 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
    发表于 2020-8-4 18:50:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    下载地址1:
    请注册登录视觉论坛会员,购买附件查看
    下载地址2:
    请注册登录视觉论坛会员,购买附件查看
    FPGA2017.txt (366 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2017 FPGA Module Readme
    March 2017
    This file contains important information about the LabVIEW FPGA Module, including system requirements, installation instructions, new features, upgrade and compatibility issues, known issues, and a partial list of bugs fixed for this release.
    FPGA Module System Requirements
    With the LabVIEW FPGA Module, you can create VIs that run on NI FPGA targets, such as Reconfigurable I/O (RIO) devices. The FPGA Module helps you design complex systems by providing a highly-integrated development environment, a large ecosystem of IP libraries, a high-fidelity simulator, and debugging features. The FPGA Module also includes FPGA IP Builder and the FPGA Compile Farm Server. You can use FPGA IP Builder to efficiently implement your LabVIEW algorithms for FPGA targets and to generate FPGA code that meets specific performance requirements. FPGA IP Builder supports only a subset of FPGA targets. Visit ni.com/info and enter the Info Code exvxfe for a list of supported targets. You can use the FPGA Compile Farm Server to offload compiles to dedicated computers.
    • LabVIEW 2017 Full or Professional Development Systems (32-bit)
    • 11 GB of additional disk space
    • Memory1:
      • At least 4 GB of RAM2 for Virtex-6 and later FPGA targets
      • Windows 10/8.13
      • Windows 7 SP14
      • Windows Server 2008 R2 SP14
      Note
      • In 2016 the FPGA Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 FPGA Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2017 FPGA Module to an unsupported OS. Additionally, after installing the LabVIEW 2017 FPGA Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
      • Only the FPGA Interface functions are supported on Windows 10 and Windows 8.1. FPGA development functionality is not fully supported as some of the features require the use of Xilinx compilation tools. These tools do not support Windows 10 or Windows 8.1. Refer to the NI website for a list of known issues that you may encounter if you run the FPGA Module on Windows 10.
      • NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2017 FPGA Module, install the device driver software. Refer to the hardware documentation for requirements for a specific device.
    2 You must use a 64-bit OS to address 4 GB of RAM.
    3 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    4 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017.
    • 35 MB of disk space
    • 1 GB RAM
      • Windows 10/8.11
      • Windows 7 SP12
      Note  In 2016 the FPGA Compile Farm Server dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2017 FPGA Compile Farm Server will not install or run on an unsupported OS.
    • Web browser that supports Microsoft Silverlight for accessing compile job queues via the NI Web-based Configuration & Monitoring Service FPGA Compile Farm Console
    You can use either a Windows or Linux computer as a compile worker. Refer to the Xilinx Compilation Tools Readme for information about the minimum system requirements.
    Note  If you are upgrading from a previous version of LabVIEW, you must install the LabVIEW 2017 FPGA Module before mass-compiling existing FPGA VIs. Otherwise, some FPGA-specific VIs might have mutation issues.
    Complete the following steps to install LabVIEW and the FPGA Module:
      • LabVIEW
      • FPGA Module
      • Xilinx Compilation Tools—Install these compilation tools on the development computer if you want to compile your LabVIEW FPGA VIs locally. You must install these tools on your development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use FPGA IP Builder, or use third-party simulation. Refer to your hardware documentation for information about the FPGA chip in your device and install the appropriate set of tools. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
        • Xilinx Compilation Tools for Windows—Install these compilation tools if you will compile your FPGA VIs on a Windows computer. The Xilinx compilation tools for Windows include Vivado 2015.4 and ISE 14.7.
        • Xilinx 10.1 Compilation Tools—Install the Xilinx 10.1 compilation tools if your FPGA device contains a Xilinx Virtex II chip. To download the Xilinx 10.1 compilation tools, refer to ni.com/info and enter the Info Code FPGATool101.
    • Linux—Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for information about setting up a remote compile worker.
    The LabVIEW 2017 FPGA Module includes the following new featurs:
    • Project export for the Vivado Design Suite—The LabVIEW 2017 FPGA Module provides an option to export FPGA VIs as Vivado Design Suite projects. This option allows you to design the exported project and compile it into a bitfile in the Vivado Design Suite. You can then run the bitfile on an FPGA target in the FPGA Module.
    • Support for channel wires—The LabVIEW 2017 FPGA Module adds support for a limited number of channel templates and endpoints.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the FPGA Module. This is not an exhaustive list of issues fixed in the current version of the FPGA Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    629576I2C/SPI palette link in FPGA does not properly open VIPM in Google Chrome
    611528Flush (FIFO Method) node breaks VI as unsupported if FIFO In is wired
    608514When using Target to Host FIFO, SGL changes to FXP if the Configure FPGA VI Reference dialog box opens after the VI or bitfile is imported
    602509FPGA Desktop Execution node reports error -61444 when an FPGA control or indicator is inside a tab control
    602274Read TEDS method reports error -65006 on cRIO targets when the Open FPGA VI Reference function is in dynamic mode
    601363When running a bitfile, the Split Number function returns all zeroes if you wire an I16 array to the input, wire the hi(x) output, and leave the lo(x) output unwired
    596659Unexpected XNode error when an FPGA VI using a FIFO is changed while another FPGA VI is running interactively on the the same target
    595635In an FPGA IP Builder design, resource configuration on an array buffer might conflict with the interface configuration and cause errors during the IP build process
    589796Duplicating example projects with an FPGA VI containing the Read I/O function or Get I/O Read Status function causes an error
    455843"FPGA Target" is localized to Japanese with multibyte characters, which causes build errors for RT executables referencing an FPGA bitfile with a default name
    Upgrading the FPGA Module requires you to upgrade to a new version of the Xilinx compilation tools. This upgrade can change the timing or resource utilization characteristics of FPGA VIs you developed in previous versions or cause these VIs to fail to compile. NI recommends that you test all FPGA designs after upgrading.
    If you are upgrading from the LabVIEW 2015 FPGA Module or earlier to the LabVIEW 2017 FPGA Module, refer to previous versions of the LabVIEW FPGA Module readme or LabVIEW FPGA Module Release and Upgrade Notes, available on ni.com/manuals, for changes in previous versions of the FPGA Module.
    Note  The LabVIEW FPGA Module Release and Upgrade Notes document was deprecated from the 2016 release.
    © 2003–2017 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW \FPGA\Legal\
    374737G-01
    GMT+8, 2026-4-1 13:54
