查看: 3573|回复: 0
[LV工具模块] LabVIEW 2016 FPGA Module Win32Eng LabVIEW2016FPGA模块LVFPGA2016英文版
    前天 09:56
  • 签到天数: 3580 天
    连续签到: 13 天
    发表于 2020-8-4 18:42:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具):
    EXE版和ZIP版内容一样,仅压缩格式不同。EXE为NI当年发行版,ZIP版为后期NI重新压制版。
    EXE版:
    ZIP版:
    EXE版:
    请注册登录视觉论坛会员,购买附件查看
    ZIP版:
    请注册登录视觉论坛会员,购买附件查看
    FPGA2016.txt (528 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2016 FPGA Module Readme
    June 2016
    This file contains important information about the LabVIEW FPGA Module, including system requirements, installation instructions, descriptions of new features, upgrade and compatibility issues, known issues, and a partial list of bugs fixed for this release.
    FPGA Module System Requirements
    New Features and Changes
    With the LabVIEW FPGA Module, you can create VIs that run on NI FPGA targets, such as Reconfigurable I/O (RIO) devices. The FPGA Module helps you design complex systems by providing a highly-integrated development environment, a large ecosystem of IP libraries, a high-fidelity simulator, and debugging features. The FPGA Module also includes FPGA IP Builder and the FPGA Compile Farm Server. You can use FPGA IP Builder to efficiently implement your LabVIEW algorithms for FPGA targets and to generate FPGA code that meets specific performance requirements. FPGA IP Builder supports only a subset of FPGA targets. Visit ni.com/info and enter the Info Code exvxfe for a list of supported targets. You can use the FPGA Compile Farm Server to offload compiles to dedicated computers.
    • LabVIEW 2016 Full or Professional Development Systems (32-bit)
    • 11 GB of additional disk space
    • Memory1:
      • At least 4 GB of RAM2 for Virtex-6 and later FPGA targets
    • Either of the following operating systems:
      • Windows 7 SP13
      • Windows Server 2008 R2 SP13
      Note
      • The LabVIEW 2016 FPGA Module does not support the Windows Server non-R2 editions, Windows Server 2012 R2, Windows 8.1, or Windows 10.
      • NI recommends a 64-bit OS for the computer on which you install the Xilinx compilation tools.
    • FPGA device
    • Device driver software—To program most devices with the LabVIEW 2016 FPGA Module, install the device driver software. Refer to the hardware documentation for requirements for a specific device.
    2 You must use a 64-bit OS to address 4 GB of RAM.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2016.
    • 35 MB of disk space
    • 1 GB RAM
    • Windows 7 SP1
    • Web browser for accessing compile job queues via the NI Web-based Configuration & Monitoring Service FPGA Compile Farm Console
    You can use either a Windows or Linux computer as a compile worker. Refer to the Xilinx Compilation Tools Readme for the operating system to obtain information about the minimum system requirements.
    Note  If you are upgrading from a previous version of LabVIEW, you must install the LabVIEW 2016 FPGA Module before mass-compiling existing FPGA VIs. Otherwise, some FPGA-specific VIs might have mutation issues.
    Complete the following steps to install LabVIEW and the FPGA Module:
      • LabVIEW
      • FPGA Module
      • Xilinx Compilation Tools—Install these compilation tools on the development computer if you want to compile your LabVIEW FPGA VIs locally. You must install these tools on your development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, use FPGA IP Builder, or use third-party simulation. Refer to your hardware documentation for information about the FPGA chip in your device and install the appropriate set of tools. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
        • Xilinx Compilation Tools for Windows—Install these compilation tools if you will compile your FPGA VIs on a Windows computer. The Xilinx compilation tools for Windows include Vivado 2015.4 and ISE 14.7.
        • Xilinx Compilation Tools for Linux—Install these compilation tools if you will compile your FPGA VIs on a Linux computer. The Xilinx compilation tools for Linux include Vivado 2015.4 and ISE 14.7.
        • Xilinx 10.1 Compilation Tools—Install the Xilinx 10.1 compilation tools if your FPGA device contains a Xilinx Virtex II chip. To download the Xilinx 10.1 compilation tools, refer to ni.com/info and enter the Info Code FPGATool101.
    • Linux—Visit ni.com/info and enter the Info Code FPGAcwl for information about setting up a remote compile worker.
    LabVIEW 2016 FPGA Module Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, the LabVIEW FPGA Module drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. The LabVIEW 2016 FPGA Module and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2016 FPGA Module to an unsupported OS. Additionally, after installing the LabVIEW 2016 FPGA Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The LabVIEW 2016 FPGA Module includes the addition of a new suite of Xilinx compilation tools, Vivado 2015.4. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the FPGA Module. This is not an exhaustive list of issues fixed in the current version of the FPGA Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    577377FPGA User-Controlled I/O Sampling functions are broken in the Japanese version of LabVIEW 2015 and LabVIEW 2015 SP1
    574086IP Integration Node and Component Level IP can fail to generate simulation files in Vivado 2014.4
    568649FPGA VI Reference wire can become broken across structures and subVIs when the referenced bitfile changes
    550239A case structure that contains global variables and more than 32 cases can fail FPGA compilation
    545362The output valid terminal is missing if the FFT Express VI is configured to perform single channel, single sample transformation outside an SCTL
    534464The Tick Count Express VI in microseconds does not roll over in simulation
    495744VIs remain open after a project closes if the project contains a DMA FIFO that has an FXP data type
    549466The Linear Algebra Matrix Multiply function can return wrong simulation results when N=1 and Output pattern is Row-Wise Element
    542770Copying code from a subVI in a .lvlib that contains an SCTL or the FPGA I/O node can cause LabVIEW to hang or crash when you close the owning project
    521795The Sampling Probe Watch Window does not update unless the highlight execution mode is turned on
    512546When you compile an FPGA design on Vivado targets, specifically the USB-7856R, the compilation might hang during the place phase
    This section provides information about upgrading from the LabVIEW 2015 FPGA Module to the LabVIEW 2016 FPGA Module. Refer to previous versions of the LabVIEW FPGA Module Release and Upgrade Notes, available on ni.com/manuals, for changes in previous version of the FPGA Module.
    Note  The LabVIEW FPGA Module Release and Upgrade Notes document was deprecated from the 2016 release.
    Note  NI recommends that you test all FPGA designs after upgrading. Upgrading the FPGA Module requires upgrading to a new version of the Xilinx compilation tools. This upgrade can change the timing or resource utilization characteristics of FPGA VIs you developed in previous versions or cause these VIs to fail to compile.
    VIs that Contain an IP Integration Node
    If you open a VI saved in a previous version of LabVIEW that contains an IP Integration Node, you must regenerate support files for the IP. To regenerate the support files, select Tools»FPGA Module»Regenerate IP Integration Nodes Support Files from LabVIEW and follow the on-screen instructions.
    Note  If LabVIEW fails to update all support files, re-add the IP Integration Node to the VI and generate the support files for the IP Integration Node.
    If the IP Integration Node contains Xilinx Vivado IP configuration (.xci) files, you must regenerate the configuration files in the latest Xilinx compilation tool for Vivado. After regenerating the configuration files, re-add the files to the IP Integration Node, re-add the IP Integration Node to the VI, and generate the support files for the IP Integration Node.
    VIs that Contain a Xilinx IP Node
    If you open a VI saved in a previous version of LabVIEW that contains a Xilinx IP node, you must regenerate support files for the Xilinx IP node. To regenerate the support files, select Tools»FPGA Module»Regenerate IP Integration Node Support Files from LabVIEW and follow the on-screen instructions. (Xilinx Vivado) After regenerating the support files, verify the behavior of the Xilinx IP node. Reconfigure the Xilinx IP node if its behavior has changed.
    Tip  (Xilinx Vivado) You can also regenerate the support files by double-clicking the Xilinx IP node and clicking the Upgrade Xilinx IP button.
    © 2003–2016 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW \FPGA\Legal\
    374737F-01
    举报
    GMT+8, 2025-6-30 11:57
